MID OHIO MAY 17 &18
#136
But the laps look nice and smooth and you basically use all the track
#137
A bit late to the party, enjoyed all the videos, here is one from the blue "rain" sprint race
http://www.youtube.com/watch?v=rQgyJVOxvY4
#139
"Was that the Levitas 993? It pulled like a freight train in the straights"
Not sure, but when he lit the turbo........wow!
#140
#141
This has been really educational to watch everyone's video - lots of things to learn. I've been watching my own and learning a lot.
At the risk of causing huge laughter, I've posted two of the few laps that survived my camcorder issues. It's here: Video
One of the things I noticed the most about my video is that there is a big difference between what you (I) perceive in the car and what you're really doing. For example:
I can't wait to get back to to MidOhio...I can easily see at least 1 second that I can gain if I focus and correct some things.
Other comments & feedback welcome.
Rick
- Times when I thought I went deep into a corner before braking...I wasn't nearly as deep as my mind told me it was when I was on track.
- Sensing that I was "full throttle" all the way to the braking point...in reality...I started feathering and lifting well before the brake point.
- There were a number of passes I could have taken...I moved too early and gave up speed...then couldn't make the pass.
- Not having the car in the ideal gear for a certain turn/section...I can now see a couple of spots where it would help my car to drop into 2nd gear rather than staying in 3rd or upshifting into 4th rather than lifting while in 3rd to stay off the rev limiter.
Rick
Turn 2 is flat out in your car. You should never lift for this corner unless forced to do so by traffic or moisture. Turn 2 was a little wet during the enduro so if that was causing your lift that's OK. Otherwise take it flat out.
You should be going fast enough through turn 11 to need 4th gear in Thunder valley. You can then take turn 13 in 4th gear with only a brush of the brakes and then right back on the throttle. Lots of time to be gained there.
Colin suggested trying 2nd gear in a few places, and I definitely agree that you should try it, particularly in the Keyhole. Its also possible that you could increase your speed enough to make 3rd gear work for you in those corners.
In general you should understand your rpm sweet spot and try to make sure you're always in it. If your're far below it you should be in a lower gear. If you're just a little bit below it, then you should try to figure out how to go faster in that corner so that the higher gear works for you.
#142
Lifetime Rennlist Member
T2 is flat in almost everything. The only car I have driven where that is not the case was my old 993TT at ~525 HP and aggressive street suspension. It would push through T2 if I took it flat and really hurt the next two corners. It was faster to take it flat but some LFB to get front tire bite. You should follow the wisdom but at the same time be aware of what your car is doing and improvise as needed.
The best example is when it rains there. Usually you get rain back in T7 through the carousel then the track is much drier. This demands very different driving on different parts of the track and a real awareness of what is changing from lap to lap. MO in the rain tends to be an amazing experience because of this tiny micro-climate they get over the track.
#143
Hi Guys......
I was in the B group DE. I've enjoyed reading the discussion and thought I would also venture to post some of my footage.
http://youtube.com/user/uproar928S
Please keep in mind when offering your critique that this is a full weight 928 on street suspension and Kumhos. So there are a few things that my "husky" car won't tolerate.
I had a best ever lap of 1:45.1. I know that's not fast for most of you....but not bad for a street car that weighs over 3400 pounds.
Best regards.....
Ken
Best regards.....
Ken
#145
Basic Site Sponsor
Basic Site Sponsor
Damn that thing has some grunt. What'd you do to the motor?
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
#146
Ummm. Nothing really....just a 2.4 liter positive displacement supercharger with an intercooler.
I've done all of the work myself. The car was an automatic and I converted that as well to a 5 speed with 2.72 limited slip.
I do get a real kick dropping out warp behind someone who isn't suspecting something devious from a 928 guy.
LOL.
Best regards,
Ken
LOL.
Best regards,
Ken
#149
http://www.youtube.com/watch?v=_SvxKoocWyc
#150
