Empty shell to finished car
There's a lot less of it in the 928 than in my 997 and the stuff in the 997 is real, not a vinyl wrap. I like CF with black interiors as it gives a subtle visual pattern to what would otherwise be a very monochrome intereior, but it's still black, so goes well. I've actually CF wrapped the badges that will be on the exterior of the car too, which will say "928 Spyder", carrying the theme to the outside and making the badges stand out more than just plain black ones would. There will be a Spyder badge on the stainless running boards when you open the doors too.
I used an epoxy syringe from West Marine loaded with some high quality synthetic grease. Care needs to be taken to not crack the plastic (and now fragile) seal between the races. After 10 minutes of working the grease in, spinning the bearing, injecting more grease etc, the bearing is now whisper quiet and very smooth. It actually feels like a new bearing. Time will tell how long it will last.
While in there I also re-painted the black parts on the column, installed a new rubber vibration damper in the lower steering column, and put everything back together.
Next on the list was getting rid of the really dumb hatch motor, and I followed Alan's (think Colin also did this) PDF on how to do it. Part number is 1H5 959 781 and is a VW rear hatch release motor. Found on Ebay for $19.00. After the somewhat fidgety install, and numerous trials and errors, the hatch now pops open reliably, quickly, even from the key FOB that comes with the Infinitybox multiplexing electrical system.
Small victories, but it's getting closer
Cheers!
Carl
Basically, install the seal onto the glass, then install all the trim pieces. Then insert some cord into the seal slot all around the perimeter of the seal and let the end pieces meet at the bottom, hanging out a few inches so you can grab them. Place the window in the frame opening and while pressing from the outside at the same time you pull the cord "out" from the seal, the seal lip will be pulled inward and over the frame edge. Takes 5 minutes per side max.
I also got the ignition switch and turn/wiper stalk installed and wired up (mostly). The hookup to the Infinitybox system is very simple. The ignition switch only needs 3 connections (accessory, ignition and starter). The stock ignition switch and connector has the terminals embossed on the plastic, so the connections are as follows. Remember, the system is low-side switched so what normally is a "30" terminal (positive) now becomes the ground for this system.
30 --> chassis ground (because system is low-side switched)
X --> accessory input on Infinitybox system
15 --> ignition input on Infinitybox system
50 --> starter input on infinity box system
So basically, only 3 wires are needed on the ignition switch. However the switch has two "30" terminals, two "15" terminals, so I got lazy and instead of figuring out which one to use, I used both and ran a 2-into-1 connection to the Mastercell input. The first picture of the ignition switch shows the factory wires, the second picture of the switch installed shows the 22 AWG wires installed instead of the larger gauge factory wiring. Only milli-amps flow through the switch. The ground wires were kept at 18 AWG.
Turn signals are as follows:
49a --> chassis ground
L --> left turn signal input on Infinitybox system
R --> right turn signal input on Infinitybox system
High-beams are as follows:
56 --> chassis ground
56a --> high beam, and auxiliary high beam input on Infinitybox system
This works but only allows high beams when stalk is pushed forward. It won't activate the pull stalk to flash high beams, so I have to do some more re-tracing on that part. The wiper side of the stalk is next on the to-do list.
The infinity box has some neat diagnostic functions, so after things were wired, I put it in diagnostic mode to verify that the respective input gets activated when the various switches are pulled. Diagnostic mode is reached by holding down the two rightmost buttons for one second. Screen shots follow. It also shows the "uptime", how long the system has been powered, measured in Days:Hours:Minutes:Seconds. Pretty cool.
Cheers!
Carl
What kind of wing do you intend to put on the rear of the car? A Strosek wing would look nice but I do not think those are available anymore (also see my avatar picture).
I notice you have a red key sitting in rear hatch lock. According to my knowledge only older cars before 1987 had red keys and your car is of a later model.
Ċke
Hope you had a great mid-summer evening Ċke!
The wing is the "standard" GTS rear wing, although it is a fiberglass reproduction. My Audi seen in the picture is a very dark blue, and it stays cool very well, usually only needing a fan speed of 2-4 (out 12 max) to keep the set temperature. The 928 has an upgraded (stronger) fan blower, and the controller will be changed to a PWM controller for better fan speed control. The car also has a more efficient parallel flow condenser and a new evaporator, so I am gambling on this car having slightly better cooling than stock.
In addition to the hardware upgrades, the insulation has also been significantly upgraded, especially in the roof area. Roof panel has one layer of Damplifier Pro, followed by 12mm closed cell foam, which should keep that area cooler. With the window tint I think it will be very comfy inside
The red key is a "spare", the regular black key is in the ignition lock at the moment
The rear hatch lock was replaced with a non-alarm version several years ago, and came with a red key. At some point I will have the rear lock and ignition lock re-keyed for a single, new key.
The Strosek 928 looks great, is it single stage paint or did you put a clear coat on it?
Cheers!
Carl
Cheers!
Carl
Have thought about adding keyless go, I believe that to be an option with the ISIS system that you have. It would mean adding an electronic lock to the column where you key mechanism meets the column.
If you are referring to a pushbutton start so to not have an ignition key, yes that is an option. The Honda 2000 start button/switch is a popular switch that a bunch of guys have used. I decided against it, as for some reason I prefer the physical key. It is also less complicated as I don't have to replace the mechanical steering lock with an electric version. Of course a third option is to remove the physical steering lock all together, which I was contemplating, but for now I will keep it as is.
Cheers!
Carl
Cheers!
Carl
The red car has a single stage paint Indisch Rot (indian red) and several layers of clearcoat put on it. I did the car full restauration in 2000-2001 for a German customer. When he moved on to a Ferrari a few years later I bought the car for my wife as a compensation for all the flowers I had forgotten to give her over the years.
From being garaged all the time the paint is after 15 years still in very good condition but it is impossible to avoid damages from stone chips in the paint especially at the lower sides of the doors and in front of the rear wheels which is a drawback having a wide body car.
Note the small rear window which will minimize solar radiation into the car. I have raised the wing for better rear visibility.
Ċke
Anyway, the wiring for the wiper and windshield/headlight pump is as follows below. Only one ground point is needed, terminal 53a:
Interval wiper position
53a --> chassis ground
J --> Interval input on Mastercell
Single wipe position (uses same terminal as low speed wipe)
53a --> Chassis ground
53 --> Low speed input on Mastercell
Low speed wipe position
Medium speed wipe position
53b --> Medium speed on Mastercell
High speed wipe position
53i --> High speed input on Mastercell
Headlight Washer position
SR --> Headlight washer input on Mastercell
Windshield washer position
53c --> Windshield washer input on Mastercell
Finally I narrowed down the selection for my HVAC controller, and as can be seen in the picture I went through a few different options. From left to right, we have a 2000 Nissan Sentra controller, a 2008 Mazda Miata MX-5 controller, a 2011 Nissan Sentra controller, a 1998 Audi A4/S4 Quattro automatic controller, and finally a 2011 Kia Optima controller. All of them except the Kia controller (too wide) fits very well in the center console widthwise. They are all manual except the Audi controller, but after realizing the complexity of that control head I decided on a manual HVAC system for now. The final choice is the 2008 Miata controller, as it will match my interior ideas the best, and it also comes in an automatic version of the exact same size and appearance, so if the install goes well I may upgrade at a later stage. Both versions have "infinite" fan settings, as I do not like only 4 choices for fan speeds. Usually my choice is in-between what is available...
Now I just need to get the wiring harness procured, then integrated and then the door actuators, and then....hmm, this never ends does it?
Cheers!
Carl
