718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
OEM Navigation Retrofit DIY
Old 07-03-2024, 11:24 AM
  #961
718socal
718socal's Avatar
Originally Posted by JGGPilot
If there is anything I can help me, let me know! I can send you my phone number on PM as well! Thank you 718SoCal!
Appreciate it 👍 PM me
Old 07-03-2024, 11:30 AM
  #962
JGGPilot
5th Gear
JGGPilot's Avatar
just tried, ain't letting me. I'm new here maybe I don't have the privilege just yet.
Old 07-03-2024, 12:32 PM
  #963
718socal
718socal's Avatar
Just PM’ed you
Old 07-03-2024, 05:51 PM
  #964
6IXSPD
6IXSPD's Avatar
Hey folks, so is this still doable on a 2023 718? I read there were some PCM version compatability issues...
Old 07-03-2024, 05:53 PM
  #965
718socal
718socal's Avatar
2023 should be good 👍. Post a screenshot of your PCM version here to be sure.
Old 07-04-2024, 08:11 PM
  #966
kwazi7
kwazi7's Avatar
Just PM’ed you
I eagerly await the results of this :-)
I'd offer to help but unfortunately, I don't have my car yet.
718socal (07-04-2024)
Old 07-09-2024, 12:36 AM
  #967
Ken968
Ken968's Avatar
I want to add android auto only. Car has nav already. Will this method work?
Old 07-09-2024, 01:09 AM
  #968
718socal
718socal's Avatar
You can't because you have the latest firmware with Hardware Version 60. You have the CD less PCM 😣. You can use an adapter to add AA for now..
The following 2 users liked this post by 718socal:
Mike981S (07-09-2024), pgap718 (07-15-2024)
Old 07-09-2024, 09:01 AM
  #969
Ken968
Ken968's Avatar
Thanks for the response. I was hoping I could use this method again, it worked perfectly on my previous 718. Is there a preferred Android auto adapter currently?
Ken
Old 07-09-2024, 10:35 AM
  #970
Westcoast
Westcoast's Avatar
Received 4,670 Likes on 2,717 Posts
Ken
As yours should already have Car Play activated (?) I would recommend what I use, the Carlinkit 4.0, This adapter gives you wireless CP/AA with a physical USB connection to a wired CP enabled head unit.
Amazon.com: CarlinKit 4.0 CP2A Adapter for Wired CarPlay Car, 2 in 1-Convert Wired CarPlay to Wireless,Wired CarPlay to Wireless Android Auto(for Android 10+) : Electronics Amazon.com: CarlinKit 4.0 CP2A Adapter for Wired CarPlay Car, 2 in 1-Convert Wired CarPlay to Wireless,Wired CarPlay to Wireless Android Auto(for Android 10+) : Electronics
Old 07-09-2024, 10:45 AM
  #971
Ken968
Ken968's Avatar
Thanks I actually already have one of those which I used in my first 718. I'm not sure if they changed the interface or something but when I connect my phone via USB I don't see the android auto option appear on the PCM screen like it did previously. This made me think the car is not enabled with AA. Maybe I'm missing something??
Ken
Old 07-09-2024, 10:49 AM
  #972
Westcoast
Westcoast's Avatar
Ken
Cool, you should be there then, the Carlinkit 4.0 connects and looks like CP to the head unit, when you connect your phone to Carlinkit 4 and it is USB connected to the PCM you will see a selection for Car Play, choose that and it should give you AA on the PCM. I don't see an AA icon, only a CP icon, choose that.
I have the Carlinkit 4.0 connected to my 718, you have the same version?
Old 07-09-2024, 12:05 PM
  #973
Ken968
Ken968's Avatar
I have the Carlink 5.0, and on my previous car there was an Icon that I selected on the PCM home screen that launched android auto. So far I haven't seen that on my current car. I will have to keep playing with it I suppose. So far I haven't even been able to get AA even with the phone connected via the arm rest USB or the glove box USB. Thanks for the suggestions
Ken
Old 07-09-2024, 12:23 PM
  #974
Westcoast
Westcoast's Avatar
Ken
Ahhh, I figured as much, as your PCM does not have wired AA enabled therefore Carlinkit 5.0 will not provide AA connectivity.
There are definite differences between the Carlinkit 4.0 and 5.0:
The following 2 users liked this post by Westcoast:
718socal (07-09-2024), Mike981S (07-09-2024)
Old 07-09-2024, 09:21 PM
  #975
Mike981S
Mike981S's Avatar
I second @Westcoast 's suggestion. I used
Carlinkit 4 Carlinkit 4
in my GT4RS during EuroDelivery (using a USB cable) and it worked reasonably well. 5 will NOT work. Another one I have seen people use is one of the
Ottocast Ottocast
adapters (not sure which one).
The following 2 users liked this post by Mike981S:
718socal (07-10-2024), Westcoast (07-10-2024)
Quick Reply: OEM Navigation Retrofit DIY
