Kline 718 GT4/Spyder exhaust
#1816
that’s correct, you either need a valve controller, ecu tune, or “collar mod” to physically prevent the valves from fully closing during those rpm ranges.
#1817
#1818
The following 5 users liked this post by ltfl09:
Anu2g (10-03-2023),
josephr25 (10-04-2023),
JPMD (10-03-2023),
SupremePower (10-04-2023),
tigerhonaker (10-03-2023)
#1819
Basic Sponsor
718 GT4/Spyder Kline exhaust + Soul valve controller - YouTube
sorry don't come on here much lol. This is Kline inconel oap and rear section. Stock headers and soul valve controller
SupremePOWER Inc
1562 Kimberly Ave - Fullerton CA 92831
Contact: sales@supremepower.com - Shop# (714)632-1951
World's Largest Retailer/Distributor of BBS Motorsport & Street Wheels from 2015-2023
Huge Inventory: BBS, Kline, Brembo, Soul, Recaro, KW, Akrapovic & 200+ brands. Installation available
** Retail & Wholesale ** Global Delivery ** We match/beat any authorized dealer's price **
SupremePower.com // SupremeForged.com // Follow SupremePower on IG
SupremePOWER Inc
#1820
Just thought I’d say thanks to everyone who posted on their experiences with the Kline exhaust. Based on a lot of what I read here, YouTube vids and some other sources, today I ordered a Kline SS system from SupremePower. I chose to get heat shielding on the OAP’s for a little extra peace of mind in controlling heat and more importantly, that cool diamond plate look ;-) While I know this may mess with the sound a little, it’s still going to be way better than stock. I also decided against the Inconel mainly because I just felt I didn’t need to go for the extra expense for a GTS 4.0. Going to hold off on a valve controller as well and see what the stock PSE sounds like and will try out some collars with the valves partially opened. If that doesn’t work for me, I will be back in touch with Eric at SupremePower to order a Cargraphic VC. For now sticking with the stock tips but if they don’t fit on the Kline well, as I have read many complained about, I will order those really cool ceramic coated black Kline tips Eric offers. Those things do look pretty sweet. In a few weeks, my Kline should arrive and will be installed and I should have the answers to some of my questions. Would be happy to report back if anyone cares to hear my overall install and first drive experiences. Finally, thanks to Eric at SupremePower for all the advice and suggestions and for making this exhaust a great buying experience. If you’re considering a Kline or many other exhaust brands, don’t hesitate to reach out to them. Thanks Eric!
#1821
Basic Sponsor
Just thought I’d say thanks to everyone who posted on their experiences with the Kline exhaust. Based on a lot of what I read here, YouTube vids and some other sources, today I ordered a Kline SS system from SupremePower. I chose to get heat shielding on the OAP’s for a little extra piece of mind in controlling heat and more importantly, that cool diamond plate look ;-) While I know this may mess with the sound a little, it’s still going to be way better than stock. I also decided against the Inconel mainly because I just felt I didn’t need to go for the extra expense for a GTS 4.0. Going to hold off on a valve controller as well and see what the stock PSE sounds like and will try out some collars with the valves partially opened. If that doesn’t work for me, I will be back in touch with Eric at SupremePower to order a Cargraphic VC. For now sticking with the stock tips but if they don’t fit on the Kline well, as I have read many complained about, I will order those really cool ceramic coated black Kline tips Eric offers. Those things do look pretty sweet. In a few weeks, my Kline should arrive and will be installed and I should have the answers to some of my questions. Would be happy to report back if anyone cares to hear my overall install and first drive experiences. Finally, thanks to Eric at SupremePower for all the advice and suggestions and for making this exhaust a great buying experience. If you’re considering a Kline or many other exhaust brands, don’t hesitate to reach out to them. Thanks Eric!
I also wanted to chime in and say that the issues regarding the stock tips have now been resolved on Klines end…. we have worked with Kline on this and now the outlet pipes the tips bolt onto have been slightly enlarged to make up for the inconsistent range of max clamping the oe tips offer
#1822
Thank you for the kind words and your order!
This is great news to hear! However, still not completely ruling out the ceramic satin black Kline tips once I see how the OEMs look and sound.
SupremePower (10-24-2023)
#1823
#1824
Basic Sponsor
Basic Sponsor
Kline has new carbon tips for 718 GT4RS 125mm which can be used on the non RS as well. Fir reference the Kline carbon non RS tips are 101mm
For more info: sales@supremepower.com
UncleDude (10-24-2023)
#1826
For non heat shielded Kline owners, can you tell me how much your rear tire pressure increases from a spirited drive? For example, on my stock car, rear tires are 35 psi cold. When I go on a spirited drive the rear tires heat up to 40-41psi. I’m trying to figure out with the Kline without heat shield if the tires will heat up even more or will it be the same.
#1827
jimdillard (10-27-2023)
#1828
That's a highly weather-dependent question, but personally, have only seen pressures jump a normal amount, so usually just 2-4psi depending on the outside temperature. Don't think you have anything to worry about as air flow would be scrubbing off any heat. Doubt the heat-shielding will make any real discernible difference, especially for the added cost.
#1829
I'm not too worried about any component damage back there, but just to keep heat soak down I am considering swapping for shielded Kline OAP.
#1830
Your starting temp of 35PSI seems a tad high. Consider aiming for a max warm tire temp of 35PSI, and see how you like the change in driving dynamics.
