Panamera 4 E-hybrid Owners Thread
#1126
I am one of the lucky first Panamara e-hybrids delivered in March whose GPS system is unable to get a signal from any of the 24 GPS satellites. My dealer swapped out the module and antenna once, but the replacement was broken, too. How many of you are having the same problem?
I spoke with PCNA this afternoon,. as well as my dealership, and there is no update available for when or if Porsche will have replacement modules and antennas available. If anyone hears anything, I would appreciate your posting an update here.
#1127
heard something similar from my SA here in Austria. Porsche is switching to WLTP measurements as of September and getting all the certifications could be tricky. MY19 should therefore be available as of November the earliest. That is why they are trying to get as many MY18 on the road as possible by September.
#1128
I took delivery of my long waited 4 e-hybrid Sport Turismo on last sat. Given it is a new car and needs time to run in, I haven't really tested its performance. With my limited city driving, I am a bit disappointed with the battery. I have the 7.2KW onboard charger, but I haven't installed a 240v charger at home yet. It took me 13 to 14 hours to fully charge the car by using the conventional 110v outlet. According to the manual, I can only take advantage of the 7.2KW charger if I use 240v. Anyway, once fully charged, it says I can go for 49KM (30 miles), but as soon as the car left my garage, it went down to 45KM, and before I drove 4 or 5 KM more, it says my range went down to 35KM. It seems that the battery under normal driving condition (A/C, radio, NAV and etc), it can only last 25-30KM at best. Also, even I am in e-mode, sometimes the engine just kicked in by itself even I don't push very hard (especially going uphill!)
Also, I thought they didn't put in the rear-wheel steering option that I ordered as I cannot notice it is working or not. I have to ask my wife to get off the car to look whether the rear wheel is turning (it did)!!! I drove a 4-wheel steering car many many years ago and I remembered it felt very different than a normal car, but not with this Panamera.
I am still getting used to ACC/PID and night vision and etc. At first, I was nervous, but after a while, they do work well, except once the car slowed down or stopped, it doesn't pick up very fast when the car in front accelerates and that leaving big gaps for cars in the adjacent lane to cut in, which sometimes can be dangerous.
The suspension works really well even I have 21" wheelset. It goes over potholes and bumps very smoothly.
For some reasons, I seem to have problems with the memory function, every time I get back to the car, I have to turn on the A/C, and re-adjust the seat. Also, the car sometimes "forget" my favorite setting on the steering wheel and I need to do it again and again. I need to look into that......
The Porsche connect app is very basic, and it takes a while to refresh the status. I thought I can search/enter a destination and send it to the car, but don't know how to do that yet.
That just my brief review from the last few days of short drives.
#1129
KW - the battery just needs training and no way will it go 30 miles city driving anyway - as much as a quoted 40 mpg car will do 50 on the motorway and 25 in town - stop start low speed driving is not efficient.
Memory should work - just make sure you don't go in with 2 keys - sometimes my wife has her key and if you are in the car with both it gets confused/doesn't put it in either mode particularly!
Don't worry about run in time, just hit sport plus and bury it - you need to turn your frown upside down!
#1130
My SA was not very helpful when it came to figuring out what electrics likes you need to take advantage of the 7,2kW onboard charger. He said you needed 400V and 32 Amp. I was disappointed as I only have 400V 16 amp in my garage. Nevertheless, I took the charger as an option as I thought it might come in handy when I am charging the car away from home. However, after ordering he car, I did some math and this is what I want to share with you:
To calculate how much time you need to charge your car, you need 3 the following information:
1) voltage of your electricity supply
2) current
3) number of phases (1, 2 or 3)
To calculate the power:
For 1 or 2 phases:voltage x current
For 3 phase: voltage x current x 3^0,5
So in my case at home I have the following combination 400V/16amp/3phase:
400x16x1,732=11kWh
Depending on the charger you have in the car (3,6 or 7,2), and assuming 15% loss, the time needed to charge the car will be the battery size (14kWh) divided by either the charger value of your car or your electricity supply at home, whichever is lower:
In my case 7,2 is lower is than 11 so I can take advantage of my charger in the car. Assuming a 20% loss in efficiency from charging, 7,2 becomes 5,8. So to charge a 14kWh battery, like we have in our cars, I will need 14/5,8= 2,4 hours. I can only confirm this number in 2 months when my car arrives :-)
Obviously any electrical engineer here is feel free to correct me if I just wrote some BS :-)
2) current
400x16x1,732=11kWh
#1131
4 months and still waiting, oddly it can work even with no satellites connected, but does lose itself sometimes, and strangely in the exact same place, within metres ?
As far as I have been told by a contact at PCGB they keep rejecting new batches from their supplier. But that makes me wonder what they are putting in new cars ? - Surely they must be putting in antennas they know not to be up to the job ?
At last count I am aware of 4 batches being rejected. I have lost the will to be interested now, but keep looking at the goodwill amount adding up - make sure you complain and get something out of PC - such as the Precision school and a supplied car
Complain to your dealer in first instance, get a case number, then get onto PC customer services.
#1132
I have driven hybrids for 3 years, both me and my business partner has.
Your not going to get 30 miles round town, as AJ says, you would not expect your engine to do the same in town as a motorway, your battery wont either.
The more harder you drive the car in battery the more juice it will use, even if its just increasing power to get up hills it will use more juice, and the more accessories you have on, such as AC, heated seats etc the more juice you will drain.
If your driving Miss Daisy then you will get more miles, whether city or motorway.
The only way you will see maximum mileage is on a motorway, and only when you are doing a number of charges per single trip, as it will calculate your range through the history of the latest trip/charge. - just like it would with the engine.
I have, in my previous S -E Hybrid ( that was 22), but its rare.
#1133
Has anyone been able to send navigation destinations from the iPhone Connect app to the PCM in the car. I took my car to my dealer and he swore that it is possible but after about an hour of him and another technician playing around they couldn’t figure it out...I would regularly use this function so if anyone has experience setting it up pls let me know?
#1134
My battery for the first time in 6 months went up to 46km indicated range, which is 8km more than I have ever seen before. I have no idea why it has suddenly started to behave. I have done nothing different. In France I am only charging at 3kw. The real electric mileage you will get is very "slope" dependant and given the freewheeling nature of the car and its 2300kg weight, it's not surprising. Going downhill to my nearest medium sized town in France, about 12km away only consumes 2 to 3 km of battery. However on the way back up, it needs at least 35km range indicated, before it will get the 12km back home without starting the ICE.
Wilson
Wilson
#1135
K777 - interesting what you say about the antenna. Mine is due to go back in on Monday to have this looked at but is there any point if they haven't got the antenna in stock? May ask the dealer to confirm.
#1136
Now, Leeds allocate me a car (since mid April), and then contact me the day before to advise if the parts arrived (usually I have already found out from Reading that it isn't available), then Leeds allocate me a car in a couple of weeks, recurring etc.
So I would suggest you call them the day before and ask if they have it physically.
It seems they show in stock in Germany, but never make it to Reading and so never make it to the dealers.#
#1137
I suspect the hill is quick significant.
The other thing you can do is take it in to the dealer and ask them to check the battery and all its cells are all charging fully , but I would expect you to have an error message saying "Epower not available - ok to drive on engine" if the system detected any fault at all with the battery.
#1138
If you are going up hill mostly back the 12km then you will not just use 12km of battery range ( you wouldn't use the same petrol down hill and uphill) , downhill you will be also charging a lot, as you coast or brake, uphill you will not be recharging either. Your range of 35km is because the car is looking at the previous trip (or maybe trips), as in the downhill trip. So it indicates a high range for the downhill trip you just made. What is the range at the top of the hill when you are charged up again ?
Wilson
#1140
2) current
400x16x1,732=11kWh
2) current
400x16x1,732=11kWh
