928 Forum 1978-1995
Sponsored by: 928 Specialists
Twin Turbo 928 fixed and back out there terrorizing the streets!
Old 06-08-2015, 04:34 PM
  #916
S4ordie
Not the sharpest tool in the shed
S4ordie's Avatar
There are other devices that have been altering the brain for a long time. My personal favorite when tracing electrical problems on a 928 (see how I kept this relevant to this forum?)
Cool links - and way weird stuff. I would post this up in OT.
Old 06-09-2015, 08:04 PM
  #917
blau928
blau928's Avatar
Originally Posted by ptuomov
The exhaust manifolds are now a definitely a go, John released the purchase order, the foundry has the models, and the delivery date is mid July. Here's the last rendering.
Attachment 943344
This version passes the casting requirements, thermal stress requirements, gas flow requirements, and sensor location requirements.
Note the five sensor bungs. The four individual runner bungs can be used for either pressure traces or for WBO2 measurements (both need heat shields for the sensor). The fifth is for a very convenient access port for either slow (cycle average) pressure sensor, WBO2, or EGT. The point of that port is that it's more convenient to access than the individual runner ports. The best place to measure WBO2 for the whole bank is of right after the turbine because the burn process continues in the turbine and the readings are more reliable because of a more complete burn - downpipes have those.
Couldn't you use the ports in the head for EGT/Lambda monitoring? I think it's already tapped for EGT sensors with 12X1.5mm threads....
Are you going to use the in cylinder pressure monitoring as well?
Old 06-09-2015, 10:07 PM
  #918
ptuomov
ptuomov's Avatar
Pressure measurement ports need to be normal to the flow. The ports in the head face the flow.
We'll measure the cylinder pressure if we figure out how to fit everything that needs to fit inside the spark plug tower.
Old 06-10-2015, 12:19 AM
  #919
blau928
blau928's Avatar
Default Twin Turbo 928 fixed and back out there terrorizing the streets!
Gotcha.. The stock egt from Porsche had a curved sensor which would explain the flow.
Good luck with the pressure sensors. If you succeed with them, let me know, as I am curious to run either pressure or egt to my logger.
Old 07-02-2015, 11:23 AM
  #920
ptuomov
ptuomov's Avatar
Default Casting **** without a casting couch!
John sent me some screen shots from the design review of the casting process. (I couldn't join the event because of the ducking financial markets day job...) Molds, cores, yadayada yaa. One thing that I learned from these is that you _can_ do casting **** without a casting couch! ;-)
Old 07-07-2015, 06:46 PM
  #921
ptuomov
ptuomov's Avatar
Default Molds at the foundry
Here are the molds that are used to cast the turbo exhaust manifolds:
Old 07-07-2015, 07:45 PM
  #922
Imo000
Captain Obvious
Super User
Imo000's Avatar
Are both manifolds going to be in the same mold "block/bune"? How were molds made, are they sand?
Old 07-07-2015, 08:08 PM
  #923
ptuomov
ptuomov's Avatar
You need a different mold for each manifold, they are not symmetric. The blocks are separate, and poured separately, if I understood your question correctly. The patterns in the photos are 3D printed from sand with a particular process. The design of the molds is such that it's feasible to build the patterns that can be used to produce those sand molds faster without 3D printing.
Old 07-07-2015, 08:38 PM
  #924
ptuomov
ptuomov's Avatar
Default FIRE IN THE HOLE!!!
Def Leppard:
Pour some sugar on me
Ooh in the name of love
C'mon fire me up
Pour your sugar on me
Ooh I can't get enough
I'm hot, sticky sweet
From my head to my feet, yeah
Old 07-07-2015, 08:46 PM
  #925
blau928
blau928's Avatar
Attachment 952084
Attachment 952085
Attachment 952086
Attachment 952087
Awesome stuff..!! Looking forward to seeing the finished setup..
Old 07-08-2015, 01:18 AM
  #926
BC
BC's Avatar
That's pretty cool. (Or hot, as it were). I am not sure I would be wearing a t-shirt.
He has ordered enough to make each unit-set realistically priced?
Old 07-08-2015, 03:11 AM
  #927
ptuomov
ptuomov's Avatar
Originally Posted by BC
That's pretty cool. (Or hot, as it were). I am not sure I would be wearing a t-shirt. He has ordered enough to make each unit-set realistically priced?
The 3D print makes the small series economical. Plus the alternative of hand fabricating that manifold (as in the previous versions of the kit) is very expensive.
Old 07-08-2015, 08:22 AM
  #928
ptuomov
ptuomov's Avatar
Default The raw castings out of the molds
Old 07-08-2015, 09:01 AM
  #929
Imo000
Captain Obvious
Super User
Imo000's Avatar
Very nice!
Old 07-08-2015, 03:33 PM
  #930
Tony
Tony's Avatar
unreal.
Quick Reply: Twin Turbo 928 fixed and back out there terrorizing the streets!
