928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 05-01-2015, 01:01 AM
  #5581
Preston2207
Preston2207's Avatar
Just bought the 85.
Today- checked belt tension and it was perfect. Checked all fluids added new coolant.
Fixed sunroof hinge. And put about 45 miles on the rubber round deals. I. Love. This. Car.
Old 05-01-2015, 01:38 PM
  #5582
christiandk
christiandk's Avatar
Got that window motor to work......old dry gue was the problem. Easy peasy! Love to make the original stuff work!
Old 05-01-2015, 01:40 PM
  #5583
Paddcomp
Paddcomp's Avatar
Today I removed a rounded brake caliper retaining bolt. Drilled, ground a slot, impact wrenched out. 4 new M12 x 70mm 1.5P high tensile Allen bolts fitted.
1off 100 jobs done.
Brian
88 S4 auto
Old 05-01-2015, 04:36 PM
  #5584
The Deputy
The Deputy's Avatar
Had a toughy today. Thought I'd tackle the rear wiper. Flipped the cover up off the control arm pivot...nut was just lying there...hmmmm...tighten it down after inspecting things...works great. Big fix for the day...but hey...ever once in a while you need a given.
Now, I'm looking forward to seeing a little rain.
Fixed the blower motor control speeds yesterday...just a relay.
I'm on a roll...but I better stop while I'm ahead.
Brian.
Old 05-01-2015, 05:20 PM
  #5585
Randy V
Randy V's Avatar
Just an observation -
The guy who started this thread hasn't been on Rennlist since late 2011.
I guess he's done working on his 928.
Old 05-01-2015, 09:23 PM
  #5586
NC928S4
NC928S4's Avatar
Hat's off to Tom at 928Intl! Quality Parts delivered on time. We have great suppliers.
I just finished installing replacement used horns. Both horns decided not to work and I was putting off the repair vaguely until some meathead drifted into my lane a couple of days ago and I could not honk. Adjacent lane was clear so a side swipe was avoided.
In retrospect, I'm pretty sure one of the horns was dead when I picked her up 5 years ago because the horn sound has been anemic on the best of days. The second horn finally gave up.
In diagnosing the failure I started with confirming the steering wheel switch functioned. This was confirmed by an audible relay clicking in the electrical panel. I then confirmed DC voltage at horn wires. A 12 VDC battery was then placed against each failed horn and not a sound was uttered. I expected to hear a horn blast but it turns out that's not how it works.
I tested each replacement horn on the 12 VDC battery and heard an energetic click but not a honk. Called up one of my EE buddies and he said there is probably an amplifier between the relay and horn. Whatever. I connected the newly arrived horns and both work as expected. So I guess there is some kind of horn frequency signal riding on the 12 VDC horn power. I learn something new everyday.
Old 05-01-2015, 09:48 PM
  #5587
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,322 Likes on 500 Posts
Adjusted the ride height in front.
Lift it about 7 mm. To get it at about 165 mm.
Went from 180 to around 158 in the last four years after new shocks installation/OP. springs.
Everything went very smoothly. About 30 min. for both wheels.
Now I need to drive it for a while to settle the suspension and re-measure it.
Old 05-01-2015, 11:42 PM
  #5588
Andy Kay
Andy Kay's Avatar
Bought a new rubber door seal from Roger. My wife took my 928 out of town. Not sure what I'll drive to the DFW 928 breakfast tomorrow.
Old 05-01-2015, 11:58 PM
  #5589
Captain_Slow
Captain_Slow's Avatar
Bertrand...this is interesting:
I noticed Stan's car at Hershey looked as low as my car. He reported he'd set ride height about 170 (I think) some years ago. I'm at 152+/- 1 mm up front. 165 rear. I can adjust rear fine. Front adjusters are stuck and spinning on the nubs on the shocks. Not done trying to free them, but prepared to remove shocks and springs.
Today I did something I should do more often...I washed the car. Then took it for a drive. It is in the high 50s to low 60s. In this kind of weather the car always feels stronger.
Looks so shiny now.
Old 05-02-2015, 12:45 AM
  #5590
kkgmgcooke
kkgmgcooke's Avatar
Cleaned the bugs off my windshield.
Old 05-02-2015, 01:14 AM
  #5591
The Forgotten On
The Forgotten On's Avatar
Finished the front 993 caliper install. Just need to do the rears and I will finally have decent brakes in my 81.
Old 05-02-2015, 01:56 AM
  #5592
Cadillac art
Cadillac art's Avatar
Put the 928 up on my new lift. The Fcar came back from the shop and I needed the room. Loving the lift!
Old 05-02-2015, 03:53 AM
  #5593
Randy V
Randy V's Avatar
Then do a 4-wheel alignment.
Old 05-02-2015, 07:25 AM
  #5594
Hilton
Hilton's Avatar
IIRC he was pretty obviously a flipper
Old 05-02-2015, 10:56 AM
  #5595
polecat702
Vegas, Baby!
polecat702's Avatar
How high is the ceiling in your garage?
Quick Reply: So what did you do to your 928 Today......
