So what did you do to your 928 Today......
#4276
Inventor
Finished S4 intake refresh! Just rolled over 50,000 miles.
New gaskets, knock sensors, CPS, oil fill tower o-ring + 16V paper gasket + Yamabond.
Did a little gasket matching and bellmouth smoothing for good measure.
Only a little PorKen-izing - venturi delete, vapor recovery delete, intake temp switch delete.
Can you believe this made >300 rwhp!
#4277
Put some nicely donated side mirrors from MJ Rocket on. After i did a crappy job painting them. Im gonna sand them down and wrapped them...what i shoulda done from the get go. Thanks again to MJ for mirrors and mirror bras...they were kinda droopin a little.
#4278
New alternator, fixed some wires and up'd the boost.
#4280
Oil Change, Stripped and painted nuts black
Stripped lug nuts with "Airplane Paint Remover". That stuff is nasty but works. Sprayed nuts with brake cleaner then painted with Caliper black gloss. Look great.
#4283
Fixed the squeaking caliper on my front passenger's side. The people who did the brake job didn't screw them in.
These jobs are common place in their shop, I wonder how they missed it. Saved the rotor from being warped.
#4287
Started to dig into all the grounds (just going to clean them all, to say I have). Realized I couldn't find my 13mm socket and my garage was a disaster. I have been working out of my truck tool bag, since I left my garage setup in KC.
So, I told the GF I was going to HF to pick up a 13mm socket. A few hours and too many dollars later I have a new socket/ratchet set, plier set, screwdriver set, wrench set, and a pegboard to hang it all from.
Also talked the GF into working on the grounds while I put the garage together, she's a keeper. Though after getting the two in back, the battery terminals, and the two in front of the radiator she decided that was enough garage time for her. I finished the board, took the pic, and came inside myself. We'll tackle the hard ones tomorrow.
#4288
Had no low beam on the driver side headlight on the Strosek.
Troubleshot the problem, no power at the light, good power at the CE panel. Ohmed out the wiring from the CE panel to the headlight plug, open!
Raised the car up and looked up into the headlight well. Saw some frayed wires so I got a hand on them and they seperated. Guess what, all three wires, low, high and ground must have been mangeled by the headlight mechanism.
I was able to pull the frayed end out into the engine bay.
Removed the other end and soldered and heat shrunk the wires.
Ensured the wires were not being fouled by the light.
Works great!
Also washed both 928's after the repair.
It was a good day to be a 928!
Works great!
