718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
C40 Oil Discussion
Old 12-22-2020, 09:41 AM
  #136
mjw930
mjw930's Avatar
Originally Posted by theEnd
I just picked up my Spyder from its 10,000 mile / 6 month servicing. The dealer used Mobil 1 A40 for the oil change. I'm still waiting for them to tell me why they didn't use C40, and what should be done about it.
Originally Posted by Westcoast
Wow, that is not good, probably not the end of the world but still astounding when the C40 spec oil is available in their parts system and indeed online as well! Especially considering that C40 oil has been out for a couple of years now...
This is not surprising to me, it was more of a surprise was some of the aggressive pushback I got here when I suggested the bulk of NA dealers were simply pumping the standard NA version of Mobil 1 A40 into our cars. I called 3 dealers near me just to check and got a fairly consistent response that, at least at the parts counter, they care about the viscosity numbers and are ignorant of certifications. One even argued that all that 0W-40 Mobil 1 European formula was the requirements and the C40/A40 discussion was pure marketing...... Needless to say I won't be using them as a servicing dealer (it's not where I'm buying my Spyder from anyway). One did recognize the difference but to date (since 2019 when the standard was introduced) he's only had 1 customer ask and he was using it in his Cup car. The 3rd dealer didn't know what oil was on his shelf but pulled a bottle while we were on the phone and low and behold it was the C40 version. Had I not asked he wouldn't have known.
But the reality is we here are the minority, I suspect 80% of their customers simply don't care and quite honestly it won't be a problem. Oil related failures are so rare now that these discussions are really academic. 10 years from now on a tear down I'd hazard a guess that even the best trained engine guy couldn't differentiate between the car with a 100% C40 diet vs. an A40 diet.
minn19 (12-22-2020)
Old 12-22-2020, 10:15 AM
  #137
fueledbymetal
fueledbymetal's Avatar
Originally Posted by lovetoturn
For those that may want even further reading on the A40 vs C40 debate, here is another thread to look at from last year.
https://rennlist.com/forums/718-foru...tor-oil-4.html
That's from last year. I'm sticking with the latest guidance for FY21+ cars:
Old 12-22-2020, 10:35 AM
  #138
minn19
minn19's Avatar
I love the last line, "take it to the dealer for oil changes until".................................they have C40 as well and until then, they will change with the A40 spec.
Old 12-22-2020, 10:38 AM
  #139
mjw930
mjw930's Avatar
Not to be a smart *** but you may wish to stick to the guidance for FY21+ cars but if your servicing dealer is unwilling or unable to provide C40 spec oil you're SOL. And to be clear, you can "demand" whatever you want with the service writer but unless you physically inspect what the technician is putting into the car you have absolutely no guarantee they didn't put A40 oil in regardless what they tell you.
Old 12-22-2020, 11:37 AM
  #140
Westcoast
Westcoast's Avatar
Received 4,745 Likes on 2,758 Posts
Originally Posted by Mercuriell
Good to read the thread referenced above in the 718 forum - what is further confusing is the cited Porsche document recommending C40 oil for late model 718/992 with or without GPF
I am not sure what is so confusing, looking at the list the 9A2 engine in the Carrera is listed as requiring the C40... it makes sense that the 9A2 Evo 4.0l in the 718 require it as well.
Originally Posted by Bill Mitchell
Yes, which begs the question, if the A40 oil was good enough before, why all of a sudden is it not? I know oils evolve and better oils are rolled out and recommended for older cars, but if A40 was okay for a 2019 Porsche Cayman and now it's not, then something is fishy. I am willing to bet that virtually every Porsche with a 2019 build date received A40 oil from the factory and the dealer .
Bill, it seems that you do not want to accept that things move on and there is a new spec for the oil in these cars, nothing fishy, simply an improved formulation...
And again it not only about the GPF...
Balloonmeister (12-22-2020)
Old 12-22-2020, 11:53 AM
  #141
Bill Mitchell
Bill Mitchell's Avatar
Wink
I guess I wasn't very clear with my posting. Yes, I realize improvements are made and newer oils are better in most cases, I accept that and embrace it in fact. But the confusion comes from the fact which has been determined in this thread from several vehicle owners that many Porsche dealers are either unaware of the new C40 spec or unwilling/unable to meet it with their current inventory of oil. Thus many 2019 cars have been serviced at dealerships with A40 spec oil even though Porsche has said for about 2 years that the spec for all 911's and Boxster/Cayman since 2019 should be C40 spec oil. So I have to conclude that it is, 1. either no big deal or, 2. that the dealers don't care and are just willing to put older oil in the cars because that's what they have on hand or the only thing they can get. If the new oil is in their parts catalog and they are ordering it but it doesn't arrive, then that's on PCNA and ultimately PAG. If they just aren't ordering it because they don't want to stock two oils, then its on them but I can't see that many dealers doing this. So we still don't have a definitive answer even thou we're in agreement that cars since 2019 should get C40 and especially 2021 cars that have the GPF installed(even though they don't have the full GPF treatment like European cars) . I suppose at some point, probably next year, it will all sort itself out and our discussion will become moot, but its good fodder for discussion now and helps build a good conspiracy theory.
The following 2 users liked this post by Bill Mitchell:
minn19 (12-22-2020), Westcoast (12-22-2020)
Old 12-22-2020, 11:59 AM
  #142
Balloonmeister
Balloonmeister's Avatar
Motul 8100 X-Clean Gen 2, Porsche C40-spec oil is readily available on Amazon for $12/L or $49/5L.
https://www.amazon.com/Motul-8100-X-Clean-Gen2-Liter/dp/B08NWJXMNY/ref=sr_1_16?dchild=1&keywords=Motul+8100+X-Clean+Gen+2+Porsche+C40&qid=1608652350&sr=8-16 https://www.amazon.com/Motul-8100-X-Clean-Gen2-Liter/dp/B08NWJXMNY/ref=sr_1_16?dchild=1&keywords=Motul+8100+X-Clean+Gen+2+Porsche+C40&qid=1608652350&sr=8-16
0-Day (12-22-2020)
Old 12-22-2020, 04:19 PM
  #143
fueledbymetal
Agreed, so I wouldn't "demand" anything. When my service is due I'll call in advance to ask what oil they carry and base my course of action on their reply. C40 is available in the wild as indicated above, so in a pinch I will source my own if needed - better that than than potentially sacrifice the longevity of the car imho.
Old 12-22-2020, 04:36 PM
  #144
Mercuriell
Mercuriell's Avatar
only that after reading both threads I’d got my head around that the C40 formulation was needed for the GPF whereas that bulletin clearly cites it for non-GPF NA models - so either they’re aiming for consistency for logistic reasons or else there are other reasons such as the Low Speed PreIgnition mentioned in the 718 article 🤪
Old 12-22-2020, 04:43 PM
  #145
Westcoast
Westcoast's Avatar
Hold on, just to dirty up that oil, read this in the Mobil 1 bulletin:
Applications
Mobil 1 ESP X3 0W-40 is recommended for high-performance engines requiring GPFs (gasoline particulate filters).
• Mobil 1 ESP X3 0W-40 can only be used in the vehicles for which it is approved. It is not backward compatible with vehicle engines requiring an A40,
C30 or C20 .
*** Always consult the owner's manual of the vehicle for the manufacturer's recommended viscosity grade and specifications
File Type: pdf
Old 12-22-2020, 05:11 PM
  #146
Mercuriell
Mercuriell's Avatar
Yep seen that one - overall it points to the fact that Mobil and Porsche should have got their story straight and their oil distribution sorted before rolling out the latest models - maybe they’re so electrified by the Taycan and hybrids that they think oil matters less important than Charging Stations.
Plenty of material here for future class action should engines start playing up !
Old 12-22-2020, 06:54 PM
  #147
mjw930
mjw930's Avatar
Quite honestly I think what they are really saying is using A40 spec oil, while not optimal, has little to no effect on their warranty claim rates. In other words it's cheaper than ramping up the supply chain.
Not being backward compatible is confusing and without documentation on why it's total speculation..
Old 12-22-2020, 07:38 PM
  #148
lovetoturn
lovetoturn's Avatar
Received 1,148 Likes on 561 Posts
I agree with Bill.
What happens when your inert GPF is removed in favor of an aftermarket solution, or eliminated as described by one of our more popular threads for a paltry some of $10 of beer and some your time?
Old 12-22-2020, 08:04 PM
  #149
Mercuriell
Mercuriell's Avatar
I agree with Bill.
Back pressure will be reduced - whether this is important is doubtful unless your engine needs a warranty claim ...
Great thread though !
Old 12-22-2020, 08:10 PM
  #150
Westcoast
Westcoast's Avatar
I agree with Bill.
Leaving Bill out of it...
The GPF is not the only consideration, there are other emission systems in place on these cars, I am curious If the C40 oil was as readily available as A40 would this even be a discussion?
Quick Reply: C40 Oil Discussion
