New Product: *** Illuminated Sill Kit *** UPDATE: NOW SHIPPING ***
#151
James - my car is a rather unique... It has retrofiited ROW electric headlight adjusters (perfect with H4's), the dual **** at the front is my 'remote mounted ****' for the Valentine 1 remote audio adapter (a great location for this). The rear one is a bass level control for my audio system.
Alan
Alan
#153
I think some place in this thread is the link to the instructions. You might find them on Paul or Hans' web sites too...that is probably where they are hosted. The key is to look up Andrew Olson's sill plate removal instructions so you get that off carefully w/o breaking it.
#154
Found it bout page 3, or 5...somewhere.
#156
I emailed Paul in April of 2015 regarding if they could still be purchased and he indicated that they are no longer available.
From what I read in some of the other threads (IIRC), the cost for the fabrication became too large, and (also, IIRC) one of the original fabricators had issues or backed out which complicated matters.
I for one, and I'm sure there are many others, would love to see them back available.
#157
#158
emailed with Paul late last night he and I must share the same affliction of late work. He indicated that a little redevelopment and potential interest would move this up on his list. I am in for a set, would even be beta tester if need be.
#159
There are a few previous write-up using parts easily sourced on eBay:
https://rennlist.com/forums/928-foru...-write-up.html
https://rennlist.com/forums/928-foru...l-upgrade.html
#160
The only thing I didn't like is the inconsistency in how light is distributed (look back at the multi-color picture for reference):
#162
Kit available
I purchased the illuminated sill kit and never got around to installing it. I would be willing to sell it if one of you really wants it - rather see it on someone else's 928 than collecting dust on a shelf.
#163
#164
Mine using the EL strips has been operating properly since installed several years ago.
#165
Thread Revival
George,
I also have a car with a digital dash, and I find that the while lighting matches quite well with the rest of the dash lighting. I will be using white myself, both for the switches and the sills. It is possible that there is an LED out there that would match better - the panels accept the standard 5mm (T1-3/4) type LED. You can order a handful of different colors from Mouser, Newark, or Digikey and see what matches your interior the best if you would like. Usually, LEDs only run between $0.35 and $1.50 depending on the light output and color, so it wouldnt be an expensive experiment, just time consuming, and unfortunately for now, I dont have to the time to spearhead that experiment.
If you do find some that match, please share the part number with the rest of us.
Hans
Hans
Here is what I come up with at Mouser using the keywords Hans gave above - this is Greek to me and only a few have pictures:
My guess is the "Standard LEDs - Through Hole" (based on the pictures), but even these have varying mcd (millicandella) values.
Thank you, in advance, for any pointers!
