Old 06-28-2017, 01:01 PM
  #8251
4score4
4score4's Avatar
Just finished up redoing the whole front end suspension and tie rods/ends on my 84. Had dead shocks, dead struts, wore out strut mounts, and a disastrous sway bar install ( was upside-down which damaged the control arms ), crusty ball joints, and cracked bushings all around.
Also learned I had a proper manual steering rack, as opposed to a de-powered unit, must have been a swap.
Shoving the rubber bushings on the sway bar and installing that, WORST thing I've had to do on this car, would rather change the timing belt and water pump. maybe.
Old 06-28-2017, 02:11 PM
  #8252
ealoken
ealoken's Avatar
Started on my new engine.
Old 06-28-2017, 11:06 PM
  #8253
odonnell
odonnell's Avatar
Took it to work as the first maiden voyage after 2 weeks of work...suspension, wiring, motor mounts, tuning, and some alternator issues. Drive and runs awesome but the brakes feel super sh***y. They started feeling soft after I did my front wheel bearings last month but now they're downright unsafe. Who wants to bet my Rock Auto reman Volvo calipers are the issue. Master checks out ok and I fully bled the system with ATE TYP 200 a few months ago.
Old 06-28-2017, 11:40 PM
  #8254
Tiger03447
Tiger03447's Avatar
Dear Pfarah7: After talking with V2Rocket, and looking at all the crap in the footwell I'll have to remove to get to it....I chickened out...I hit it with my dremel and squirted some de-rusto solution on it..probably a watered down naval jelly in a squirt bottle, and it came out all clean on the rusted areas. I dried it off and rinsed it off with water after plugging the M/C hole...I haven't been back to my shop in a couple of days due to a blown out L knee, but hope to hit it with some paint tomorrow or Friday. I did however, pick up several powdercoated parts for the rear end down in Hartford, so that will be back together soon I hope..this rear end/rear brake ordeal has taken waayy too long IMHO....~:>((
Old 06-29-2017, 07:27 AM
  #8255
SloMo228
SloMo228's Avatar
Buttoned up the install of a new-to-me S2 transaxle and actually-new GKN CV axles (which are HUGE, by the way. No worries about these suckers breaking) and new rear speakers.
I'd been putting off the speaker install because it involves taking out the rear quarter windows, but it actually is pretty easy to remove and reinstall those.
Got just a few little tasks on the to do list to prep the car for a nice road trip to Virginia. I'm being sent out to Charlottesville for work and wanted to take advantage of the opportunity to hit some nice twisty Appalachian roads on the way!
Old 06-29-2017, 01:06 PM
  #8256
Tiger03447
Tiger03447's Avatar
Safe travels..SloMo228 Hope that you have fun!
Old 06-29-2017, 01:22 PM
  #8257
SloMo228
SloMo228's Avatar
Thanks! It's always nice to get a chance to take the 944 out into some nice roads in the hills, and I haven't been to this part of the country before. I'll be down there for two weeks so I have a free weekend and I plan to spend a whole day exploring backroads.
Old 06-29-2017, 08:11 PM
  #8258
ToXic U4ia
2nd Gear
ToXic U4ia's Avatar
Had her out corner hunting. Not much game in lower Michigan.
Old 06-30-2017, 09:24 AM
  #8259
dreygata
dreygata's Avatar
Bought two replacement connecting rods, ordered a replacement lower balance shaft cover.
Continued cleaning up the engine parts and had a beer
Old 06-30-2017, 11:40 AM
  #8260
phL
phL's Avatar
let a timing gear cover go up in flames with a little too much heat while burning the paint off (yes, i was aware of that risk)
ordered new timing gear cover from rennbay (aluminum)
put the cams back in and the tensioner with new guide pads
determined the old valve cover looked like **** and ordered a good used one off ebay
thinking about going under the car again to see if the crank is still fixed at TDC
more to be done on the weekend.
belts are ready. not sure if i want to throw that new water pump in there or not. the old one has proven itself to run great so far.
Old 06-30-2017, 12:31 PM
  #8261
SloMo228
SloMo228's Avatar
Isn't that part magnesium? Must have been quite a show, hopefully it wasn't still on the car!
Old 06-30-2017, 04:19 PM
  #8262
KVDR
KVDR's Avatar
Trying to decide what to do with these burgundy script sport seats I bought locally on impulse.
My interior is 'light grey', so I was originally planning to recover them, but they seem to be rare and might actually clean up okay using steam or other means.
Old 06-30-2017, 05:38 PM
  #8263
pfarah7
pfarah7's Avatar
Tiger: Yeah, that's what I may end up doing someday...
KVDR: 924Werks does sell Porsche script upholstery in various colors if you wanted restore those seats.
Old 06-30-2017, 06:42 PM
  #8264
pdxfj
pdxfj's Avatar
After fully rebuilding the A/C system in my car, I had it charged with R12 today. Blows really, really cold.
New compressor, lines, dryer and condenser. Not cheap, but worth it.
Old 07-02-2017, 09:15 PM
  #8265
No Lag
No Lag's Avatar
Do tell. I'm looking to fix mine. Tips? Where did you purchase your compressor?
