718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
PIWIS 3 Coding Retrofit and Feature Request
Old 06-16-2024, 06:56 AM
  #1066
Jonathan_987
Jonathan_987's Avatar
I have found a way to deactivate the shift recommendation in the instrument cluster. This results in a new menu item under settings (display) with which you can toggle on and off.
The following 2 users liked this post by Jonathan_987:
MrFunk (06-16-2024), TubaFreak (06-16-2024)
Old 06-16-2024, 01:24 PM
  #1067
718socal
718socal's Avatar
Great find 👍
Old 06-25-2024, 01:50 PM
  #1068
skiddmcmarx
skiddmcmarx's Avatar
Originally Posted by 718socal
Another great feature for Boxster owners, Open or close the Convertible top with the remote key.
Was this on a 718 or a 981? Did it actually function for you on a US car? I keep reading so many conflicting posts, I'm not even sure if it is feasible. I feel like I have tried every option imaginable, including the ones shown here. It looks like the comfort top by remote options don't stay coded on. The windows function up/down via the remote as per the codes selected, but the top does not. I'm on a 981 Boxster.
Thanks for the help!
Old 06-25-2024, 02:16 PM
  #1069
AdamIsAdam
AdamIsAdam's Avatar
Received 3,967 Likes on 1,719 Posts
He was able to do it on my 981 Boxster!
718socal (06-25-2024)
Old 06-25-2024, 02:19 PM
  #1070
718socal
718socal's Avatar
Adam is correct. There were a few different settings changed. I can only see those when I am connected to the car.
Old 06-25-2024, 02:31 PM
  #1071
skiddmcmarx
I’m on a 2015 981 US Car with a PIWIS II- would that be why? I’ve selected every option you have shown and still to no avail. Any other tips?
Old 06-25-2024, 02:36 PM
  #1072
718socal
718socal's Avatar
Sorry but I am not familiar with PIWIS 2. It should technically work on PIWIS 2. I can code this remotely for you just like Adam
Old 06-25-2024, 02:39 PM
  #1073
skiddmcmarx
As much as I would love to figure it out, I’m game for that. That’s basically the main reason I purchased the PIWIS lol. I do not want to install the smart top module if I don’t have to.
thanks!
Old 06-25-2024, 02:41 PM
  #1074
718socal
718socal's Avatar
thanks!
If you decide to code remotely, you can scan your car with your PIWIS 2 and look at what changed. I just did not have enough time to document this because we were coding three cars that day. PM me
Old 06-25-2024, 02:49 PM
  #1075
skiddmcmarx
PM Sent. Where’s the easiest section to view changes made? Still figuring out the dev mode.
thanks
Old 06-25-2024, 03:28 PM
  #1076
718socal
718socal's Avatar
thanks
Not familiar with PIWIS 2. In PIWIS 3 go to Coding /Programming then Manual Code.
Old 06-25-2024, 08:57 PM
  #1077
skiddmcmarx
Turns out I over complicated it; if you only activate the options specifically from https://rennlist.com/forums/718-gts-...l#post18311530 then you'll get the proper operation of the top.
The windows were a different story. Currently my windows go all the way up when closing the top with the remote, but stop a 3/4 up when opening the top with the remote. I have changed a few options, but I will link the exact options on here for anyone that's interested. Obviously once I figure it out.
Thanks, 718socal for the assist!
downshifted (06-26-2024)
Old 06-25-2024, 09:02 PM
  #1078
AdamIsAdam
AdamIsAdam's Avatar
Windows can be programmed to fully close once top is closed with remote. They cannot come all the way down with opening the top however. Less of a concern.
Old 06-25-2024, 09:07 PM
  #1079
718socal
718socal's Avatar
Glad I could assist. You should also post this in the 981 forum too 👍
AdamIsAdam (06-25-2024)
Old 06-25-2024, 09:15 PM
  #1080
AdamIsAdam
AdamIsAdam's Avatar
I posted it somewhere there.
Quick Reply: PIWIS 3 Coding Retrofit and Feature Request
