928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 05-18-2015, 04:19 PM
  #5686
NC928S4
NC928S4's Avatar
Fixed headlight over retraction problem. Spline shaft on headlight motor was mostly stripped. Put in a replacement motor that had some sharp teeth and after several alignment attempts headlights are raising and lowering properly.
This is a pic of stripped spline.
Old 05-18-2015, 09:43 PM
  #5687
taylorgw
taylorgw's Avatar
Cleaned her up, enjoyed a warm long weekend with a couple good drives. This car continues to amaze/impress me ... 30 years old, but you would never know it.
Old 05-18-2015, 10:12 PM
  #5688
mickster
mickster's Avatar
Originally Posted by John Speake
Fitted a new relay to the HVAC head unit on my Euro 16v.
I used an Omron G6B2214P-US 12v. This relay has the advantage that it is rated for 5 Amps, rather than the miserable 2.5A of the original.
It's small enough to fit comfortably inside the relay with the covers on.
Great to know. In my old 91, the guy who replaced the relay used a 5A one as well-and I think it was Omron. Fused it with 3A at the freeze switch and good to go.
Old 05-20-2015, 02:18 PM
  #5689
MainePorsche
MainePorsche's Avatar
Hey Guys,
It's been a while for me. When it rains, it pours...
Hadn't seen the car, my tools etc in a while. Got the car out of the Maine winter hibernation mode and on the road. Timing belt tension check, oil and air filter change, coolant change, battery cell inspection, and cleaning/Deoxit to easy grounds and 13 pin. One cell on the battery a little low on H2O and some charging necessary. She started up on the first throw.
Hope all has been well with you.
Old 05-20-2015, 02:20 PM
  #5690
HoosierHitman
6th Gear
HoosierHitman's Avatar
Popped a hole in my radiator... looking for a replacement used for my 89 928 S4.... anyone have one ? Buehler... Buehler.... ? :} I need to post three times in order to be active, so thanks for letting me post here. Indy 500 or Bust this weekend !
Old 05-20-2015, 11:22 PM
  #5691
dr bob
Chronic Tool Dropper
dr bob's Avatar
Search will be your friend.
928 International has a pretty slick all aluminum replacement if yours can't be repaired. New originals can be spendy. They have good used ones too.
Old 05-21-2015, 10:31 AM
  #5692
voskian
voskian's Avatar
Craig, good to hear from you and that you have your 928 out and running. Hope to catch up with you at one of the shows. There is a tech session down in Wilbraham, ma, not sure how far from you, on July 11.
Will be doing an oil change this weekend.
Bob
Originally Posted by MainePorsche
Hey Guys,
Old 05-21-2015, 11:21 AM
  #5693
MainePorsche
Bob
Hey there Bob,
Hope all is well. July in Wilbraham will be tough. We are in the midst of transitioning to North Country in NY. I have been there for months laying the groundwork.
Craig
Add: What I did today - put the new tags on the plates that I got yesterday. They were expired from before I left.
Old 05-21-2015, 12:58 PM
  #5694
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,297 Likes on 493 Posts
Nice to see you back Craig.
Hope everything's good.
Haven't done much on mine lately.
Everything's fine. Well almost everyhting...
I have a coffee run next saturday with the local PCA group.
Can't wait to drive it!
Old 05-21-2015, 01:14 PM
  #5695
MjRocket
MjRocket's Avatar
Default So what did you do to your 928 Today......
Bertrand are you coming down for SITM?...You should my friend
Old 05-21-2015, 02:43 PM
  #5696
Bertrand Daoust
Hey Matt,
Unfortunately not.
Don't have much time this year.
I went two years ago and had a great time.
Beautiful place to held an event like this. Just perfect!
Jeannie and Dave are great hosts too.
Have fun there and wish you and all a lot of sun!
Old 05-21-2015, 10:20 PM
  #5697
martinss
martinss's Avatar
On my '88 auto, I cleaned and cleaned everything I could get to around the transmission area, drained the transmission and torque converter, dropped the pan, replaced the filter, cleaned the pan and reservoir, then reinstalled with new gasket.
Since the pan had been leaking since the PO had it, I had never been able to even see the reservoir for the accumulated crud. In aggregate I spent several hours cleaning everything I could get to - which made a relatively easy job a long one. This is what the pan looked like after cleaning:
Old 05-22-2015, 02:48 AM
  #5698
ltoolio
ltoolio's Avatar
Updated my hatch wiper to the 24" variety. Thanks to Alan and Arnoud for the idea/instruction.
The dust lines on the window give you an idea as to the difference in coverage from the old to the new.
Old 05-22-2015, 04:44 AM
  #5699
928DK
928DK's Avatar
Changed filter, K1 spring, cleaned oil pan and surroundings
Old 05-23-2015, 03:09 PM
  #5700
MainePorsche
Addressed a problem with my install of a DC FK95 fan controller. The issue was a physical wiring issue from where I had the trans temp, air intake temp, and high pressure refrig sensors tie into a SPST relay before going to the controller unit for fan activation through pins 12 & 13 on the control unit. After getting out of Northern Maine winter hibernation, I have clicking of the relay when I hit bumps. As I have to leave town and not track the fault, I have just disconnected the 30 pin power source to the relay from the Xbus output of fuse 3. The AC activation and the primary temp sensor work great, and this unit was a really good alternative. Will get to the wiring fault a little down the road.
Quick Reply: So what did you do to your 928 Today......
