928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 09-07-2014, 07:21 PM
  #5011
dr bob
Chronic Tool Dropper
dr bob's Avatar
Did a full exterior paint clean and seal. Car has been somewhat neglected since the Great Migration from SoCal in June, plus the contractor rolled it out of the garage here in the few weeks before we officially 'moved', and it got sprinkled and pine-tar speckled while it sat out. I cleaned the pine tar speckles off right away when we got here, but it's waited until now to do all the rest of the job. Interior still neeeds similar attention, but at least it's clean enough to use the cover now. Took it for a short 50-mile tour south before I dusted it and parked it. It's not wintah yet but the car is ready.
Old 09-07-2014, 08:14 PM
  #5012
Godzilla83s
Godzilla83s's Avatar
Got the windshield washers working on mine. I don't think they had sprayed fluid in 10 years! Going to have to get a replacement 1 way valve on the drivers side, or just leave the vacuum elbow I put in there in.
Old 09-07-2014, 10:04 PM
  #5013
Jetdriver69
Jetdriver69's Avatar
Removed the aux air valve to check its operation. After testing and repair, I have an increased idle with cold start @ 1200 rpm and 750 rpm when the valve fully closes.
Removed power to the idle switch which cured a throttle lag when revving the engine. I used to have a slight delay in the return to idle rpm, not quite dying, just a delay. Now without the idle switching have very smooth throttle response and no lag.
Old 09-08-2014, 02:03 AM
  #5014
295Porsche
295Porsche's Avatar
Washed it up... took years of "tree dust" off of it!!! Put it garage.
Old 09-08-2014, 02:59 AM
  #5015
The Patman
The Patman's Avatar
Today I found a major design flaw in the 928...too many wires running here and there!
so...I pulled a few out!
Old 09-08-2014, 11:06 AM
  #5016
dr bob
dr bob's Avatar
Picture shows what appears to be an S4+ car with rear wing removed. Or is it an earlier car with S4 bumper cover and lights? If it is an S4, you have both 7" front wheels on the right side. Should have 8" on the rears.
Old 09-08-2014, 12:06 PM
  #5017
owenstanley
owenstanley's Avatar
Removed the old and very oily hood insulation, cleaned off the adhesive, installed new hood insulation. Looks way, way better!
Old 09-08-2014, 12:41 PM
  #5018
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,200 Likes on 1,241 Posts
That car has a few interesting things going on:
https://rennlist.com/forums/928-foru...e-project.html
Old 09-08-2014, 05:56 PM
  #5019
soontobered84
soontobered84's Avatar
Started on the Stepson's cam carrier gasket replacement. This is a MUCH bigger job than I remember from the previous job on the Jalapeno. Of course, the Jalapeno's gaskets were replaced during a tech session in my garage with no shortage of willing participants to turn wrenches. This time, I'm doing the gasket change in BradW's shop which is an extreme upgrade in working locations.
I have both cam carriers off and now need to clean the old gaskets off. This is not fun.
Old 09-08-2014, 06:34 PM
  #5020
Bilal928S4
Bilal928S4's Avatar
Default Broke my creeper
Broke my creeper. Now have to go and buy a new one.
Old 09-08-2014, 06:35 PM
  #5021
Bilal928S4
Bilal928S4's Avatar
Replaced the motor mounts on the 89. A long weekend.
Old 09-08-2014, 06:38 PM
  #5022
Bilal928S4
Bilal928S4's Avatar
Previous weekend I had replaced all the hvac actuators except the one below the fan.
Old 09-08-2014, 06:41 PM
  #5023
Bilal928S4
Bilal928S4's Avatar
Also I had installed a short shifter on the 89.
Old 09-08-2014, 09:38 PM
  #5024
Koenig-Specials 928
Koenig-Specials 928's Avatar
Removed my front cooling flap motor to make room for a 16" pusher fan. Easy job
Old 09-08-2014, 11:45 PM
  #5025
295Porsche
295Porsche's Avatar
Dr. Bob... It is a 87 928s4... didn't have the spoiler on it when I got it. I just through the rims on it to get it out of the guys yard I bought it from. Will correct that, thank you for the info.
Quick Reply: So what did you do to your 928 Today......
