718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
OEM Navigation Retrofit DIY
Old 07-09-2022 | 08:20 PM
  #76
arne's Avatar
arne
Speaking of the "latest method", I'm assuming that once Nav, CP and AA is activated that there is no real reason to "update" by doing it again with a later MIB build. Correct?
Old 07-09-2022 | 08:27 PM
  #77
Westcoast's Avatar
Westcoast
For the most part you could say "if it is working as you need it, no need to touch".
What the AIO also does is update the PCM firmware to: MHI2_US_POG11_K5186_1
Old 07-09-2022 | 08:46 PM
  #78
sgreer78's Avatar
sgreer78
Originally Posted by Westcoast
Great to hear it worked out!
By the sounds of it you didn't use the latest method?
I don't know what the latest method is. I just used the one detailed in this DIY.
Old 07-09-2022 | 08:55 PM
  #79
718socal's Avatar
718socal
You did it the hard way 😁. AIO is a lot easier. I am glad that it is working for you 👍
sgreer78 (07-09-2022)
Old 07-09-2022 | 09:06 PM
  #80
CaneTLOTW's Avatar
CaneTLOTW
Latest would be this: https://mibwiki.one/share/30b7c0f9-a...1-20f4309ef4bb
FW update magically doing all the patching and more during install.
And yes, it even starts to install automatically after putting SD into unit
The following 4 users liked this post by CaneTLOTW:
718socal (07-09-2022), Larry Cable (12-28-2022), sgreer78 (07-09-2022), Z06jerry (07-20-2022)
Old 07-09-2022 | 09:34 PM
  #81
sgreer78's Avatar
sgreer78
Is it worth going ahead and doing that on top of what I did the "hard way"?
also, Reading the link above, I’m guessing since my Bose still has audio I didn’t break anything?
TXshaggy (07-09-2022)
Old 07-09-2022 | 10:07 PM
  #82
Westcoast's Avatar
Westcoast
Essentially if you run AIO now all you will be doing is updating the firmware of the PCM, functionality stays the same.
As for BOSE unless you make changes to the AIO file it will not touch the BOSE system.
Old 07-09-2022 | 10:23 PM
  #83
sgreer78's Avatar
sgreer78
ok, last dumb question. is there any benefit to updating? any improvements?
also I'd really love to find that download speed fix thing. the link is dead in the link above.
thanks
Old 07-10-2022 | 01:41 PM
  #84
Westcoast's Avatar
Westcoast
thanks
All electronic manufactures that use firmware will release updates for bug fixes and improvements, sometimes there are functional changes other times not. I don't have the release notes for changes between versions so I can't tell you what the firmware changed.
Download speed fix?
Old 07-10-2022 | 01:46 PM
  #85
sgreer78's Avatar
sgreer78
Download speed fix?
On the page above it said there was something to help with DL speed of the maps. I tried to 8 hours yesterday to get the maps, only made it to 5gb before it just quit.
Old 07-10-2022 | 02:23 PM
  #86
Westcoast's Avatar
Westcoast
Ahh yes, I messed with that a bit but doing it the hard way (trying to copy the URL and add it). So I downloaded and installed the Download manager, added the browser extension to Edge... on the MIB download section of interest simply highlight the file of choice and then hit the download button, the Download manager will resolve the URL and automatically add it to the managed list.
sgreer78 (07-10-2022)
Old 07-10-2022 | 02:44 PM
  #87
CaneTLOTW's Avatar
CaneTLOTW
Link to the manual for download manager:
https://mibwiki.one/share/99dda9a7-0...f-2ea7e0eb18cb
Old 07-10-2022 | 02:46 PM
  #88
CaneTLOTW's Avatar
CaneTLOTW
There are no official change list for FW updates.
General functionality is the same.
More like nice to have if everything is working fine for you as it is.
Old 07-10-2022 | 03:14 PM
  #89
sgreer78's Avatar
sgreer78
Thanks for all of this. I got the manager working in my extensions in Chrome. And yes, everything is working fine for me now so I'll not mess with it.
Old 07-10-2022 | 04:54 PM
  #90
718socal's Avatar
718socal
Did you install the maps?
Quick Reply: OEM Navigation Retrofit DIY
