Diesel Cayenne and VW emission issue
#3241
I received 3 cards. One with only first and last name, one with first, middle and last name, and one in my LLC name. I recently assigned ownership to my LLC name for reasons related to work usage. I've already registered under my name. Should I register under my LLC name also?
Or you can send them a question at their website/email address or call the toll free number. I'm sure they have crossed this bridge by now from the 2.0L case.
Like others I received two 3.0L Gen 2 specific cards that only differ by middle initial of my name, so no problem proving I'm the same person on both cards.
#3244
My mistake ... yes, you are correct. Thanks for correcting it. I'll edit the original post as well.
#3246
If your vehicle registration and vehicle title is under your LLC then you may want to register with it. But really once you get in the process you will have to prove yourself to be an "eligible owner" and also have that proof notarized, so as long as you have appropriate documents to show you and the LLC are one in the same you should be ok. But there may be an advantage of having any money directed to the LLC ..... Or you can send them a question at their website/email address or call the toll free number. I'm sure they have crossed this bridge by now from the 2.0L case. Like others I received two 3.0L Gen 2 specific cards that only differ by middle initial of my name, so no problem proving I'm the same person on both cards.
#3249
#3254
Was referring to the wheel color
My P!g is blue and I'm quite happy with it that way which is why I kept it that color even when I had a chance to change it (http://www.6speedonline.com/forums/c...on-damage.html).
After blacking everything else out it's been suggested a few times to do black wheels, but that's just too much in my opinion.
#3255
