718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
PIWIS 3 Coding Retrofit and Feature Request
Old 08-19-2022, 03:22 PM
  #91
Westcoast
Westcoast's Avatar
Received 4,647 Likes on 2,708 Posts
Originally Posted by 718socal
Now you can try to code your car with this. FYI you can’t have the coding for Windows UP/DOWN from the remote. They are mutually exclusive. It’s one or the other 🥲
Years (and a few cars) ago I bought a SmartTop module so I have this functionality in the Spyder now, not only the ability latch the top from the outside but remote windows as well.
Mike981S (01-25-2024)
Old 08-19-2022, 04:14 PM
  #92
718socal
718socal's Avatar
So on your car, you can release/lock the latch from your remote. That's pretty cool.
Old 08-19-2022, 04:21 PM
  #93
718socal
718socal's Avatar
Originally Posted by derek tacos
Is there a way to make the interior console buttons that control the top single press as opposed to hold?
also, is there anyway to enable vim through piwis?
It’s easier to enable VIM from GEM AIO. I really haven’t looked at the One Touch feature. It might be a bit different from BMW coding where you have the option to program One Touch button
Old 08-19-2022, 04:26 PM
  #94
daaa nope
daaa nope's Avatar
^^^ what the heck is that?
Never seen that menu before. GEM AIO??
Old 08-19-2022, 04:30 PM
  #95
718socal
718socal's Avatar
Video in motion. I never use it but it allows you to play video while driving. It’s in the submenu in AIO
Old 08-19-2022, 04:31 PM
  #96
daaa nope
daaa nope's Avatar
AIO - so I thought that was just for Android stuff?
Looks like you can also do coding with it?
Maybe this was covered in this thread already and I missed it based on the Android assumption (I'm an Apple user)
Old 08-19-2022, 04:36 PM
  #97
718socal
718socal's Avatar
Yes, you can code VIM. All In One is for both CP and AA. I am an Apple user too 😀
Old 08-19-2022, 04:42 PM
  #98
Westcoast
Westcoast's Avatar
Yes, the SmartTop interprets specific key presses on the remote and sends the appropriate signals via the CANBUS to the module(s) in question.
When opening or closing the top on the Spyder (or a Boxster) you can set the windows to be up or down at the end of either operation. Remote operation of the windows themselves alone are a different key sequence.
718socal (08-19-2022)
Old 08-19-2022, 04:50 PM
  #99
718socal
718socal's Avatar
I have that on my truck, it can be very handy! I suspect that this would be a no-go on my 6MT Spyder.
Remote Start was available on my previous BMW MT car via remote key and Phone app. I think it checked if your shifter was in gear and E-brake was not released.
Old 08-19-2022, 05:52 PM
  #100
Z06jerry
Z06jerry's Avatar
With PIWIS you can code windows up or windows down at the end of the top opening sequence (I chose the default windows up). The windows will then close after top up unless you release the key early which will leave the windows partial down 1"- 6" depending on when you released the key. You can continue to close the window as much as desired by pressing lock again hence you can leave the windows open a bit on hot days with the car locked.
Old 08-19-2022, 06:12 PM
  #101
Westcoast
Westcoast's Avatar
Very similar results then, to be expected because the SmartTop is actually sending factory sequences to the modules. One small difference with the SmartTop is that during top operation is the the windows up/down is selectable from the remote fob as desired.
The following 2 users liked this post by Westcoast:
718socal (08-19-2022), Z06jerry (08-19-2022)
Old 08-20-2022, 06:20 PM
  #102
718socal
718socal's Avatar
Has anyone tried to put their car in Dyno Mode with PIWIS?
Old 08-20-2022, 06:24 PM
  #103
Westcoast
Westcoast's Avatar
Anything with "uber" in the description has be be worth a try!
718socal (08-20-2022)
Old 08-21-2022, 09:02 AM
  #104
Z06jerry
Z06jerry's Avatar
Looks like the settings a service tech could choose before a 2 wheel or 4 wheel dyno pull, maybe?
Old 08-21-2022, 01:14 PM
  #105
Z06jerry
Z06jerry's Avatar
Default feature request - rear taillights always on
for those of us who have coded the dash lights always on (white dials) it would also be nice to activate the rear tail lights to always on too, in the event the headlight switch is "off" at dusk or other instances of poor visibility from behind. (fog, rain etc). I've coded both my other cars (VW & Audi) to work this way. Some Scandinavian countries require it.
On VW the coding reads as follows;
Tagfahrlicht-Dauerfahrlicht aktiviert zusartzlich Standlicht -> “active”
Daytime running light activates additional parking light -> "active"
drive95 (08-22-2023)
Quick Reply: PIWIS 3 Coding Retrofit and Feature Request
