718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Front License Plate Options
Old 01-07-2021, 04:20 PM
  #151
Dorian C
Dorian C's Avatar
Originally Posted by ronbauer
As I noted above, I purchased the universal kit from Craig's Custom Mustang Brackets. It's now mounted, and here are a few pics.
As 2XIPA notes, there is a little movement because of the single mounting point, but so far, is appears that there is no way for the bracket or license plate to come in contact with the bumper cover unless the thumbscrew comes loose. If you're really worried about it, using an actual serrated nut may be a better way to go, as you can get it tighter than the thumbscrew.
Ron
That looks awesome. I may be asking too much but would you by any chance have a photo from the front with the plate on? I would like to see how high/low the plate sits relative to the stock OEM mount. Thanks.
Old 01-07-2021, 04:33 PM
  #152
ronbauer
ronbauer's Avatar
I can do that tonight.
Ron
Old 01-07-2021, 06:36 PM
  #153
Dorian C
Dorian C's Avatar
Ron
Thanks. That also gives me a chance to look at your gorgeous python green GT4
ronbauer (01-07-2021)
Old 01-07-2021, 07:06 PM
  #154
UncleDude
UncleDude's Avatar
Received 5,398 Likes on 2,210 Posts
Very nice Ron. I'm going to order one too.
Old 01-08-2021, 02:53 PM
  #155
ronbauer
ronbauer's Avatar
Here you go.
Ron
UncleDude (01-08-2021)
Old 01-08-2021, 03:36 PM
  #156
LDubz735
LDubz735's Avatar
Looks great Ron, thanks for posting the pics!
ronbauer (01-08-2021)
Old 01-08-2021, 03:37 PM
  #157
LDubz735
LDubz735's Avatar
Originally Posted by alwaysdriving
My current setup is 100% perfect and will not cost you much like 30$ total, i used 8 x 2 of magnets nonudium front and back of the bumper that i bought from amazon + 3m double sided tabes this will stick the plate and secure it and when you need to remove you can without leaving a mess
Do you have links to the products you used? Thanks!
Old 01-08-2021, 04:37 PM
  #158
Dorian C
Dorian C's Avatar
Here you go.
Ron
Thank you. Looks perfect.
Magnet is not without mess. Taking off the bumper and permanently glue something to the back of the bumper is indeed a mess to some.
Old 02-21-2021, 02:13 PM
  #159
dnimi123
dnimi123's Avatar
Received 1,111 Likes on 672 Posts
Those looking for a cheap, easy and not bad looking front license plate option... Yes thats a piece of black weather strip tape! Go ahead say what you will but its a better spot than on the bumper and its better than the Carbino thingy... Its firmly mounted in place with the upper edge pressed into the inside crease of the grill and help with some more tape. Have driven on freeway and at high speeds with no movement.
FASTRKMAN (02-21-2021)
Old 02-21-2021, 02:17 PM
  #160
FASTRKMAN
FASTRKMAN's Avatar
Great idea dnimi123 this may work for me as I only need a temp fix. Any concerns with the block of airflow?
Old 02-21-2021, 08:26 PM
  #161
dnimi123
dnimi123's Avatar
Not really concerned as air can get in around and behind the plate... and dont really care if my 'lap' times on my street suffer! Also as mentioned I think it looks better in this spot than on the bumper and Carbino sticks too far out. Not to mention its pennies for weather strip (my first iteration was black electrical tape). There are other variations too like with Velcro and getting the plate to sit more upright, but slanted like this works for me for now...
Old 03-07-2021, 09:20 PM
  #162
SpeedySpidey
SpeedySpidey's Avatar
For those who can be patient, watch this space for my front plate mount solution. I think I’m on to something.
It’s a simple, no Drill solution, and really inexpensive, yet (I believe) fairly easy to implement.
I am almost finished with it, but I have to pause for a week or so to visit my brother in Fla La Land...
I should have it wrapped up by the end of the month, so stay tuned 👍
dnimi123 (03-08-2021)
Old 03-07-2021, 09:26 PM
  #163
UncleDude
UncleDude's Avatar
Looking forward to your patented solution speedy
Old 03-07-2021, 10:31 PM
  #164
SpeedySpidey
Ha! No patent... free to all Rennlister’s. But I’m really excited by this and I do expect this to be copied by professionals.
Old 03-07-2021, 10:59 PM
  #165
UncleDude
UncleDude's Avatar
I have the same one Ron has, and will be applying it to the car when I get it. IMO that one is hard to beat for ease of install and because you can take the plate of easily. There was one member who’s already ripped of the Carbino holder
Quick Reply: Front License Plate Options
