AIM Solo GPS Lap timer available $399
#377
Basic Site Sponsor
Basic Site Sponsor
Received 3,325 Likes
The Solo has no integration or communication with the SmartyCam.
The Solo DL does integrate through a cable, powers up the SmartyCam, turns it on and off automatically with an RPM input, supplies the GPS signal for lap timing, mapping and speed to the SmartyCam, sends the logged data it collects to the SmartyCam's mSD card and shows how much space you have left on the card. It's very well integrated.
A 944 might be better to have an MXL Pista and a an SC, an EVO 4/TG-Dash and an SC or, for more reasonable money, just an RPM Bridge/SC combination.
Without the CAN or OBD-II input, the Solo DL can't get an RPM feed, which is of great value and primary to the value of the integration of the data into the background of the video, off the older cars. The RPM Bridge, MXL Pista or EVO 4 can get that from a 944 and send it to the SmartyCam.
The benefit of the automatic integration is that people can pull the chip, stick it in the computer and have speeds, lap times, g-loadings and, with the accessory to "translate" the vehicle information (RPM Bridge, MXL Pista or EVO 4 on the old cars, Solo DL or EVO 4 on the new cars), can integrate all that info graphically onto the background of the video FOR IMMEDIATE REVIEW.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#378
just seems to be a prob with yesterdays files from my DL. From other's solo works fine too...
must be something to do with my re calibrate or dropping the Hz on some sensor readings (to clean up data a bit i.e. 20hz is enough) or something ...
but its causing problems unfortunately. Trying to think of any other changes I might have made. Math channels, maybe?
EDIT - Pete I found the bug and its AIM. I went thru all changes i made yesterday and one of them was taking more detailed notes in the comments space during dl ....
If your race notes/comments are longer than 1 line when you dl/save your drk file, it cause this export crash
Can you pass on to Roger/Aim please?
Thanks to AIM via Roger for confirming the bug was 34+ characters in the notes w. caused a crash. Will be fixed on next release.
#379
Looking at data loggers. Has anyone else been successful in getting OBD-II data from a 2010 GT3 beside orthojoe? Would really be helpful to also know what info was available.
This is a great and tremendously helpful thread!!!
#380
Basic Site Sponsor
Basic Site Sponsor
I had a problem with ShakenBake's car, but it's a bad unit and it's been replaced.
#381
Rennlist Hoonigan
which cost no drachmas
Interesting note that Robbie told Jerry and I - the Solo uses the architecture from the EVO3 with certain things disabled. It now makes more sense why the Solo and Solo DL are so powerful!
#382
Excellent! Thank you Peter. Your contribution to this thread is over the top!
A few more questions that many others may find helpful:
I see brake press. Is Pedal_angle the throttle?
Noticed the "Enabl..." box check is checked but dimmed on a few channels, data still transmitted to SoloDL?
Thank you! BTW I will be in touch on next season.
David
David
#383
Basic Site Sponsor
Basic Site Sponsor
David, PPS is pedal position sensor for the accel pedal before the nanny controls, angle is after the nannies! All checked parameters are logged, the shaded ones can't be unchecked or altered due to their relationship to other parameters. Hope to hear from you next year!
#384
Peter
I believe the 2010 GT 3 is a Bosch ECU. I've had trouble making the DL work with OBD II on the 2010 GT 3. I have not tried the latest firmware though.
DaveNR, keep us posted on which Protocol works for you. Try the generic OBD protocols after you try Porsche/Bosch
#386
http://aim-sportline.com/download/ec...II_100_eng.pdf
Cheers!
#388
Basic Site Sponsor
Basic Site Sponsor
Perhaps this is what you are looking for: CAN over OBDII for 997.2
Cheers!
Cheers!
It's what Jerry, Matt, Roger and I have been asking for for over a year, starting with orthojoe's plea!
Folks, keep talking about this and we'll all benefit from our collective effort!
#389
I still want to verify it really works. I got it to work on the 2011 but not the 2010. Very strange. Hopefully DaveNR will confirm that this works
AIM has added staff to do a much better job producing documentation. Glad to see it is arriving.
#390
Short update:
Sorry for the delay, holidays and other things interfering with priorities! Configured the timer by AIM instructions posted by rldzhao with the following channels:
ID CHANNEL NAME FUNCTION
ECU_1 RPM RPM
ECU_2 WHEEL_SP_FL Front left wheel speed
ECU_3 WHEEL_SP_FR Front right wheel speed
ECU_4 WHEEL_SP_RL Rear left wheel speed
ECU_5 WHEEL_SP_RR Rear right wheel speed
ECU_6 THROTTLE_POS Throttle position sensor
ECU_7 ACCEL_POS Acceleration position
ECU_8 COOLANT_TEMP Engine cooling temperature
ECU_9 INTK_AIR_TEMP Intake air temperature
ECU_10 MANIFOLD_PRESS Manifold air pressure
ECU_11 FUEL_LEVEL Fuel level
ECU_12 STEER_ANGLE Steering angle
ECU_13 BRAKE_PRESS Brake pressure
Should have can connection done in next day or so. Will check the "Online" connection to the data logger and give report. So far so good...
ECU_1 RPM RPM
