Sponsored by: APR
0Q Pure White - journal
Old 07-21-2021, 06:59 PM
  #286
d00d
d00d's Avatar
Loud, but Ti light!
Old 07-29-2021, 03:26 PM
  #287
d00d
d00d's Avatar
The distributor for Akrapovic confirmed they're not interested in making any more, even for a group buy, sad!
I'll have something interesting from Cargraphic installed in a few weeks though.
Snowy999 (07-29-2021)
Old 09-11-2021, 04:17 PM
  #288
d00d
d00d's Avatar
The custom Cargraphic exhaust valve controller override module came in two days before the NCR PCA DE at Club Motorsports in Tamworth, NH (clubmotorsports.com).
It was my first DE since buying the GT4 over five years ago, so long overdue.
There's 250' of elevation change, which didn't seem like much from the car, but I realized was much steeper on the end of day track walk.
Much thanks to my instructor and fellow GT4 owner Nick, who among other things provided great insight into how to best get around the course.
First session I left the module in automatic mode and wasn't black flagged, which I thought odd since I have headers without catalysts.
Second session I was flagged for being `way over' 92dB.
If you see a fellow on a bicycle pointing something at you from the perimeter road, this is the sound man.
I was fine after setting to the third mode of always closed, and didn't have any overheating issues.
Second mode is always open.
Cargraphic has both two and three mode versions for the 781 GT4, but only two mode for the 981.
They made me a custom three mode version for the 981 GT4.
BGB should also be able to get this for you.
https://www.cargraphic.de/en/your-ve...ayman-gt4-40l/
https://www.cargraphic.de/en/your-ve...81-gt4-cs-38l/
It didn't come with instructions, and I didn't take pictures because of limited time.
The 981 valve controller is easily accessible on the top right of the intake manifold (see post 4), where the one for the 781 is hidden under the left side of the intake.
The two cables connecting to the Cargraphic unit are run under the engine bay cover similar to the 781;
https://rennlist.com/forums/718-gts-...trol-unit.html
I stuck the unit on the top of the right wheel well above an ECU, and captured it's ground wire under the ECU mounting nut.
The red wire doesn't have a connector on the end to plug into an open slot in the fuse block like the one for the 781.
To the right of the ECU there's a fuse block.
The fifth small fuse from the right, a 15A, has two wires coming off of the back.
Used a T connector left over from a Valentine One kit to tap into the smaller diameter wire.
Top left button (unlock) is always open, top right is automatic, bottom left (lock) is always closed.
Old 12-10-2021, 12:31 PM
  #289
d00d
d00d's Avatar
Tips and a video of Club Motorsports from Michael J. Ruggiero.
File Type: pdf
File Type: mov
Snowy999 (12-10-2021)
Old 02-20-2022, 11:43 PM
  #290
d00d
d00d's Avatar
Got a home near the track so I can have a proper lunch before heading back.
The following 2 users liked this post by d00d:
Crazy Eddie (02-21-2022), Milksteak (03-10-2022)
Old 03-03-2022, 09:29 AM
  #291
d00d
d00d's Avatar
National Bank of Ukraine is accepting donations to the Armed Forces via Google Pay, credit card (sent $1K), or bank wire;
https://bank.gov.ua/en/news/all/nats...potrebi-armiyi
https://hotair.com/karen-townsend/20...inians-n452460
https://ukrainewar.carrd.co/
burnergt4 (03-03-2022)
Old 03-03-2022, 11:59 AM
  #292
burnergt4
burnergt4's Avatar
Matched your donation, my friend. Ні війні
d00d (03-03-2022)
Old 03-04-2022, 11:29 PM
  #293
user1029
user1029's Avatar
I’ve donated a lot in Bitcoin to Ukraine’s military Come Back Alive organization because **** Putin.
https://savelife.in.ua/en/donate/
The following 5 users liked this post by user1029:
burnergt4 (03-05-2022), Crazy Eddie (03-04-2022), d00d (03-05-2022), maschinetheist (09-23-2022), RocketGuy3 (07-12-2022)
Old 06-01-2023, 09:16 AM
  #294
d00d
d00d's Avatar
Another plate holder modification that allows it to sit flat against the bumper without gaps.
Old 07-13-2023, 08:04 AM
  #295
blacksheepSpyder
blacksheepSpyder's Avatar
I seem to be stuck here, can't get this damn connector loose. Help please!
Connector at oil tube...
Old 07-13-2023, 08:18 AM
  #296
DR.S
DR.S's Avatar
It is fiddly because the nose is from the other site.
Just gently lift / wiggle with some plastic wedges and it will eventually come loose.
If it should brake, it will be no drama.
Old 07-23-2023, 02:38 PM
  #297
d00d
d00d's Avatar
It's almost impossible to unlatch this cable assembly from the clip on the oil fill pipe (post 2, diagram 1, part 21), as the latch is underneath and only accessible from the end facing the pipe.
To remove it I had to chisel off the top end of the connector.
When I installed the new one I left it unlatched.
Good to know this is possible without breaking anything.
Old 07-23-2023, 02:46 PM
  #298
d00d
d00d's Avatar
With these I was able to pass Club Motorsport's 92dB limit this year without keeping the valves closed, which had caused the car to go into limp mode.
https://www.cargraphic.de/en/your-ve...81etcupersilx/
Old 07-24-2023, 07:46 AM
  #299
blacksheepSpyder
Completed the CS/GT3TB install. I didn't expect the car to be so much faster. I would now call it spooky. Dyno numbers are one thing. Spooky fast is something else.
Old 07-24-2023, 07:51 AM
  #300
blacksheepSpyder
Oh yeah the trick to getting that clip off the oil tube is, insert a large flat blade screwdriver in the top part of what looks like a square and twist. it pops right off and unbroken.
Quick Reply: 0Q Pure White - journal
