Orthojoe's GT4 track thread and ramblings
#1081
So ds1.11 fronts only give 6-7 days? I remember a post early on where you predicted getting 12 days out of them, but perhaps I'm making that up.
#1082
Originally Posted by Yargk
Thanks for the info. I have ds1.11s on the GT4 and currently ME20 on the rear of my subaru and DS2500 on the front of the subaru. I'd like to try ME20 on the GT4, but I'm being cautious since pads can sometimes unevenly wear rotors and rear pads are a big commitment (lots of track days).
#1083
When you say 4mm toe, is that measured based on the 20" wheel or the entire diameter of the RE-71? Since my alignment guy works in degrees or minutes, would need to know this when doing the conversion.
#1086
#1087
2) Most likely the machine was programmed with the vehicle info and did the adjustment from there; which usually includes tires since some cars can have different sized wheels but yet maintain the same OD.
#1089
I have 3/16 inch total toe (~4.8 mm total toe) in the rear and after two days with RE-71R I've noticed that my rear tires are wearing more quickly than my fronts. I was wondering if you had enough data yet to tell whether your rear tires wear less with 4 mm total toe in than with 6 mm?
#1090
#1092
Hey OJ. Clean out your PM inbox.
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
#1093
After 13 track days running Ferodo DS 1.11, I have 55% left on LF, 82% left on LR, 55% left on RF, and 82% left on RR. I'm going to run the fronts on my next 2 day event although I'll have a spare set with me. On the best time thread, I'm in top 3 on the 3 tracks I've run with the GT4.
#1095
Originally Posted by ExMB
Hey OJ. Clean out your PM inbox. ![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
I have about 20 days on the ap rotors on the GT3 and GT4 and they still look good. I'm still predicting 40 days or more. Who needs pccb? Amazing.
Anyone going to thill next Friday?
