track etiquette for lapped drivers
#215
Originally Posted by Veloce Raptor
Larry, do you see things differently than what I posted?
What I can say is that he was closing very quickly, and there is not a whole lot of room there. Maybe if he could have timed it better, he could have slowed a little sooner, and still kept the E car between him and Charlie going into Big Bend. Then with the run that he had, box the 944 out going into the 2nd apex, and wind up in the same position without all of the drama.
But 20/20 hindsight has 100% accuracy, and the options you could have taken when reviewed on the video, you had to initially decide in a heartbeat. Would I have taken that pass? Probably not, but it also didn't have to be that dramatic. The 944 could have left racing room without impeding their own progress, and all Bob needed was one car width at the apex. If you look at the video again, you will see that the 944 really hurt himself, because when Bob got by, it made the 944 slow and it allowed the E car to pass as well. If he had let Bob pass initially, he could have kept the E car behind him.
I have made some hairy passes too, and at times have relied on the awareness of other drivers for it to happen. Splitting the 2 cars on my last lap at Road Atlanta comes to mind. If either car had not held their position, and had drifted inwards before I had drawn even, I would have been fixing both front fenders, and it probably would have been my fault. It would have cost me third position to wait and see what they would do, as 4th was directly behind me, and so for better or worse, that was factored into my decision making process. If 4th hadn't been right there, I may have waited a second to see which side might have been safer.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
#216
OK, fair enough. However, the blue X is clearly visible on the back of the 944. An experienced racer (like Bob) should have expected a reaction like that, especially from a rookie who had the line, and not forced it. However, when one has an entitlement attitude...well, we can all watch it on the video. Whereas Charlie was patient, and forced no one in that clip.
#217
What I can say is that Bob does practice what he preaches, and easily allows the leaders through; something he has to do frequently when the put his class in with the GT3 Cup Cars. He's not so easy when it comes to passing for position though, something I tried to do frequently.
#218
I really think that the Club Race organizers/stewards, etc. really should take the time in a classroom or pre-race gathering to reinforce the proper courtesies necessary regarding tracking several classes of cars at once. This isn't just for Rookies as the cars that I had issues with were not X'd..
1. Be AWARE of who is near you
2. If you catch a car in a higher class race him, pass him, etc.
3. If a car in a higher class car catches you (or is approaching/gaining rapidly), and you are not racing a common class car for position, try and give the opportunity for him to get by safely. This is equally true (IMO) even if you are trying for a good overall finish. If I caught you when you have no one in front/behind you guess what..
4. Be AWARE of who is near you
#219
#220
Colin, if you watch carefully, Bob's brake lights are on way before the 944's. And his brakes stay on well after the 944 comes off he brakes. Bob also seems way too tight to be on line. It appears that the 944 brakes, then comes off brakes to go back to power as he crosses the apex....but Bob has come from behind him and gone ag in order to deny him the apex, and in the process nearly pushes the 944 off track. Seems to me that Bob was trying to make an overly ambitious pass on a marked rookie car by going inside....didn't get ahead under braking...and decided to go for it anyway and hope the other guy would back down to avoid contact. Seems like a **** move to me, especially on a rookie.
Now, I respect Larry's comment. However, had Larry & TD been racing in the 944's for class position, I highly doubt Larry would have gone off line in that corner just to let God Himself in the form of Bob through (and thus allow TD's 944 to get way ahead).
#221
My issue is that the 944 was wide of the normal line into the first apex into big bend...by just about a car width. Then well past the 1 marker, he starts to cut it in. This is not the standard line. I can see how Bob would have thought that the 944 was "giving him room".
Btw, the two 944s were not racing for position.
#222
#223
Documenter of Ineptitude
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
#224
Watching that video, it seems there are two different lines into there. This is also borne out by other videos, including pro races. Yes, it is likely the 944 didn't see Bob...but Bob should have seen the blue X and not nearly rammed the guy off the track. Combined with his "But Since I might be in a hurry how easy he survives the corner depends on his consideration of the passing car" attitude + the fact that the 944 was ahead of him at turn in and most reasonable people will come to the same conclusion I did. Consideration goes BOTH ways in club racing, guys. Just because a guy "wins a lot" does not give him free reign to talk & act this way.
JMO....
JMO....
#225
so for scholastic purposes, if this ended in contact, which way would the 13/13 go? in 'favor' of the rookie b/c he doesn't know and makes mistakes, or point towards someone who ends up running into another, w/o regard whether that was a rookie or an experienced (faster) driver? both?
