"Racing room" not required to be given in PCA club racing?
That is wierd. To me blocking is making two defensive moves. If you take a tight line or move to the inside to defend position the other guy needs to back out some, that is racing. To make pass you need both momentem and a place to go. To defend position take away any place for the guy to go. 1 move done well is the way do it. Weaving all over the track is blocking.
Based on a recent discussion, the RacerUniversity Pro Coach/Racer faculty members don't seem to think there is a difference between club racing and professional racing when it comes to what is acceptable when passing.
I got shot down when I suggested there was a difference in a discussion.
Scott
Scott
That is what makes it different.
Isn't it better to say that the leading car "owns the racing line" until the passing car: (a) has bumper overlap, or (b) has a bumper on the leading car's door, (c) whatever -- and then the lead car needs to give racing room?
Seems to me that a "chop" move may be nothing more than going to the apex when you believe that you still own the racing line.
So while most rules talk about car position car relative speeds are key in determining how likely a crash can be.
I like the FIA approach, personally: "manoeuvres liable to hinder other drivers, such as more than one change of direction to defend a position, deliberate crowding of a car beyond the edge of the track or any other abnormal change of direction, are strictly prohibited." There is a point at which going for the apex crowds a car beyond the edge of the track or is otherwise a manoeuvre liable to hinder another driver." Note that need not be the intent, but just the effect, of the manoeuvre. Look at the drive through penalties assessed in the Monaco race on Paul and Lewis last weekend. Classic cases.
This rule does not prohibit, as I read it, a car on the inside line of a bend holding a car out into the marbles or a slower part of the track if the inside car does not crowd the car beyond the edge of the track.
The differnce is that in club racing and pro- racing is not the action of making the pass, but the choice of when to make the pass and how hard to defend the pass. Every pass has some risk. I don't make passes in club racing that I think have high risk of contact even if is just a light tap. I just won't do it. In pro racing you look a risk differently. If you can make the pass and not wreck your car and not get penalty go for it. If either car gets a tire donut so be it.
In both cases ones you commit to the pass do it right and be assertive. If you look like you are weasling out in the lead car's mirros they will tend to slam the door on you. I said earlier in that not only is position important, but so is momentum and speed difference. An assertive pass comes with a clear speed difference and therefore it is harder to close the door. A weak pass comes with little speed differnce and high likely hood of getting the door shut hard. However in club racing there have been times I have done weak passes (faints mostly) and they stick. The guy in front thinks I have the corner and I really don't but he gives it to me anyway. Oh... well I will still take it.
Winders.. you are missing one key point. A pass is a pass and they are right that a pro pass is equal to club pass. So that the actual pass is the same. When you do it go for it.
Scott
Very interesting thread... I think PCA should add a concise definition of racing room and who is at fault to the rule book. The sections of the PCA rulebook iin the first post do not address that at all, only the administrative aspects.
As for me, I thought the Professor nailed it, and I'm just a poorly financed club-racer who doesn't want his car damaged.
Racing line and racing room are not the same thing. If you are going take an apex and there is car on your bumper or even with some overlap you can still leave racing room and take the apex. Leaving racing room means that car has a place to go. They may not want to go there, but there is room to avoid a wreck. Yielding the line because the trailing car has bumper even with yours is giving up too soon. Now of course what cannot be determined from car position along is relateive speeds. If the trailing car has bumper overlap and 5mph more speed turning in will result in a crash. If he has the same speed as you turning in defending position and that guy can back out.
Good passing technique is the same.
The level of risk in doing so deemed acceptable is different.
The rest are just examples.
I learned this early in my racing career, the hard way.
I was making a pass on a much slower car. I left lots of room - almost drove down the inside of the track, as the car I was passing was a rookie and I wanted to give a wide berth. The other car took a late apex, and didn't see me coming. Because of my poor angle of entry, and speed difference, I couldn't back out, and hit him fairly hard in the passenger door. I was appropriately DQ'd as I was the passing car, and at that point, did not yet control the corner/have a right to the line. No surprise.
What happened next surprised me. The RD sat me down, and explained to me that this incident was due to, or at least made worst by my not being assertive enough. I was expecting a lecture on being too aggressive. He explained that if I had "skinned" the car I was passing, several good things would have resulted:
- There would be a better chance the rookie driver would know I was there
- I wouldn't have the terrible angle of entry into the corner, and could have made course corrections more easily to avoid contact.
- On a better line, I could have carried enough speed to complete most, if not all the pass by the point we contacted.
-Any contact that did happen would be minor, and not have punted the other car, resulting in an automatic DQ.
This was a very enlightening conversation, and shows that being assertive once you made the decision that a clean pass is avialable applys in club racing, as well.
In the Washington DC Region SCCA race school novices are taught to pass with only a couple of inches side-to-side for just the reasons stated. It's a good race school and a real bargain.
^^^This^^^ is an extraordinary bit of self-serving hooey.
In a discussion about tactical passing moves, you alone determined that what was being advocated was hazardous. YOU made the characterization that on-track tactics, acceptable to the other dicussion participants, were outside of the norm for club racing. Racers, both club & pro, with THOUSANDS of races experience, disagreed with you. You then chose to assert that "disagree" = "attack". It was not an attack, and both a broad and narrow reading of the responses reveal that...to everyone but you.
However, I will not hesitate to use the word "dilettante" in regard to your post here. That, my friend, is an attack.
I know most would never agree with this, but any deviation from the racing line by the lead car is blocking. Anything different from what you would do if no one were behind you can't be anything else but a block. A little bit is defending, a lot is blatant. Simple as that.
My basic premise was that the article was too simplistic. Then you described some tactics that I thought might be too aggressive for club racing. You said the tactics are the same at any level of racing. I disagreed....which I thought was my right but apparently is not.
Again, no where did I say the pass described in the article was hazardous.
Scott
Personally I never try to run anyone into two off, but I will make them work for a pass. They need to get far upalong side of me to take the inside away. 6" to 12" of overlap is not going to cut it unless you have a ton of speed. 4-5 feet of overlap will cause me to leave room, but only enough to get by. That is unless I feel that I will lose out even more by continuing to challenge by going side by side. In that case I my give you the corner and focus in maximxing my exit speed trailing you so that I can come back in another corner.
