gasket - worst luck
#61
Originally Posted by ZEUS+
Good point. Check coolant and oil levels first. If it cranks hard STOP right away.
to correct myself, it's more chocolaty than white.....
oh, by the pictures, there is definately coolent in the oil.....
thanks
#62
I don't know whether your radiator has side tanks for a transmission cooler, but (if you have an automatic) check the transmission fluid level.
WHERE DID YOU ADD THE WATER TO THE RADIATOR??
#63
Under the Lift
Originally Posted by chaadster
Anyway, 9 quarts is too much, by a quart or so. Drain some out.
#64
Originally Posted by juvius
i put some water in the radiator not to waste good coolent, then turned it over a few times.. it started, so i shut it off quick... looked at the dipstick and it looks like every bit of water i put in the radiator is now in the motor... the dipstick level was very high, kinda like twiced the height of full..
Is it not freezing overnight where you are?..............if so you should be using a a/f mix otherwise you may have a split block to repair.
#67
Originally Posted by Giovanni
So the oil is already ruined, drain the oil and remove the oil filter. Add more coolant and see if accumulates in oil pan.
#69
ok good...............can you drain the engine oil into a clean drain pan and look at it closely? If so is it contaminated with antifreeze/water or what?
I dont know how but was there any chance any water/coolant get into the oil filter?
#70
Well, that is the color and texture I was hoping not to see. There were no indications before the oil change ?
i'm really hoping that all it is, is a blown gasket and not a crack head, block and anything else like that.... but.. i would be happier with something simpler... where's the best place to price head gaskets... someone has to have them for less than $300.... after all, it's just a gasket.....
thanks
#71
#72
thanks
#75
928 Int is selling head gskts for $84.
As has been mentioned pressurise the coolant system and do a leakdown test before assuming it is a bad gasket.
Did you confirm what was causing the smoke from under the hood?
