Old 09-13-2016, 12:38 AM
  #6586
The Forgotten On
The Forgotten On's Avatar
Replaced the small coolant hose that goes from the back of the waterblock to the coolant T that runs to the expansion tank then topped it up with coolant.
Maybe this will finally end my search for why water was leaking into the V of the engine after my waterbridge debacle.
Old 09-13-2016, 12:50 AM
  #6587
MjRocket
MjRocket's Avatar
Originally Posted by Shawn Stanford
Received the 928 decals from Bertrand and finished converting the ratty old '928S' aluminum thresholds.
Tomorrow I'm going to see a man about a stripe!
Shawn
Where did you get these aluminum ones?
Thx
Old 09-13-2016, 01:02 AM
  #6588
Vandalizer
Vandalizer's Avatar
Replaced the PO's D90s with new rubber and the correct 7 slot wheels.
Old 09-13-2016, 01:32 PM
  #6589
antsmands
antsmands's Avatar
Not blinding at all, very clear! The picture does not do them justice!
Old 09-13-2016, 02:20 PM
  #6590
Shawn Stanford
Shawn Stanford's Avatar
They came out of someone's parts car. I bought a pair of leather seats and the seller told me to take anything else that might be of use to someone. I grabbed a couple things, including those aluminum thresholds.
They originally were covered in a 'no skid' kind of stuff, with the '928S' cut out. I cleaned off the old stuff and Bertrand made me the decals.
Old 09-13-2016, 04:13 PM
  #6591
NoVector
NoVector's Avatar
Finally have a complete tool box. Thanks, Roger!
Old 09-14-2016, 12:08 PM
  #6592
Shawn Stanford
What? You didn't have a spare coat hangar laying around?
Old 09-14-2016, 01:00 PM
  #6593
voskian
voskian's Avatar
NoVector, do you have one of these in your glove box?......this is what is usually evasive in completeting the tools set!
Love the avatars
Old 09-14-2016, 01:27 PM
  #6594
eugkim
eugkim's Avatar
Originally Posted by antsmands
Gauge cluster update - L-R - Vacuum, Volts, Coolant Temp (F), Alternator Temp(C), Engine RPM. I
Love the blue faces!
Anyone know what stereo headunit this is?
Old 09-14-2016, 01:51 PM
  #6595
Petza914
Petza914's Avatar
MJ,
I bought a pair from Rennline. They're just a hair short to cover all the holes, so made some transition curves with cf vinyl to finish the job and adhered a CF wrapped logo to the center. Might give you another way to go.
Shawn
Thx
Old 09-15-2016, 03:06 AM
  #6596
Whitesands
Whitesands's Avatar
New timing belt.
Old 09-15-2016, 03:09 AM
  #6597
MainePorsche
MainePorsche's Avatar
Fixed the non op cruise control. My first suspect was to rule out loss of ground because of a failed 3rd brake light (all others are LED). Bulb was good, but there was a loose connection that needed correcting.
Other thing today was registering my car in the new state I am living in now. After I got my plates I was happy to find my same plate I had in Maine was available in the Empire State. I booked it online forthwith. Was a day with reflection.
Old 09-17-2016, 12:14 AM
  #6598
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,295 Likes on 492 Posts
Put back the belly pan... After 6 years!
Bought a used one from 928 Intl last Spring.
Cleaned it well and had it sprayed with Linex. They did a great job.
My old one was done so I removed it and never thought about it after.
It's about time that it gets back to where it should be.
Yes, I forgot to paint the inside of one of the deflector!
Old 09-17-2016, 11:34 PM
  #6599
2002M3Drew
2002M3Drew's Avatar
Polished entire car with Chemical Guys VSS
Sealed entire car with Chemical Guys Blacklight
Applied Chemical Guys spray sealer
Removed 30 year old dealer badge from rear bumper with heat gun and trim remover (and patience)
Cleaned and conditioned entire leather interior
Vacuumed entire cat
Cleaned all windows in and out
Old 09-17-2016, 11:43 PM
  #6600
Petza914
Petza914's Avatar
Replaced my Jager hood liner / heat shield with the versions from 928 Motorsports. After just 18 months and limited use, the large portion had become brittle already and the small portion was coming loose.
Not the first mile on the new ones yet, but I have to say, the material is nice and light, seems like it will be extremely durable, and more heat reflective. Looks like another well thought out and designed offering from Carl.
Installed a spare set of Jager shark graphics I had.
Quick Reply: So what did you do to your 928 Today......
