GT4 - Unlocking the Power Potential!
#1021
A few laps from this weekend's event. It was hot and the times aren't anything spectacular. The car is definitely capable of getting under a 2:20 with a real driver. I turned the power down substantially because I was concerned about the 100F + temps and the long straights but the Colonel ran like a top!
https://www.youtube.com/watch?v=OdTWKM836hA
It also helps with a 4.0 X51!
#1022
Basic Sponsor
Thank you! The biggest thing i notice is the power in the top of 3rd, 4th and 5th gears. I have the tune turned down substantially and in most areas i was shifting at 7K to 7.3K RPM. The car in cold temps revving to 7800 prob makes another 30 rwhp.
#1024
You must do a lot of deep sea fishing in Florida, it seems you had no trouble whatsoever reeling in pretty much everything you came across!
Excellent driving & amazing car. Are you running the stock gears? Your motor was still kicking butt being dialed down. : )
#1025
Got a few questions here for bgb so please bear with me. I decided to ask here because I'm pretty sure there are Californians who can benefit from the answers.
So, how much hp gain will I possibly be looking at if I want it run the entire stock exhaust system, but have the x51 + 4.0 stroker done? (Assuming CA 91 Octane)
Will the car pass CA smog? (Readiness flags ). Are the CELs turned off by virtue of the sensors giving it an passing reading or are the lights just turned off?
I understand the the cobb is used at this point but is the Ehressmann a more solid option in terms of reliabilty? Which is a more forgiving/versatile tune ?(working over a wider range of temperatures and atmospheric conditions we've seen temps of 117F in CA recently)
Also, do you have your customers buy the kit from suncoast or do you do modifications to the parts used(port and polish)? I may buy the kit now and have the mods installed two years later after warranty ends just to make sure I end up not being able to find one.
#1028
Basic Sponsor
Ha ha ha...i've been at it for a long time buddy! I got my competition license in 2001 after attending 2 DEs.
Thank you! The PDK gearing is stock. It's going to be a while before the PDK final drive gear is available. The tires help a lot though. I am sort of picking on freshmen so to speak because i'm on slicks but i am still driving around at about 80%.
I will see if i can answer these without missing anything. My numbers are more conservative than others when it comes to the power gain/loss from the exhaust but let's assume it's a peak number of 15rwhp from a set of race headers without cats vs. the OE manifolds with cats. In certain parts of the rev range that number could be as much as 25 rwhp but let's keep things on a peak basis. The car in that video is running a stock PSE rear muffler section so that keeps things on an apples to apples basis. The car will pass smog as none of the readiness monitors are turned off when running the OE manifolds and not running a race exhaust. In fact, Cobb does not turn off readiness monitors - they just have a feature for race car owners that turns off the request for the Check Engine Light for race cars that are for off-road purposes and don't run cats. I am currently working with Cobb to add another air flow table so that the ECU is 100% happy about its digesting more than the standard amount of air intended for a stock GT4 engine. The Ehresmann solution resolves this already. Both the Cobb and the Ehresmann solution are great tunes but the tune from Germany is encrypted and can't be massaged by anyone in the U.S. That's the biggest difference among the two. If you decide to go with a 4.0L down the road and start with just the Stage II X51 upgrade now, the ECU would have to be sent back to Germany. This is all rather easy though as I still have a very good relationship with the folks in Germany.
The above reply would cover you as well. The two issues with putting any better flowing product on a Cayman is that when the exhaust is less restrictive (100 cel vs 200 cel) it throws a fault for a variance between the pre-cat and post-cat O2 sensors that are expecting to see a very standard variance based on an OE catalytic converter. The same is true for the IPD plenum; if you add the larger throttle body and the engine notices that it's digesting more air, it's going to trigger a fault for an implausible MAP/MAF volume. Once i'm successful with the new tables and can tell the ECU what to expect, there will be zero concerns. if you're worried about what to do on the exhaust front, we recommend sticking with a 200 cell catalytic converter when the time comes. We recommend catless race headers IF AND ONLY IF you're going on the race track. Even an OE catalytic converter cannot handle the race track environment...that much we have proven repeatedly over the last few years.
We run a 265/645/18 up front and a 305/660/18 rear in the Pirelli Pzero slick race rubber; it's by far and away the stickiest rubber you will ever get your hands on.
#1030
Basic Sponsor
I forgot two points:
1.) We purchase the Power Kit from the dealership and sell them to the customer but lately they're getting harder and harder to obtain. I purchased the last one in inventory worldwide because i got nervous. I am not sure when another will become available.
2.) Any Porsche with an IPD plenum will have the same restraints going through smog as a 4.0L X51 GT4. If you have stock manifolds, your O2 faults are gone; if you have the IPD, you're digesting more air than normal just as the larger displacement motor does. In the case of a 4.0L GT4 with or without X51, since it's the same engine case, it's the same motor and doesn't qualify as an engine swap.
#1031
#1032
I use the same combo with 19x9/19x11 Forgelines.....you can't go wrong. I do buy scrub tires and they are more than OK for me at DE events.
#1033
Location: On a pygmy pony over by the dental floss bush
#1035
Good question.
