928 Forum 1978-1995
Sponsored by: 928 Specialists
Twin Turbo 928 fixed and back out there terrorizing the streets!
Old 07-17-2014, 03:04 PM
  #856
DKWalser
DKWalser's Avatar
At 5,250 rpm the horsepower and torque curves cross -- at just over 500 hp/lbs. Very nice.
Old 07-17-2014, 03:21 PM
  #857
Alan
Electron Wrangler
Alan's Avatar
Interesting that you have completely flat torque from 3.7K - 5K and pretty flat all the way up.
The flappy is clearly doing its work here - quickly getting torque up
Be interesting to see the effects of shifting the flappy activation point - did you try that?
Alan
Old 07-18-2014, 05:09 PM
  #858
ptuomov
ptuomov's Avatar
Originally Posted by Alan
Interesting that you have completely flat torque from 3.7K - 5K and pretty flat all the way up. The flappy is clearly doing its work here - quickly getting torque up. Be interesting to see the effects of shifting the flappy activation point - did you try that? Alan
We could make it even flatter at the top. In the next motor we will.
The flappy is set to open about the same time as the boost controller first cracks the wastegate. It's a busy area there. We've got a bunch of LH/EZK columns dedicated to that area.
Old 12-06-2014, 10:37 PM
  #859
ptuomov
ptuomov's Avatar
Default Hey what's up, bros?
Still knee deep in sorting out and shorting out oil firms, can't get out much to frivolous sites like this. Don't have time to give a full update, but the gist of it is that I've done _nothing_ 928 related for a couple of months and John's deep into intercooler optimization for a higher capacity system.
Old 12-09-2014, 10:45 PM
  #860
BC
BC's Avatar
Originally Posted by ptuomov
Still knee deep in sorting out and shorting out oil firms, can't get out much to frivolous sites like this..
I assume you mean this?
http://www.ft.com/intl/cms/s/2/1fedf...c0.html#slide0
Old 12-10-2014, 09:42 AM
  #861
Strosek Ultra
Strosek Ultra's Avatar
We ordinary lethal guys are losing money when the oil shares are going down. Think Tuomo did the opposite and hopefully it will be invested into future twin turbo developments for our entertainment.
Old 12-17-2014, 07:17 AM
  #862
ptuomov
ptuomov's Avatar
Hi again. Since the action at the market is over for a little while now, I figured I'd give an update.
There's an article about the car in PCA's Panorama magazine. I've tried to join PCA a couple of times, but their web application doesn't recognize my car's VIN so no dice in terms of paying them dues and getting the magazine. Hopefully one day I'll figure out how to sort that out, or maybe I'll just go and try the VIN's of my other two Porsches.
The article cover page looks nice, though:
Old 12-17-2014, 07:56 AM
  #863
AO
Supercharged
AO's Avatar
Nice!
Old 01-20-2015, 10:06 PM
  #864
ptuomov
ptuomov's Avatar
Default Another one about to spread its wings!
This car left John's shop today:
The owner will be driving it for 2400 miles to home. That's how reliable the system is. I did 1000 miles with mine in a day after it came off the dyno, so this is the new record for the shakedown!
On my car, I think next up is some intercooler and pressure air piping improvements.
Old 03-03-2015, 07:03 AM
  #865
ptuomov
ptuomov's Avatar
Here's some more detail on how John's been modeling the thermal stresses, flow, fitment, etc. for the next iteration of the turbo exhaust manifolds. These will be cast from Inconel in the late spring:
Old 03-03-2015, 09:13 AM
  #866
RKD in OKC
RKD in OKC's Avatar
Now I want a twin turbo setup on my GTS!
Old 03-03-2015, 08:45 PM
  #867
BC
BC's Avatar
Yep. That's still the John we know from 10 years ago.... Telling everyone how difficult it is.
So many years. So Many.... https://rennlist.com/forums/928-foru...rbo-928-a.html
https://rennlist.com/forums/928-foru...-turbos-2.html
https://rennlist.com/forums/928-foru...eir-928-a.html
Old 03-03-2015, 09:14 PM
  #868
ptuomov
ptuomov's Avatar
That would be interesting. It would however be more cost effective to get a 5-speed S4, say '87 with 9.4:1 compression ratio. Which is the route I went with, and can't say I've regretted it so far.
It is very difficult to get this level of power with this level of reliability, I think that's not overstatement. When the standards are raised, things get more and more difficult, as constraints starts binding from every direction.
The Inconel exhaust manifolds will be more reliable and likely flow better than the fabricated mild steel ones, and given the saved labor the cost impact is not large. With say 50 pairs cast there would be big cost savings, regardless of material, but there's the expected inventory holding cost that rules that option out. But I am digressing.
Old 03-03-2015, 10:56 PM
  #869
BC
BC's Avatar
Well, talk to him about opening it up. Put some prices up privately on how some of us can partake just in the manifolds and maybe we can get some economy on this.
Old 03-04-2015, 01:46 AM
  #870
RKD in OKC
RKD in OKC's Avatar
Wouldn't mind dropping the GTS's compression just a bit, and it is a 5 speed.
It's coming apart to freshen the rings.
My stroker 2.8 liter 944 Turbo had 8.5:1 to run 17psi. Only the turbo had to be one size bigger going from 2.5 to 2.8 liters.
Quick Reply: Twin Turbo 928 fixed and back out there terrorizing the streets!
