718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
PIWIS 3 Coding Retrofit and Feature Request
Old 11-23-2022 | 12:46 PM
  #151
rnlst_log's Avatar
rnlst_log
[QUOTE=Baggerdude;18464278]"PIWIS needs to be in Engineering and not V diagnostic mode to code the cluster. By default the AC is always ON on my car. If you have the memory seats, I think it remembers the last setting with your memory button and key"
Thanks, Socal718 ... appreciate your help. I'll pass this along. I think they were in the Engineering mode. Perhaps there is something they were missing. I'll see if they can try again.
[/QUOTE
I bet their E mode will not have the manual coding values.
718socal (11-23-2022)
Old 11-23-2022 | 01:23 PM
  #152
Z06jerry's Avatar
Z06jerry
Originally Posted by John Mclane
I managed to activate closing the top with the fob, which is available in most of the world but 'merica.
In the same page, comfort windows up and down. If you try to activate both the top and windows comfort access on the Spyder, the latter will work as they share the key fob (press and hold open or close doors). Useful for who prefers windows rather than the top or cayman users..
Nice, now Spyder owners can enable latch/unlatch of the top from outside the car. With the help of @718socal we saw that Spyder coding when coding my BGTS 4.0's convertible top to operate from the key-fob, now you've confirmed that key-fob latching can be coded for the Spyder. FWIW, The Boxster' Comfort Windows and Comfort Top are also mutually exclusive but my windows will still fully close at the end of the cycle and partially open at the beginning so the windows have useful functionality when top coding is chosen. Also one can choose the windows closed or open at the end of the opening cycle. @John Mclane do the Spyder widows operate the same way?
Old 11-23-2022 | 01:42 PM
  #153
John Mclane's Avatar
John Mclane
They open and close a little bit when operating the top. When I left the windows and top comfort setting on, only the latter worked. I think the former is more useful so I changed it back. Being able to finish the closing with the fob instead of going in the car (specially w/ bucket seats) is so simple yet so convenient.
The following 2 users liked this post by John Mclane:
718socal (11-23-2022), Z06jerry (11-23-2022)
Old 11-23-2022 | 03:20 PM
  #154
718socal's Avatar
718socal
Attachment 1332579Attachment 1332580
I also found a line that implies the OPF is monitored on this car (23 Spyder). Could someone compare with prior American non-monitored cars (20-22)?
Attachment 1332578
Tried wireless CarPlay activation. Turned in 5ghz but made no difference. It could be hardware related as others reported.
I am glad that you were able to code your Spyder. The Wireless CP is not available because there is no 5ghz on PCM4. I use the Carlink adapter for Wireless CP
Old 11-23-2022 | 03:22 PM
  #155
718socal's Avatar
718socal
[QUOTE=rnlst_log;18479554]
[/QUOTE
Anyone who needs PIWIS should talk to @rnlst_log
Old 11-23-2022 | 03:55 PM
  #156
John Mclane
That's the conclusion I got to, thanks for confirming. It seems that the interface on the 982 is simpler than the 992. I failed more than succeed on that one. The spyder doesn't have a lot I can code anyways. No front camera, parking sensors, seat memory... It does have this loud thing behind my seat that leaves me smiling and with concentration problems during the day (thinking when I'm getting back to it).
Old 11-23-2022 | 05:13 PM
  #157
718socal's Avatar
718socal
Attachment 1332578
I have the same setting on my 2021 CGTS. This is just the OPF fault warning in the cluster. I would think that any change to the OPF would be in the DME.
There is also the VO for specific exhaust
Old 11-23-2022 | 05:17 PM
  #158
John Mclane
Awesome, thanks for checking. To the Shops!!!!!!!
Old 11-23-2022 | 05:27 PM
  #159
718socal's Avatar
718socal
Congrats on your new car.
Old 11-23-2022 | 05:30 PM
  #160
John Mclane
Thanks! Fluke weather in Chicago allowing for Dunlop tire drives. I might mount winters just to keep on driving.
Old 11-23-2022 | 08:00 PM
  #161
Westcoast's Avatar
Westcoast
I am not an iPhone user, but I thought that they could use 2.5Ghz for wireless Car Play?
Old 11-23-2022 | 08:21 PM
  #162
John Mclane
Back to the drawing board. I can get the top to latch back by using the lock button on the fob, but the windows don't finish going up. I think one of the settings need to allow for that as well .
To the cold garage w/ Google translate...
Old 11-23-2022 | 08:25 PM
  #163
Westcoast's Avatar
Westcoast
Did you see @Z06jerry Post #152 above?
PIWIS 3 Coding Retrofit and Feature Request - Page 11 - Rennlist - Porsche Discussion Forums
Old 11-23-2022 | 10:21 PM
  #164
John Mclane
Found this and will testName:  photo340.jpg
Size:  1.39 MBName:  photo239.jpg
Edit --> it worked!
Old 11-23-2022 | 10:32 PM
  #165
718socal's Avatar
718socal
From Apple documentation.
Quick Reply: PIWIS 3 Coding Retrofit and Feature Request
