Taycan Turbo - EPA rated 201 miles
#616
This thread closely parallels similar threads that started on the Audiworld E-tron forum after the 204 mile EPA range was revealed. With deliveries of the E-tron, real world data became available that generally collaborated the EPA estimated range; albeit with variability related to driving style, temperature, elevation, etc. Here is a link to a recent post where an owner posted his experience across a range of miles and temperatures. Around 50 degrees Fahrenheit he generally matched the EPA range, at higher temperatures he achieved higher range, peaking at about 110-120% of the EPA range estimate.
https://www.audiworld.com/forums/aud...2983350/page2/
Look for posts by 2KA6_2.7T
With time, we will see similar real world data for the Taycan. It is clear we will not see 350+ miles range like the EPA estimates for the Model S, or 300+ miles range like the EPA range estimates for the Model 3. These are very different cars with different pros and cons. I do not own either a Porsche or a Tesla, but am very interested in moving to an EV. I have been tempted by Tesla for many years, but have not been able to get past their build quality, lack of features seen in other cars in the price range, limited tech platform (no Apple CarPlay or Android Auto, no option for streaming and apps other than those built into the car or Bluetooth streaming from your phone), limited service infrastructure, etc.. Clearly Tesla has the lead on powertrain efficiency and charging infrastructure, Porsche, Audi and other manufacturers have the lead on quality and content of their cars.
I look forward to seeing more analyses of the sources of the differing efficiencies between the Model S and the Taycan. For example, how much is related to weight differences? How much is related to the two speed transmission? How much is related to battery management to allow for repeated high-speed runs? How much is related to different battery chemistry? I have not seen much in this regard so far.
We ordered an E-tron but cancelled our order due to the limited range. It would have been our primary road trip car and we were not ready for the inconvenience of limited range and limited charging infrastructure. That said, many people on the E-tron forum are perfectly happy with their purchase and do not have any concerns about the range limitation.
I have a reservation for a Taycan and will be test driving on Saturday. The limited range is less of a concern as it would not be our primary road trip car, but I am still concerned about expected rapid depreciation as newer technology comes on line in the next several years. Leasing would make the most sense for a Taycan, but the lease numbers I have seen so far are awful; I estimate a $130K MSRP 4S would lease at about $2400/month for 36/10 with no cap cost reduction (we pay 10% tax on lease payment). That is nearly 90K over three years on a $130K car. Buying would generally make more sense given the $7500 Federal tax incentive and the lack of sales tax in DC, but it will need to be a car I am happy to keep for many years to address the likely low value in 4-5 years.
#617
Not even with your throttle or brake pedals? There is always the pulling force although it's provided by the spring load. Nothing different with how you operate this one "accelerator' pedal.
You never see an engineering product that will require two ***** to control output, volume, temperature, power etc.... when one could do the job. No one would be that silly to say using two ***** makes adjusting volume more fun.
Didn't you just proved my point? Even with such a terrible latency ships still prefer to do it with just one ****.
Your description of how Tesla pedal works it totally wrong too. It never engages the brake unless the car is already at or very close to a complete stop. Sounds like you're the person who's trying to mistreat your own throat and bottom.
Again, you really do have a reading comprehension problem don't you? Or you are just too liberal in your own definitions.
First of all, ship isn't using one ****. It's a physical handle. Also, even with those that uses a '****', they have travel both ways from neutral position. Keyword, NEUTRAL POSITION. There is a clear separation between positive and negative value of input, and in the neutral position, there is neither.
Your Tesla's throttle only travels one way, it doesn't give you negative throttle input the other way around past the neutral position, plus the neutral position isn't actually neutral as that automatically engages the regenerative braking. It's a one way on/off switch, not like the 3 way like ship throttle, forward, neutral and reverse.
I never said Tesla's throttle engages the brakes, I said REGENERATIVE BRAKING when one lift off the throttle. The moment the driver press the brake pedal, physical brakes are engaged and no more regenerative braking.
So in a Tesla, you either get electrical propulsion, regenerative braking, physical braking, that's it, there is no coasting.
Normal cars and advance EVs have all those, plus coasting function.AND for the advance EVs, they have a CHOICE to whether engage throttle liftoff regenerative braking or not. It would seems the Tesla is the more technically challenged product that missing a function and don't give user a choice, don't u agree?
Der-Schwabe (01-08-2020)
#618
It's as simple as it is written.
IF you are riding the brakes at all times, the throttle still works to propel you forward, but the moment you lift off the throttle, the brakes takeover and you stop.
What else is there to explain?
#619
And just to be clear, would your definition of coasting be the absence of propulsion that results in eventual stop due to frictional forces outside of the drivetrain?
You can turn regen off and coast on a Tesla if that's your preference. Exactly like an ICE. It even has creep mode.
#620
1. You still get regen braking when you press the brake pedal. You're just adding it yourself to what the regen is now doing based on your foot having lifted off.
2. You 100% can coast in any Tesla. Just lift your foot until the power meter reads neither negative nor positive. It's mostly easy to get used to doing. The Model S / X have a better, clearer display that makes it easier. The Model 3 has a Black / Green power bar that you must get to the middle.
Certainly not as easy as simply lifting one's foot. But not all that hard either.
Read above. You can coast in a Tesla (and all other one-pedal EV's, or EV's that tie strong regen to one pedal like an i3). It's not that hard. Also, your analogy is false, even if you were to lift off, as "riding the brakes" means you are applying the brakes as you're driving, simultaneously propelling the car forward with the drive train and dragging it back with the brakes. This is not the same as an EV.
The following 2 users liked this post by Needsdecaf:
daveo4porsche (01-02-2020),
whiz944 (01-03-2020)
#621
When I was learning how to move my foot to "coast" as noted in my post above, I couldn't believe how far the car would keep going and not slow when the power bar was in the "coast" zone. I thought, "this car might show that I'm neither applying power nor regenning, but I'm still rolling really freely, this can't be right". Then I learned how to put it in Neutral, and tried a few tests coasting in Neutral. It's ridiculous. It's like a freaking fidget spinner. The car just keeps rolling!
#622
I changed my setting tonight on my drive home to see just how similar the driving characteristics might be to an ICEV. I would have to say that the difference between that and any typical ICEV with an automatic transmission is on par with the difference between any two non-identical ICEV's with automatic transmissions, meaning negligible.
Now just in the interest of context, I haven't driven an ICEV since I bought my Tesla which was 18 months ago but my previous steed was a BMW 545 with an automatic transmission for comparisons.
There is a new setting that I must have gotten OTA previously called ROLL, whereas previously, you had CREEP and whatever they call the one pedal setup. I also set regen to low vs normal.
There was still some regen at least according to the gauge but hard to feel as on even a slight downhill, it would continue to coast until I hit the brake. I have to say though that I much rather prefer letting regen do my braking for me.
#623
#624
My reasoning has nothing to do with what you think it is.
#625
@Whoopsy have you driven a Tesla for any length of time beyond a test drive - it's really quite easy to "coast" in a Tesla I do it all the time and it's not like riding the brakes all the time - but maybe your experience is different.
#627
Another non-Tesla owner who thinks all Tesla owners want to avoid driving.
#628
#629
