what engine stand bolts do I need
I am almost ready to attach my motor to a basic Anco engine stand- What bolts do I need? 82 Euro S 5spd
Archive Gatekeeper
The upper bellhousing bolt holes are M12 x 1.5, you can either get them at Ace Hardware if you're lucky (https://rennlist.com/forums/928-foru...1-5-bolts.html) or (https://rennlist.com/forums/928-foru...ine-stand.html)
Or you can pull a pair of the rear lower control arm bolts from the front suspension and use those.
The lower bellhousing bolt holes aren't threaded, so you can use any M12 bolt + washers & nuts, or M12 allthread. I had to use the latter because the standoffs on my engine stand were too long.
![](https://webfiles.uci.edu/redwards/public/91GT%20on%20stand%20right%20side%20view.jpg)
