Sponsored by: APR
Best Track Times in a GT4
Old 12-04-2016, 02:22 PM
  #466
jslee225
jslee225's Avatar
Originally Posted by matttheboatman
Nice, sounds great too! Updated!
Thanks Matt for maintaining this thread!
Old 12-04-2016, 05:58 PM
  #467
ShakeNBake
ShakeNBake's Avatar
Originally Posted by jslee225
COTA - 2.2882 - WRL / Momentum HPDE 12/2/16 - 19" RE71r 285/265 - Track Alignment, 19" OZs, Pagid rs29, Castrol SRF, Fabspeed Race Headers
https://youtu.be/fNlIikIqMrg
DANGgggggggg!!
Old 12-05-2016, 08:08 PM
  #468
jslee225
jslee225's Avatar
Originally Posted by ShakeNBake
DANGgggggggg!!
Thanks Jacy. A few observations from this DE.
Need to get over my newly found fear of turn 3 & 4 . Also, I think I need to short shift into 4th in the carousel b/c I'm always running out of gear, but i don't know if it's worth it due to having to manage to downshift right before turn 19? Also, car feels nervous in the carousel as well causing me not to get WOT until late. Maybe thinking about going back to M/M swaybar setting and getting more rear toe.
Advice from ANYONE is greatly appreciated!
Old 12-05-2016, 08:56 PM
  #469
ShakeNBake
ShakeNBake's Avatar
I upshift to 4th going into T2 and T16. T19 is tricky to downshift no doubt. You can carry 4th through T19 without loosing much, but it is possible to downshift if you are super smooth and get a nice clean controlled exit from T18. You should be able to be close to flat foot through 17 and 18 if you're in 4th, and it's way easier to modulate the throttle as well...as you move weight around fighting under and oversteer at the limit there. You might feel it being nervous if you've dialed out the understeer...it's all about balance. Do something to move a bit of balance to the rear like stiffer front/softer rear, or let some air out of the rear. Does not take much. A big adjustment might make it push again.
Old 12-05-2016, 09:26 PM
  #470
Veloce Raptor
Veloce Raptor's Avatar
Received 1,580 Likes on 825 Posts
Josh, definitely short shift to 4th in the carousel...it'll also solve the nervousness
And take 19 in 4th
Old 12-06-2016, 12:03 AM
  #471
jslee225
jslee225's Avatar
And take 19 in 4th
thanks guys great advice! I'll definitely try it out next time!
Old 12-06-2016, 11:58 AM
  #472
myBailey07
myBailey07's Avatar
And take 19 in 4th
Def 4th for the carousel, and as Dave showed, me, if you shift right as you approach the second apex it actually helps rotate the car, letting you be on throttle sooner.
I shift down to 3rd for 19 as I have to brake there anyway and then I only need one shift into 20, but then again, I am chickens###t as far as not going faster through 19.
BTW, now after having run the re71's I am convinced their grip level is super close to the R7's. That is a sweeeet tire!
Old 12-06-2016, 12:20 PM
  #473
jslee225
jslee225's Avatar
How close in your opinion are the two tires? I was hoping Hoosiers were worth 2-3 seconds as most have stated b/c was planning going to go Hoosier fulltime after a couple more sets of RE71.
Old 12-06-2016, 12:22 PM
  #474
gtreddy
gtreddy's Avatar
Does anyone know what happened to the yellow GT4 that was there? He was in front of me, puffed some smoke going into T1 and then seemed to have problems getting the car to move under power. He pulled off at T3 and was gone the next time I came around. This was on the first advanced session of the day.
Old 12-06-2016, 12:35 PM
  #475
myBailey07
myBailey07's Avatar
Purely my opinion - I think the R7s are at best 2 secs faster at cota than re71's for no more than 8 sessions. After that they are equal with the 7's dropping off fast. Not sure where the crossover is and the r7's actually become slower, I would guess around 12-16 cycles.
BUT, I don't have concrete data and this is my speculation. Ortojoe also pointed out that the re71's handle heat better and more consistent over a session and that is often more important in DE environment as you never know when you will get a clean lap in.
Going forward I will only run R7's in select cases where best lap times can be reasonably expected - cool weather, dry track, fast groups with passing everywhere. Any other time, for me, running R7's over RE71Rs are simply pissing money away...
Again, lots of opinion...
Old 12-06-2016, 04:06 PM
  #476
jslee225
jslee225's Avatar
Wise man! Makes sense, and i'll probably follow suit! Can't wait to try Hoosiers
Old 12-06-2016, 04:19 PM
  #477
ShakeNBake
ShakeNBake's Avatar
That would be awesome - but I need another set of wheels for the 71s. At the BMW event, the R7s I was running were on their 4th day (about 14-16 cycles) and the best I could muster was a 26.8 with unicorn hairs mixed with my coffee. Fun, but not fast.
Old 12-06-2016, 04:46 PM
  #478
jslee225
jslee225's Avatar
Jacy, that is moving! Would love to get a reference lap next time so I have something to aspire to
Old 12-06-2016, 04:50 PM
  #479
Veloce Raptor
Spot on about using a short shift to gently aid rotation. Underrated underutilized and under appreciated
Old 12-06-2016, 05:12 PM
  #480
ShakeNBake
ShakeNBake's Avatar
Are you using racelogic? I can open up a folder a few of us use to share lap data in circuit tools. Otherwise I'll upload lap to youtube...not a reference by any means.
Quick Reply: Best Track Times in a GT4
