Sponsored by: APR
Track Pads for GT4
Old 10-13-2016, 11:13 AM
  #91
Clark-ApexPerformance
Basic Sponsor
Clark-ApexPerformance's Avatar
Joe,
Thanks for your imput. The initial bite being not as much is the same thing I have heard from everybody that has purchased them...but you are the first to offer a direct comparison.
Clark
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: chamerly@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist-10 on your next order or mention Rennlist during your phone order.
PCA Club Racing - National Sponsor
Old 10-13-2016, 11:37 AM
  #92
ExMB
ExMB's Avatar
Received 1,355 Likes on 826 Posts
Originally Posted by orthojoe
I've driven a GT3 with the ds1.11 and then a GT3 with the RE10 pads back to back on the same day. The initial bite of the re10 is not as good as the ds1.11. Otherwise, not drastically different in terms of feel
I know you have driven the PFC11s as well. How is their initial bite compared to the RE10s. I know you said back then that the Ferrodo initial bite was better than the PFCs.
Thanx
Old 10-13-2016, 11:52 AM
  #93
orthojoe
orthojoe's Avatar
Thanx
It's been over a year since I last drove a car with pfc11. From what I remember, the initial bite is similar to ds1.11, but max torque required less pedal effort for ds1.11. If you are the type that hits the brake pedal as hard as you can, the pfc11 might suit your style better because if you do that with the ds1.11 it will lock the brakes and it will feel like it is not stopping well because of abs. Conversely, if you don't hit the brake pedal with all your might, the pfc11 will seem like it requires too much effort to stop the car.
Old 10-13-2016, 12:03 PM
  #94
Manifold
Manifold's Avatar
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,294 Likes on 2,447 Posts
I've been using the ds1.11 on the GT3 for a while, and have liked them. But based on the good reviews of the RE10, including the reports of them lasting substantially longer than other pads, I'm going to give them a try on the GT3, and likely the GT4 also.
I used to favor a lot of initial bite, but as my braking technique has improved, I've come to prefer a moderate initial bite, so that I can modulate more precisely.
Old 10-13-2016, 05:31 PM
  #95
Beantown Kman
Beantown Kman's Avatar
+1. I feel the same as Manifold. A more aggressive compound, with more initial bite, will stop the car in a shorter distance. But they are likely to result in more chassis/platform unbalance as you get on and off the brake. And it is harder not to overslow the car. As Manifold said, learning to modulate the brake precisely is easier with a less aggressive compound.
Old 10-13-2016, 05:36 PM
  #96
GrantG
GrantG's Avatar
Received 4,948 Likes on 2,802 Posts
Originally Posted by Alex@PE
The Race Technologies RE10 has absolutely been our favorite pad.
Modulation is incredible.
Lifespan is longer than any other pad we've tested in similar conditions.
It does certainly dust and make a bit of noise, but by no means as loud and aggressive as others.
Very easy on the rotors!
Feel free to get in touch with us on any inquiries! We do carry PFC and Ferodo as well.
I love them too. I sold my GT4 and have a set (for all 4 wheels) of barely used RE-10's left over available for sale. PM me if interested...
Old 10-13-2016, 06:01 PM
  #97
Manifold
Manifold's Avatar
I think that having more initial bite can give the *impression* of more slowing/stopping power, but less bite can be compensated by more pressure to slow the car as desired, and in my experience better modulation is the key to deeper braking points.
Less initial bite also has benefits in terms of better modulation when braking more softly (below threshold).
A further benefit of less initial bite (and better modulation) is being able to stay closer to threshold without activating ABS, resulting in less heat in the brake system.
Old 10-13-2016, 07:27 PM
  #98
Macca
Macca's Avatar
Let's not forget the RE10 are much kinder to the rotors going by the amount of use Trakcar had been getting from his OEM rotors after running a few sets of RE10 in Europe and USA.
To me this is a big plus as after tires OEM rotors are the biggest running cost on the GT3....
phefner (02-05-2020)
Old 10-13-2016, 07:28 PM
  #99
Macca
Macca's Avatar
Grant - have sent you PM...
Old 10-13-2016, 07:48 PM
  #100
4carl
4carl's Avatar
Received 1,138 Likes on 607 Posts
bigger bite does mean less heat because the pad makes contact for a shorter period of time ..
Old 10-13-2016, 08:15 PM
  #101
orthojoe
orthojoe's Avatar
Much kinder to rotors compared to oem?
I had 30 days on my ap rotors using ds1.11 before they accidentally were destroyed by running the pad down to the backing plate. The rotors would have lasted 40 days.
I'm currently on 12 days with oem rotors on my gt4. They probably have another 2-3 days left in them
Old 10-14-2016, 01:05 AM
  #102
DC640
DC640's Avatar
but joe, you drive so fast, of course rotors will melt =)
Old 10-14-2016, 01:40 AM
  #103
orthojoe
orthojoe's Avatar
They melt when you scrape backing pad straight onto the rotor! Lol
Old 10-14-2016, 03:53 AM
  #104
Macca
Macca's Avatar
Much kinder to rotors compared to oem? I had 30 days on my ap rotors using ds1.11 before they accidentally were destroyed by running the pad down to the backing plate. The rotors would have lasted 40 days. I'm currently on 12 days with oem rotors on my gt4. They probably have another 2-3 days left in them
Yip. OeM pads. Best I can get is 9 days from front rotors. Hoping to double that with the RT RE10 pad. AP j hook rotors obviously go twice the distance again...
Old 10-14-2016, 03:57 AM
  #105
Macca
Macca's Avatar
That sounds about right for the GT4 OEM front rotors. Guys here getting roughly 15 days from them on OEM pads. Generally they run thickness limits before they do the big cracks like the GT3. I'm guessing different weight distribution, lower vmax, good front down force and less weight helps them last longer on the GT4
Quick Reply: Track Pads for GT4
