Pulling engine help
Old 07-05-2016, 08:23 PM
MWENDL1
MWENDL1's Avatar
Default Pulling engine help
Hi. I have a 1984 Red Porsche 928S, Northern California.
I've never pulled an engine. I bought a hoist and leveller. Im nervous about attaching chain to the wrong spot. I've taken two pictures and I've searched the forums. I'm just not clear on the spot that is designed to attach.
Please help.
Thanks
Mike
Front of engine
Old 07-05-2016, 08:29 PM
Adamant1971
Adamant1971's Avatar
Received 1,093 Likes on 514 Posts
In that first pick are you intending on lifting from the air pump bracket?
You should have hooks on each head, one on left front and one on the right rear. From standing in front. They are hard to see or can be missing.
Old 07-05-2016, 08:34 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,760 Likes on 1,340 Posts
Both the front and rear engine hoist brackets are in your pictures. See the red arrows:
Front:
Rear:
Old 07-05-2016, 09:16 PM
MWENDL1
MWENDL1's Avatar
Great. Thank you. I now see the two lift points. I've read to attach to a third spot for balance. Is there another lift point or is that less important. I'm using this lift
Lift I found on cl
Old 07-05-2016, 09:18 PM
Ducman82
Ducman82's Avatar
it all depends on how you pull it. but you should not need any other attachment.
Old 07-05-2016, 09:25 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Make sure the bolt for the leveler are strong enough. Also, find someone that that pulled an engine (doesn't have to be a 928) in their life and have them at least be there to guide you through it.
When you start lifting it, go slow and constantly circle the engine looking for unhooked wires because that lift has no mercy when it comes to forgotten connectors.
Old 07-05-2016, 10:06 PM
GlenL
GlenL's Avatar
Using search is a great start.
Old 07-05-2016, 10:18 PM
fraggle
fraggle's Avatar
You'll be surprised how well it balances utilizing those two points and the leveler.
I have done this by myself with my S4, and can say that the second time I did it with three helpers it went a ton smoother.
Old 07-05-2016, 11:14 PM
Jehu Gearloose
Jehu Gearloose's Avatar
Default Pulling Engine
Mike
I pulled one earlier this year with no prior experience. You can do it, although I agree that having someone with experience on site would've been helpful.
FWIW, here are some threads I found helpful and kept for future reference. (Your mileage may vary.)
Engine Removal
https://rennlist.com/forums/928-foru...e-for-gts.html
http://members.rennlist.com/exturbo/...0checklist.pdf
https://rennlist.com/forums/928-foru...s-back-on.html
https://rennlist.com/forums/928-foru...otor-tips.html
https://rennlist.com/forums/928-foru...ing-bolts.html
Engine Stand
https://rennlist.com/forums/928-foru...do-i-need.html
https://rennlist.com/forums/928-foru...ine-stand.html
https://rennlist.com/forums/928-foru...ml#post5217554
https://rennlist.com/forums/928-foru...-mounting.html
https://rennlist.com/forums/928-foru...c-stand-2.html
Good luck.
Old 07-05-2016, 11:30 PM
Daniel5691
Daniel5691's Avatar
Make sure that you have room in front of the car to move the engine-and-hoist assembly once it is up in the air and free from the car. Ask me how I know this. LOL
Old 07-06-2016, 12:38 AM
zekgb
zekgb's Avatar
If you are doing this on your own I would suggest leaving the fuel injection harness in the car by completely disconnecting it and laying it over the right fender as feeding it through the firewall is a pain without some help. That said I might be able to help as I just went through this drill. Check your PM's.
Old 07-06-2016, 01:37 AM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Impossible.
This has never been done before.
Old 07-06-2016, 10:39 AM
Taguid
Taguid's Avatar
I pulled mine Saturday from the side and I removed the wiring harnesses from the top and front and set them aside.
Old 07-06-2016, 12:18 PM
The Deputy
The Deputy's Avatar
Originally Posted by Rob Edwards
See the red arrows:
Rear:
Rob, that's the throttle cable...it's strong...but it ain't that strong.
Sorry, just busting your chops...lol.
Brian.
Old 07-11-2016, 01:14 AM
MWENDL1
MWENDL1's Avatar
engine out!!!!!
After weeks of work engine out. I'm slowly learning. Thanks everyone for your help!
Quick Reply: Pulling engine help
