Twin Turbo 928 fixed and back out there terrorizing the streets!
#348
No ignition issues, other than that with too much timing it knocks like a **** and with too little timing it makes 100 hp less. I can get it to 650 Dynopack axle hp with 7 knocks per 10 second run on 93 pump gas. Above that, something would give.
On learning. Here's what I learned:
When you slam shut the throttle at 6700 rpm with 18 psi of boost, it's possible that the MAF sensor has a cow. Mine did. The voltage coming from the MAF is now all f'd up and the AFR on the way home was ten. So the car is a wreck for now, likely either MAF failure or LH failure. It's consistently rich as hell on both banks so I don't think it's a mechanical failure, those would show up more on one bank than the other. I drove it home, the MAF voltage is just all f'd up and all the associated problems.
I have a spare anything, except not a spare SuperMAF. I have a spare MAF, but that's regular not super...
In any case, I am out of commission for the 9/11 Shark party. I felt like a jackass showing up without a car at Carl's party, carrying just a dyno graph and a Victoria Secrets plastic bag full of booze. Only one person (who dropped my drunken *** off) saw the car.
#349
Here's one who's been left in the dust: In the end of the day, I limped the car home with some problem that gave and AFR of about 10 in both banks. Any idea about what can cause a slightly hot-rodded car to have a malfunction that shows up as a wildly rich AFR in both cylinder banks? It's so rich it can't hold idle coming off high rpm or before it's warmed up. I nursed it home giving the standard Massachusetts consideration to red lights. So what's next? I'll check the lines, but wouldn't a leak make it lean, not rich? I am thinking it's either the MAF or LF.
#350
Administrator - "Tyson"
Dynapacks are cool, haven't really played with one since EFI 101. None in the area that I know of.
Is the MAF in the stock location?
Nice graph! Even with a small hick-up like the MAF wigging out, progress is progress.
#353
1 Post
Nice, I like how you have modulated the boost so that you get a nice smooth power delivery, I'm also really impressed with the spread of boost, positive pressure at 2000 rpm, that also makes for a more driveable package.
I once drove a Nissan Skyline with 650 flywheel, but it doubled its' power between 5000 and 6000 rpm and was simply frightening, due to that.
I much prefer the power delivery of my own twin turbo 928.
I love your project, keep it up
Cheers Roy
Cheers Roy
#355
Supercharged
Super tuning session. 666 is spectacular. Do you know if that has a correction factor? The TQ is very fishy, and since HP is calculated from TQ, it begs the question if it's accurate. But it's clear you were there to tune, not throw a big number.
I don't see exactly how the MAF could richen the mixture. If anything, it would lean things out. Strange. Not sure how the superMAF works. If the super part of it broke, it would operate as a standard MAF - which would tell the LH there is more air than the tune - thus adding more fuel. Just a theory.
When you're nursing it home, were you making any boost? Just wondering about BOV?
Last thought would be fuel leaking in via vacuum lines from the regulator or dampners?
#357
The torque number is I believe the rear axle torque on fourth gear. That explains the scale.
I don't know whether this dyno measures the hp directly and then computes the torque or the other way around. It doesn't make any difference anyway which way it's computed, as long as it's computed accurately.
The peak in boost at 3300 is by design. I set the gate pressure to a bit high level, which means that the car has to make above-target boost before the boost controller turns the control algorithm on. This is for tuning purposes, I wanted to make sure that the car was making boost at the set points for the mid range and top end even if we didn't load it long enough under 3500 rpm. With hindsight, that setting was probably not necessary.
I don't see exactly how the MAF could richen the mixture. If anything, it would lean things out. Strange. Not sure how the superMAF works. If the super part of it broke, it would operate as a standard MAF - which would tell the LH there is more air than the tune - thus adding more fuel. Just a theory. When you're nursing it home, were you making any boost? Just wondering about BOV? Last thought would be fuel leaking in via vacuum lines from the regulator or dampners?
I am left with three possibilities at this point: LH, MAF, or FPR. The FPR problem could be your idea of fuel leaking to the intake manifold from the fuel pressure regulator vacuum line. I don't think it can be just the FPR vacuum/pressure reference line, because that problem would make it run rich at idle and lean at full throttle and/or boost.
#358
Yes. ;-)
This run had 680+ SAE axle horsepower, but 666 is a cooler number anyway!
Knocks are the only reason to run it rich and retarded. On higher octane gas, the stock long block would make all sorts of power when boosted.
#360
AFAIK the DynaPacks are a locked system like Dynojets.
