C40 Oil Discussion
#496
Yeah, that is what I meant.
Not saying it had anything to do with it, just saying maybe they made some behind the scenes changes when going thru that process.
#497
They make changes/improvements all of the way along, to change the specification for the oil weight for might be the same engine in a 2019-2021 as compared to a 2022+ is curious though...
#498
Not saying it is related in anyway, but maybe the 2022 change had something to do with the investigation from the 2021 CAM RON recall and stop sell? Just throwing out ideas.
We know that the PCCB brake pads (and probably the steel pads as well) were quietly changed for 2022. I am sure there are a bunch of 2022 changes that happened that were not publicized.
Forget what the OM says, it mis identifies the oil fill location.
Porsche updates it’s C40 certified oils couple times a year.
#499
However this updated version of the ENU 1701 document make a definite distinction about the use of 0W oil in a specific model year.
#500
Hmmm, actually the way I read the ENU 1701 that you posted it does differentiate between model years, it specifically states up to MY2020 and for that 5W and 0W are acceptable, it says nothing in that document about this applying to 2021 and 2022 cars.
However, I neglecting to see the lower caveat “from MY21 onward 0W…only”
Lastly that caveat applies to all MY21s forward that use C40 and not targeted at 718.
Good stuff, think we now have the correct technical answer after 500 posts.
Westcoast (03-19-2022)
#501
Same experience here. I had no problem getting C40 from Hennessy in Roswell, Ga the one time I needed it before my annual service @ 4,100 miles. My Autozone in Alpharetta has the same end cap display as previously posted and it also won’t scan as being in inventory.
#502
Yesterday was a beautiful morning, and I eventually got all 9 quarts of the coveted Mobil-1 ESP X3 0W-40 oil - after visiting *FIVE* different Autozone stores. I first hit the two stores that were closest to my house with zero luck. Then I just set Waze to take me to the next one a town away, and I scored 6 quarts there (first time seeing the end-cap for this particular oil). Nothing at store four, but store five had the full display again. So it's definitely not something that every Autozone has (yet), but hopefully they'll eventually get to all stores.
Like others have said, there was a spot for 5-liter jugs, but none on the shelf in the 0W-40 rating at the two stores that had the end-caps. And the 1-quart bottles did not scan at the register, but I was prepared for that with a photo of the price/UPC barcode from the end cap display.
All in all, it was a beautiful morning for a scavenger hunt, cruising some twisty back-roads through farm country with the exhaust valves wired open!
The following 4 users liked this post by slilley:
#503
The change to a 5w instead of a 0w goes along with what I've been recommending for almost 20 years :-)
AdamIsAdam (03-21-2022)
#504
I have a 2020 and felt that the 5W-40 oil would be a great summer oil.
#505
Unless you live in the Arctic Circle and start your car up well below 0F on a daily basis, there is no need for a 0w. So yes, you should be good with a 5w40 C40 oil for the street.
The following 2 users liked this post by Charles Navarro:
AdamIsAdam (03-21-2022),
Westcoast (03-21-2022)
#506
Also in the 992 GT3 (and likely in the GT4 RS), you can only drain half the oil on a normal oil change. Do you have any thoughts on the consequences of that and what an owner might do to maximize engine longevity (change oil more frequently than recommended, perhaps?)?
Thanks!
#507
Do you have any opinion about any risk to warranty by using 5W40 in the 2022 models and later that require specifically 0W40 C40 oil? Do you have any insight about why it may be exclusively specified (emissions or fuel economy, perhaps?)?
Thanks!
Thanks!
If concerned about your warranty, I would recommend cutting oil change intervals in half and once the warranty is up, there will for sure be plenty of choices for a 5w40 C40/VW 511 oil or you could run Driven's DI40, which is their equivalent. That's what I personally run in my direct injected vehicles.
#509
Back then when oil technology was not what it is today.
All that just to get to one statement prof Butler made (I think it was him- don’t get old): most engine wear occurs at start-up/warm-up.
I wonder if that is still true; 0w-xx/ or 5w-xx oil weights was not in existence then.
#510
Its been 35+ since my intro to engine design with part time professor Butler (MSU). He was on the rocket 88 engine team (1950s) when crank shafts started snapping in the Michigan UP in the winter. Some Mech Engr didn’t specify fillet reliefs on the crank shaft machining drawing; cold temps plus stress risers/fatigue led to premature failed shafts at engine start-up.
I'm not concerned with a 5w40 in sub zero F starts. I did used oil analysis years ago to measure wear in the winter vs summer and there was a negligible difference in wear, even with repeated starts down to -20F. What I did discover on cars driven in the winter is shorter drain intervals, sometimes as short as 3 months and 3,000 mi. Fuel dilution and also moisture content goes way up unless the car gets driven long distances with the oil temps above 215F for an extended period.
The following 3 users liked this post by Charles Navarro:
