928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 05-03-2012, 02:19 AM
  #2716
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,707 Likes on 1,310 Posts
Squeezed a couple different types of foam:
Old 05-03-2012, 03:35 AM
  #2717
928mac
928mac's Avatar
Hey Rob you dont squeeze enough during the day ha ha
What is the foam for?
Old 05-03-2012, 04:09 AM
  #2718
Rob Edwards
Archive Gatekeeper
Brad, I'm working out how best to reseal the airbox. I'm working on a post about this and why I think it's important (albeit a major, major, king kong PITA to do so, unless your car's already in a million pieces...)
Old 05-03-2012, 10:03 AM
  #2719
martinss
martinss's Avatar
Found a piece of history buried in the console of my '88:
It's from a Nokia Mobira phone. According to Wikipedia Mobira was a brand for early mobile phones from Nokia. The plug seems to be dated '86, so based on the timeline the phone was from either a Talkman or a Cityman - see pics of both here.
Old 05-05-2012, 11:18 AM
  #2720
AirtekHVAC
AirtekHVAC's Avatar
I jumpered from the jump post to the yellow on the 14-pin, and got the motor to turn...1st time since 1993!!
Old 05-05-2012, 03:47 PM
  #2721
jcorenman
jcorenman's Avatar
New lights... Thanks, Rob!
Old 05-05-2012, 05:05 PM
  #2722
inactiveuser1
inactiveuser1's Avatar
Received tow hook from 928 Motorsports.
Thanks for super fast shipping.
http://www.928motorsports.com/parts/...g_tow_hook.php
Old 05-05-2012, 11:09 PM
  #2723
NC928S4
NC928S4's Avatar
Installed front hood liner with decal. I'm sure the car is faster now because it looks cooler if you open the hood.
First we took off the hood. The electrical connections for the washer warmers and hood light unplugged easily and the hoses disconnected without issue. Removing the old liner was accomplished by first razoring out the old by parallel cutting the old hood liner with a window scraper. This worked way faster than pulling and scraping. My brother-in-law like-end it to sheering a sheep. He's single so I didn't ask push him on the sheep reference. We used liberal amounts of turpentine and let it soak for 3-5 minutes and the remaining liner and glue melted right off with a light scrape.
Applying the new liner was smooth and we did not use the wax paper procedure called out in the Budd instructions. Basically, the adhesive set up really fast and we were able to line up and adjust the liners without difficulty.
I'm not going to re-connect the washer fluid warmer lines mostly because I'm never going to need them and one has already smoked itself. The connector plugs were badly fouled so eliminating them is just another thing that can't fail.
Old 05-05-2012, 11:52 PM
  #2724
MainePorsche
MainePorsche's Avatar
Replaced my headlight switch with a new one. The changes were dramatic. See my 'Tricky AC problem' post.
Old 05-06-2012, 12:01 AM
  #2725
Adamant1971
Adamant1971's Avatar
Received 1,060 Likes on 504 Posts
Installed my new H4's.
Installed new hood badge.
Put my wheels back on.
Installed wiper arms.
Finished up door window trim.
Put all of my speakers, sub and amp back in and rear carpet, tool kit etc.
Installed the Porsche lettering on the rear from jager.
Installed temp sensor cap.
Made new vapor barrier for the doors and put panels back on.
It's 11 pm now and I just finished cleaning her up, can't wait to see her in the light tomorrow.
Old 05-06-2012, 12:38 AM
  #2726
Avar928
Avar928's Avatar
Got my Mass Air Flow sensor back from Injection Labs and installed it. Replaced the connecting boot too as it was cracked. Got a bunch of parts from Pelican, 928 MS, Roger and 928intl and a new light from Frank (thanks!).
I noticed better response from her with the rebuilt MAF, no more hesitation too.
Old 05-06-2012, 08:08 AM
  #2727
NoVector
NoVector's Avatar
Default Convert
Two more lights converted to LEDisim
Old 05-06-2012, 11:45 AM
  #2728
NickT
NickT's Avatar
Pulled out the HVAC blower housing and cleaned it all out.. Waiting on a new resistor pack and blower motor.
Old 05-06-2012, 01:37 PM
  #2729
Herman K
Herman K's Avatar
Default Fixed the coolant reservoir switch
The original float got water/coolant lodged did grind/sand it down some and slipped a styrofoam sleeve over it - back to normal
Old 05-06-2012, 04:27 PM
  #2730
megaelf
megaelf's Avatar
Default Drove some autocross today...
Quick Reply: So what did you do to your 928 Today......
