Sponsored by: APR
Experiment - GT4 Track Setup Wiki:
Old 07-01-2016, 11:16 AM
  #211
John@Fabspeed
Basic Sponsor
John@Fabspeed's Avatar
Originally Posted by BGB Motorsports
Send it down! There are several GT4 owners on the West Coast that drove our latest Cayman R with the 3.8L X51 swap and they all said the same thing "can you make my GT4 pull like that through the middle of the rev range?!"
I might just take you up on that John, just going to be a while until i'm out of recovery mode from the initial car purchase, apartment, marriage, and honeymoon...within three weeks lol
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
Old 07-01-2016, 02:43 PM
  #212
trebien
trebien's Avatar
Originally Posted by mooty
it's a corvette with porsche precision.
Is the air freshener hanging from the rearview mirror a can of Axe body spray?
Old 07-01-2016, 02:54 PM
  #213
vantage
vantage's Avatar
In the stock system, would front caster definitely be out of wack at -2.5 front camber? That's about all I need to go for my use, so wondering if additional parts are necessary at this level. The Wiki makes it sound like the answer is yes.
Old 07-01-2016, 03:02 PM
  #214
ExMB
ExMB's Avatar
Received 1,366 Likes on 831 Posts
Part of your answer will have to be determined by what wheels, tires you use, track, skill level, etc.
I have -2.6 on the front with 20 x 9 ET55 wheels with OEM tires and have as yet to encounter rubbing on the tracks I frequent while running in advanced/instructor groups.
Old 07-01-2016, 03:09 PM
  #215
vantage
vantage's Avatar
I'll be running OEM wheels / tires (right now Dunlops, may switch to PSC2 next set). I tend to run fast intermediate, so sounds like I will be fine.
I guess only issue then for me is which shims to buy!
Thanks.
Old 07-01-2016, 03:16 PM
  #216
jphughan
jphughan's Avatar
In addition to what ExMB said, it will probably also depend on how much camber your car can achieve stock. I'm running -2.5 camber in the front, and centering the wheel in the well required 8.8 caster, down from the 9.5 I had when I was only running -1.5 camber. I personally would have been concerned about rubbing issues stepping up to -2.5 camber without the ability to dial back the caster (I'm on stock wheels as well), but I can't say for certain that it would have been a problem.
  #217
GrantG
GrantG's Avatar
Received 5,050 Likes on 2,850 Posts
Could some of that be due to the better gearing in the 987? I thought the advantages of the X51 would be closer to redline. In any case, sounds like a huge improvement!
Old 07-01-2016, 03:46 PM
  #218
ExMB
ExMB's Avatar
I believe RSS has a package deal on those. Even if you wind up with extras its still cheaper than buying them individually.
Old 07-01-2016, 05:08 PM
  #219
jphughan
jphughan's Avatar
Yes indeed: http://rss.rpmware.com/rss/rss-align...i-1890057.aspx
Old 07-01-2016, 09:05 PM
  #220
Errsomeone
Errsomeone's Avatar
To follow what others have noted... I am running -2.5 camber in front by using only the Motorsport shims (and not lowering). Also using stock wheels. No rubbing found after events at VIR or WGI.
Old 07-01-2016, 10:07 PM
  #221
myBailey07
myBailey07's Avatar
-2.5 is probably at the limit of where you can go without the caster pucks. It is going to be a bit car and track specific. If I remember correctly, I rubbed just a tiny bit at the front of the wheel well at a very high compression track (TWS) while I was fine at the others.
My guess is that with oem wheels most would be okay at -2.5. It is also a relatively easy change and you can go without it and add the caster pucks if you do rub.
Old 07-01-2016, 10:41 PM
  #222
Errsomeone
Errsomeone's Avatar
Agreed. I don't think I could/would go further without additional modifications. Also not sure if more aggressive offsets would work. It is a little tight. But the compromise between street and track seems to work for my purposes at the moment.
Old 07-02-2016, 12:50 AM
  #223
GT4Tony
GT4Tony's Avatar
Thank you so much for compiling this wiki! Extremely valuable. Went with the moderate suspension setup and will progress as I get more seat time.
Camber:-2.5F, -2.0R (Shims + Tarett rear toe links w/ lockout)
Toe: .03/.03 (F). .14/.14(R)
Front Caster: 9.78(L). 10.35(R) Will listen for rubbing. Maybe should have done the thrust arm bushings at the time too.
1/2" lower. Factory rake maintained.
CB w/ full ext. tank. 686(LF). 689(RF). 853(RF). 867(RR). CW: 49.8% and 50.1%
First oil change (1300 miles). Millers Nano CFS 5W40, went with Intersport's recommendation.
Can't wait for Summit in a few weeks to enjoy her!
Old 07-03-2016, 10:34 AM
  #224
ML///
ML///'s Avatar
For the main page under oil changes - can we please add the link to the tools we need and torque specs?
This way we can create a comprehensive "go to" page for track and track maintenance.
I can't wait to see how this car feels on track. The steering is pretty freaking awesome. However, I have found that I cannot heel-toe very well in this car. The brake bit is high and the throttle is much lower than some of my other track cars. Are others experiencing this same feeling? I will say that when I drove a 981 Cayman S I was able to heel-toe with ease - I'm talking EASE. It was a gem to drive on street.
Old 07-03-2016, 10:42 AM
  #225
ShakeNBake
ShakeNBake's Avatar
And ways to clean oil from human skin.
Quick Reply: Experiment - GT4 Track Setup Wiki:
