928 Forum 1978-1995
Sponsored by: 928 Specialists
The Twin Screw Thread
Old 01-12-2014, 10:18 PM
  #2446
hans14914
hans14914's Avatar
Shoot me an email tomorrow, and I will try and get it uploaded.
Old 01-14-2014, 11:41 AM
  #2447
PC-85-928S
PC-85-928S's Avatar
trying to convert a DR S4 dual intake set up to a single intake.
anyone ever have a rear intake fabricated, or know where to buy one that would fit an autorotor?
Old 01-14-2014, 01:40 PM
  #2448
hans14914
hans14914's Avatar
Kenne bell used the Autorotor units and rebranded them as their own for many years. They
only recenlty (in the last maybe 4 or so years) have used the HPS instead.
That is the only place you are going to find an off-the-shelf part, perhaps from a 2003-2004 Ford Cobra kit?
You could make one very easily with an inexpensive waterjet flange and two 4.5" OD 90degree mandrel bends. Throw in a bit of mill work to get a locating position for the bends, and a bit of 16g sheet stock, and you would have a very nice piece.
Old 01-14-2014, 09:00 PM
  #2449
Tony
Tony's Avatar
What Hans said...issue with the nice Ford set ups(that i looked at ages ago) is they probably wont fit. The depth is the concern..they will hit the fuel lines on the firewall...or the other "stuff" down there behind the stock intake. You could probably get one, use it for the flange then butcher it and add your own intake shape by fabricating somehting? You want a nice smooth approach to the intake lobes of the rotor assembly....the set up i have is basically a "chamber" and the air is sucked in..not really directed in.
Next time i have it off i think i will fabricate a set of stators to help the air turn into the lobes.
If you have DR's set up with the smaller SC you may be in luck as they are shorter overall?
Old 01-15-2014, 09:53 AM
  #2450
hans14914
hans14914's Avatar
Tony,
I have the flange profile done if that helps you, glad to send you a copy of the file, or can get one cut for you.
Old 01-15-2014, 10:05 AM
  #2451
AO
Supercharged
AO's Avatar
The 1.7l is only about an inch shorter than the 2.1l, but at least that that length comes off on the firewall end.
Tony,
Next time you're up this way, if you're done with the KB intake, I'd like it back. I have a buyer for the KB kit I purchased last year, but I need the intake.
Old 01-19-2014, 04:52 PM
  #2452
PC-85-928S
PC-85-928S's Avatar
Default DR Intake question
Working on a DR intake that has the supercharger bolted on from the inside of the manifold.
Was attempting to open the manifold to upgrade to a larger supercharger.
After using carb cleaner to remove the right stuff, it seems like there are small spot welds on the inside.
Is this possible?
Has anyone ever run into this before?
Old 01-19-2014, 05:11 PM
  #2453
AO
Supercharged
AO's Avatar
Mine had some spot welds, but they had failed by the time I got in there. When I resealed it I used some black permatex to seal it... Holy crap that stuff is strong.
You might need to get in there with a dremel or a small rotary shaft tool to break the welds, but there will be a few locations where you cannot reach.
Heres the pic from my SCer thread. You can see where some of the welds were on mine. Next time, I'm going to use a different method to seal things.
Old 01-19-2014, 05:25 PM
  #2454
elgreco
elgreco's Avatar
Great thank you. I think I am going to stay with the original plan. Just instal it as is with the 1.7 l unit. Once I get the dual inlet back from Hans ill start to put things together.
Old 01-27-2014, 04:52 PM
  #2455
PC-85-928S
PC-85-928S's Avatar
Default ANDY KEEL MANUAL
anyone have a copy of Andy Keel install instructions?
Old 01-27-2014, 06:53 PM
  #2456
85euro928
85euro928's Avatar
Patrick,
See my PM.
Old 01-27-2014, 10:17 PM
  #2457
Rick Carter
Rick Carter's Avatar
I have it in a 35 page word document. PM your email and I'll send it as an attachment. If anyone would like to host it, I'll send it to you.
Old 02-01-2014, 05:39 PM
  #2458
PC-85-928S
PC-85-928S's Avatar
Question Intake
Rick-
What intake are you using?
It looks like the throttle body mounts right to it.
Usually single intake is on passenger side, yours in on drivers side.
I noticed you moved your power steering res.
What size supercharger?
Old 07-29-2014, 02:08 PM
  #2459
hans14914
hans14914's Avatar
Anyone need a spare 1.7L autorotor?
Old 07-29-2014, 03:04 PM
  #2460
Rick Carter
For free? :-)
Quick Reply: The Twin Screw Thread
