PDLS+ Availability Discussion
#286
It seems so - doesn't look like you can choose the Black BI-Xenons with PDLS on the GT4RS for some reason.
#287
^^ It was on my original build but when I was playing with it yesterday, they disappeared.
On the build photo, it depicts them as a black housing?
http://www.porsche-code.com/PPHVXFD7
#288
Bose shows up as a stand alone option in the configurator
nikuhina (08-16-2022)
#290
I hope they're keeping the supply chains up for damaged or failed headlights. Would suck if it took 6 months to repair an accident because headlight unavailable.
#292
Not just an accident. The entire assembly needs to be replaced if a LED goes. Or some electronic element built into the lamp. Apparently the only serviceable/replaceable part is the cooling fan on the LED assemblies.
Richardkun (08-18-2022)
#293
Jerry Seinfeld fix for missing PDLS+
#294
Just an update to my own question earlier, I got an update from my SA. He was able to add on PDLS to my gt4 order even though my build was locked on 7/20. Doesn't seem to have affected my delivery date either.
The following 2 users liked this post by vtplm:
Chrismalberts (08-20-2022),
UncleDude (08-19-2022)
#295
#296
In North America, do the GTS PDLS standard lights come with the headlight cleaning system or is that only on PDLS+? The standard lighting specs for GTS on configurator do not say they have the cleaning system and I only remember seeing this when adding PDLS+. Need to know if I still get painted covers.
6IXSPD (08-22-2022)
#297
PDLS does come with a headlight cleaning system.
#298
Yeah strangely the configurator doesn’t show the washer nozzles on standard PDLS, nor makes any mention of it.
#299
Revised config includes BOSE
Am currently V200 with an October 7 lock date (CGTS 4.0, MT). I just received my updated Build Sheet and, as expected, the Premium Package no longer includes PDLS+ or BOSE sound system. The price for Premium Package has been reduced from CAD$4100 to CAD$2250.
Somewhat surprisingly, the BOSE is still in the new build, as a standalone option priced at $1130, way less expensive than the $5400 Burmeister option that I thought I was being forced into.
So, my build cost has been reduced by $720 when all is said and done, certainly less than the value of PDLS+, but I’ll be happy if this configuration locks in 2 weeks!
#300
