Project V8- VT951's Bitchin' Camaro
Old 02-05-2010, 07:51 PM
  #46
lovemyp-car
lovemyp-car's Avatar
Originally Posted by xsboost90
believe me- an LS1>LT1 all day. Intake is much shorter to clear hood and power output is much easier to make.
i agree, the ls1 block is technologically advanced and a better engine overall. I also think you're probably right with the intake being shorter...but power output i don't know about, i guess at this point ls1 mods are starting to pop up in full force...but the LT has extensive mods available since many of the sbc mods will fit it.
for me, there really was no choice. the only ls1's i found were selling at upwards of 2K for a stock engine...part of the senior project i wanted to do was to build an engine, so i bought a torn down LT1 block for 400 bucks, and put the rest of the money into mods like are listed in my sig, as well as into parts needed for the conversion.
I was able to get away with only about 3K in the conversion overall (not including the trans i still need to replace or the paint i sprayed on it this summer etc) so i'm happy with it. It was definitely a learning experience and i think an LS swap would be much easier because of the wealth of info that gt1 (greg) and the admin over at 944hybrids have come up with and shared with all of us. For the LT, a lot of it was trial and error.
Let's just say that you guys are doing the right swap at the right time!
Good luck!
Old 02-05-2010, 08:38 PM
  #47
marky522
marky522's Avatar
well as far as clearing the crossmember you should never shim it out from the frame. We just bought an aftermarket oil pan w/ better clearance and the LS motors dont have issues clearing the hood. Rack sits in the factory location.
I am going to sit by and want to see this, because just about every swap i have seen required either shimming the crossmember from the body, or modifiying the hood. I used the Moroso pan, but didnt notch it, it wasnt necessary with the rack mounts no longer protruding above the crossmember. I am using the uprights from XSChop, with the engine sitting as low as it can I had to mount my t-body upside down to clear my hood. There is very little room between my oilpan and the crossmember on my setup, so i am interested to see your solution. Have you set the engine in place yet?
Mark
Old 02-05-2010, 09:07 PM
  #48
lovemyp-car
remember...no 944 is the same, they all are slightly different in frame, crossmember and body, so some people have very few problems with a notched oil pan, others will have to drop the crossmember over an inch and notch the pan, as well as remove or dent in the hood support to make the engine fit...so it is not necessarily what you do, but what you car is.
Old 02-05-2010, 09:25 PM
  #49
968ls1
968ls1's Avatar
Thanks for the kind works guys; I enjoy helping with the conversions and hopefully I can save you some time and $$.
Greg that picture of Pat's engine was 5 years ago right when I finished the conversion, it was really detailed and sano!. I can't wait to get yoor firewall plate and fix my trouble. Alan's swap will allow the engine to sit low due to the smaller diameter of the manual rack, the reinforcement on the back of the hood will have to be trimmed and the throttle body will be relieved for clearance. Making the uprights as shodt as possible and "fitting" the pan around the rack and x-member is crucial for getting all the clearance. If you must shim staying less than 8mm will not have a negative effect on the geometry. I met with a guy today who is doing a custom hood to clear his new FAST intake on his 951-I will keep you posted on the progress this could solve the clearance issues on the 944 LS1 conversions.
Old 02-05-2010, 09:42 PM
  #50
marky522
marky522's Avatar
Ok, that makes more sence. Thanks for that info. I was hoping i didnt cut up that crossmember for no reason...
Old 02-06-2010, 12:13 AM
  #51
Rock
Lazer Beam Shooter
Rock's Avatar
Xsboost= Unrivaled
Old 02-08-2010, 03:46 PM
  #52
SamGrant951
SamGrant951's Avatar
So is it finished and running yet?
Old 02-08-2010, 05:06 PM
  #53
ritzblitz
ritzblitz's Avatar
Originally Posted by Rogue_Ant
Lol, yeah my mother could design a better motor.
Can I your mom my NA?
Old 02-08-2010, 07:52 PM
  #54
xsboost90
xsboost90's Avatar
not even close to running yet- may be able to fit the motor this week and make the engine mounts though.
Old 02-10-2010, 01:33 PM
  #55
Darth Coupe
Darth Coupe's Avatar
Awesome guys! I hope to see it at Mid-OH this spring!
Old 02-10-2010, 01:37 PM
  #56
V2Rocket
Rainman
V2Rocket's Avatar
brb robbing bank to buy LS2
Old 02-10-2010, 02:35 PM
  #57
pjburges
pjburges's Avatar
Thats some incriminating evidence V2.... lol
Old 02-10-2010, 03:16 PM
  #58
originalmotorhead
originalmotorhead's Avatar
Buying my Lotto ticket get my money the old fashon'd way :P
Tom
Old 02-10-2010, 04:04 PM
  #59
roman944
roman944's Avatar
can I be the driver
good thread, I'm giving this V8 thing a 2nd thought; there's plenty of people here into V8's and stuff and a few people who have swapped LS1's into RX-7's - so I could get a hand or two if I needed it; looks like Renegade kit is only $2k (probably a little more with some other extra parts) - biggest problem would be locating a cheap LSx ... not sure I should even be using "cheap" ...
Old 02-10-2010, 04:28 PM
  #60
jimbo93
jimbo93's Avatar
A 5.3L truck engine can be had for about $500 to $800 depending on what is included, swap out the intake manifold, headers, and oil pan you have an LS1 for a lot less money. And with the iron block the engine supposedly can handle more power
Quick Reply: Project V8- VT951's Bitchin' Camaro
