Macan EV Discuss the 2024 Porsche Macan EV
Macan EV: if you’re ordering EV ~ post your build
Old 08-04-2024, 07:56 PM
  #211
bbmertz
7th Gear
bbmertz's Avatar
Default Macan 4S Build
Here’s the Macan 4S I’m planning to order. I intended to order a 4 but the 4S was only a few thousand more and would be a MY25. I’m trying to keep the cost down and don’t plan to take it on the track, so I didn’t add any of the performance enhancing options. Only additional option I’m considering is the GT Sport steering wheel but am concerned it might reduce dashboard visibility due to the smaller diameter. https://configurator.porsche.com/porsche-code/PSM3JDV6
I was an early adopter of the Tesla S and Y which I really enjoyed, but am looking for an EV which is more sporty and higher quality now that there are other options on the market. I initially planned to order a base 2025 Taycan but the Macan costs $18K less even when ordered with far more features, plus it has a longer range and a tow hitch option.
Old 08-05-2024, 02:18 PM
  #212
mb1
mb1's Avatar
Oddly, I don't see the Power Charge Port Cover (2W9) on the configuration for the 4S, but it is a searchable option. Am I missing it somewhere? Not included on the standard equipment page. Also, any idea how hard it is to get calipers painted after delivery?
Old 08-06-2024, 02:36 AM
  #213
marcocean
Cruisin'
marcocean's Avatar
Going for the 4s now. Seems like it’s worth the extra money for what you get compared to the 4. Tried to keep it as close to $90K as possible. Will be my first Porsche.
https://configurator.porsche.com/porsche-code/PS5NVYW7
The following 2 users liked this post by marcocean:
bbmertz (08-06-2024), TC Cruising (08-06-2024)
Old 08-06-2024, 06:21 AM
  #214
bbmertz
7th Gear
bbmertz's Avatar
You’ll find it under the last E-Mobility section in the configurator.
Old 08-06-2024, 06:33 AM
  #215
Awas
Awas's Avatar
Nice.
I would have preferred Augmented Reality HUD, instead of rear axel steering. I was keen on RAS too, but my Porsche dealer insisted it's not necessary in a car of this size.
Besides, you won't feel anything missing if you never used it before. Anyway, in the end, these are all personal preferences.
Old 08-06-2024, 06:49 AM
  #216
bbmertz
7th Gear
bbmertz's Avatar
I agree with Awas in that I’m not sure you need rear axle steering since the Macan has a relatively tight turning radius. I’d instead consider the 14-way seats which you will use every day.
Here’s my 4S build although it’s about $3K more than you were planning to spend. I’ve been driving Teslas since 2013 but excited to switch to Porsche.
https://configurator.porsche.com/porsche-code/PSQEKBB7
Old 08-06-2024, 07:19 AM
  #217
Awas
Awas's Avatar
Here is someone who had a day-to-day experience with RAS. Interesting to watch - His RAS experience starts from 12:57
Old 08-06-2024, 08:30 AM
  #218
tmrqs
tmrqs's Avatar
Originally Posted by Awas
Nice.
To add a counterpoint @marcocean, there was a convo on this previously, question was whether it made sense on a Macan - general impression was that it was indeed not as useful as on a Taycan.
As it turns out, the Macan has a higher turning diameter than the Taycan, and marginally better with RWS.
Turning circle diameter:
- Macan EV (no RWS): 39.7 ft
- Macan EV (RWS): 36.4 ft
- Taycan (no RWS): 38.4
- Taycan (RWS): 36.7 ft
So if it’s useful on the Taycan, definitely worth considering on the Macan too. I ended up spec’ing it myself.
Every Cayenne driver I spoke to swears by RAS - naturally not the same type of car as a 992. Hoping to get more feedback over the next 3 days as I’ll be at PECATL and then Barber.
Old 08-06-2024, 08:41 AM
  #219
Awas
Awas's Avatar
@tmrqs
Cayenne is a bit bigger than Macan though.
Basically, I went with my Porsche dealer's advice. He said he had driven this car in Germany and didn't think it's an option I really need.
I thought he was being honest at least and not selling me more options to make more money : )
By the way, that video I posted, the guy says, initially he liked RWS a lot but not any more. So, I guess it's got positives and negatives.
tmrqs (08-06-2024)
Old 08-06-2024, 09:04 AM
  #220
tmrqs
tmrqs's Avatar
@tmrqs
Yes and no.
The Cayenne, Macan and Taycan have pretty much the same wheelbase:
- Cayenne: 114 in
- Macan: 113.9 in
- Taycan: 114.in
To my previous post, if Cayenne and Taycan drivers recommend it, it could easily apply to the Macan.
The 992 on the other hand has a 96.5 in wheelbase - and is quite a bit lighter than the other 3.
Some dealers told me to get RAS, others to skip it. Drivers I talk to (not 992 drivers granted) also recommend it.
Not easy to make a decision without trying it. Hopefully will learn more tomorrow!
Old 08-06-2024, 09:31 AM
  #221
Awas
Awas's Avatar
Originally Posted by tmrqs
Yes and no.
I guess, that's the best way to find out to get first-hand experience.
But then again that Rennthusiast guy liked it too at first in his 992 : )
As I understand, he thinks it makes his Porsche drive “too surgical”. But I guess, Macan's handling is already pretty good without RWS, with its all-wheel drive system, torque vectoring system, an electronically controlled differential on the rear axle etc. A bit of drift in cornering could be more fun without RWS : )
Old 08-06-2024, 09:54 AM
  #222
TC Cruising
TC Cruising's Avatar
Listening to the videos of those I trust the most such as savagegeese, Kyle/OutofSpec,Autogefuhl, Smoking Tire, and Edmunds, etc., we are definitely getting RWS. If nothing else it will allow us to back out of garage (tight turn) with the extra back and forth to turn it around and head out the driveway facing forward.
Old 08-06-2024, 10:35 AM
  #223
Awas
Awas's Avatar
Yes, that is true. I watched all of those videos too and hence was keen at getting RWS too as mentioned above, before I got dissuaded by the Porsche dealer.
Besides, all those reviewers you mention drove the Macan for how long? And just like those reviewers, that Rennthusiast guy also liked RWS to begin with too : )
Old 08-06-2024, 11:23 AM
  #224
digli
digli's Avatar
A 1m (3.3 ft) reduction in turning radius is significant when navigating tight urban driveways, laneway garages, parallel parking, etc. Also, has anyone noticed how tight underground parking garages have become? For my use case as a daily driver in an urban environment, a tighter turning radius is huge plus. And if the handling at speed improves to the point of becoming "surgical", I'll take it.
The following 3 users liked this post by digli:
bandrews (08-07-2024), beye (08-06-2024), TC Cruising (08-06-2024)
Old 08-06-2024, 03:15 PM
  #225
beye
beye's Avatar
Same here: I spec’ed it because underground parkings are so tight, it is a big pain because of the wheelbase when there are long tight turns with borders! (They like this kind of thing in Europe).
First day with my TMS, years ago, I was unable to exit the parking without scratching my rear left wheel… Shame on me.
I never drive a car with RWS, I hope the « surgical » behavior you’ve mentioned is not a « comfort issue » for both driver and passengers.
Quick Reply: Macan EV: if you’re ordering EV ~ post your build
