Sponsored by: APR
GT4 - Unlocking the Power Potential!
Old 05-01-2016, 11:02 AM
  #631
Jimmy-D
Jimmy-D's Avatar
Received 1,454 Likes on 758 Posts
Originally Posted by d00d
That sound isn't normal, check that the Y intake and manifold rubber boots are fitted correctly.
You can do the recalibration without having Porsche use the PIWIS II.
Turn the key to the first position, which is the one before the engine turns over, wait at least 60 seconds.
Press accelerator pedal to the floor and release, remove key.
It will go through the adaptation process after that, may take 50 miles if you take it easy.
2016 white/black GT4
2008 white/amaretto S8
I thought the second position was the one before you turn the car over?
Old 05-01-2016, 11:03 AM
  #632
Jimmy-D
Jimmy-D's Avatar
Originally Posted by CAlexio
Nobody had mentioned this adaptation process before, where did you find this info?
Nobody has yet answered the question that why would one have to do this adaptation if you have a tune
Old 05-01-2016, 11:06 AM
  #633
jmartpr
jmartpr's Avatar
Received 1,474 Likes on 918 Posts
I have also read in some posts about disconnecting the negative from the battery during the installation and the ECU will re-learn everything once the power is back....
Old 05-01-2016, 11:17 AM
  #634
jmartpr
jmartpr's Avatar
If I have to guess given my limited knowledge of Porsche ECU's I guess most tunes would address fuel/timing calibration but the TB calibration/adaptation is probably to give the ECU the range of operation for the new TB.....probably the ECU recognizes that the TB is new and different. You stomp on the pedal and the signal send from the TB goes out of the range pre-established on the ECU for the stock TB......
so you get a CEL or less performance given that the throttle opening is out of place on the ECU fuel and timing maps. If there's an option to calibrate with PIWIS best guess is that it's necessary every time you change the TB.
Old 05-01-2016, 11:23 AM
  #635
d00d
d00d's Avatar
I got this from the 987 IPD plenum install document, not sure where Greg got it initially, probably from a shop manual.
Depends on how you look at it I guess.
If off is 0, power would be 1st, and start would be 2nd.
Old 05-01-2016, 11:28 AM
  #636
Jimmy-D
Jimmy-D's Avatar
^Correct
Old 05-01-2016, 08:08 PM
  #637
CAlexio
CAlexio's Avatar
Received 1,973 Likes on 917 Posts
We need to summarize what we know almost, but not sure I'm the best to do it as I have only read on here the info. What I gather thus far is:
-with tb and plenum you can recalibrate during ignition with the gas pedal procedure.
-without a tune you will get a cell no matter what
-the hanging throttle issue has happened with a tune while under heavy usage at the track.
Any other core conclusions we can draw? I have yet to install my Tb and plenum and was keeping my fingers triple crossed that I wouldn't have to do the tune in order to avoid the cell... Kind of bummed now
Old 05-02-2016, 02:20 AM
  #638
kitwetzler
kitwetzler's Avatar
Kit, I had talked to Fremont and was told the piwis was no problem... Have you now heard otherwise?
That's good news, I'll try there again. I called and the SA I got after a 15 minute hold had no idea what I was talking about :P
Old 05-02-2016, 02:22 AM
  #639
kitwetzler
kitwetzler's Avatar
AFAIK, the 981 SDI9 does NOT do the throttle body adaptation this way. I'd love to be proven wrong, but unless you turn the car to the on position, the throttle body doesn't move at all in the 981. I saw that in the 987.1 guide but the 981 does not do this.
Old 05-02-2016, 10:45 AM
  #640
d00d
d00d's Avatar
Good to know, thanks.
Even so, usually a procedure like that doesn't go away between ECU versions from the same company, unless that information is from the older Bosch ECU.
If anyone can find the source that would be great.
Looks like the 987 DFI SDI3 is also from Siemens, and the Durametric can start the adaptation for that version.
Maybe what jmartpr describes causes it to start an adaptation, or it will just start on it's own at some point.
Old 05-02-2016, 01:37 PM
  #641
jmartpr
jmartpr's Avatar
If we could get the details on how the adaptation is done with PIWIS or Durametric.....IMO I would think that letting the car do it's own calibration on a DBW (drive by wire) part would be more risky and less precise than providing the ECU manually the minimum and maximum points for the TB operation.....unless the TB has the ability to send to the ECU throttle plate percentage opening and the ECU adjusting it in relation to gas pedal positioning, but I doubt this could be the case.
Old 05-02-2016, 03:35 PM
  #642
d00d
d00d's Avatar
In the Audi world the Durametric analogue is VCDS which provides more functions overall, and the TB adaptation there is accomplished automatically by just starting the process;
http://wiki.ross-tech.com/wiki/index...ment_%28TBA%29
Old 05-03-2016, 10:23 AM
  #643
BGB Motorsports
Basic Sponsor
BGB Motorsports's Avatar
Originally Posted by Fabspeed Motorsport
John,
I have only found one other GT4 owner experiencing an issue similar to this (slight throttle hang), and all in house installations with the Piwiz recalibration have gone off without a hitch. We spoke with Gavin over at Autoquest and he has had no issues with any of his installations as well. We are waiting on word from our tuner and Cobb on getting into the throttle body mapping to help resolve Jacy's issue. Feel free to give me a ring any time and I would be happy to share any relevant details with you.
Thanks for the support. It's amazing how all of us can share information despite selling competing products. Reasons like this are why those that choose to collaborate will always go further than those that do not.
^ Good question because I was thinking the same if you are implementing a tune. Would not the tune do this?
if not - do you have to wait for them to do this than implement the tune??
As of right now, I know of 2 ECU vendors that have been able to turn off the request to the instrument cluster to throw the code for the MAP/MAF being improbable. Prior to this, doing the throttle body adaptation used to buy you some time but it was never 100% guaranteed as I can think of a story from everyone about how sometimes the CEL would return and then go away again after a while.
Originally Posted by jmartpr
Is the TB recalibration with PIWIS absolutely necessary?
Every single time you program the DME you must do this adaptation or the car will run in what's called Reduced Engine Power UNLESS the battery gets unplugged during the entire process; if so, you can navigate through it and the car will run and will not be in Reduced Engine Power BUT the CEL usually returns. This is why tuners have implemented this into their protocol so that the writing software does it or else there's no way the car would run well after programming.
Hi guys,
I bought the IPD plenum and 82mm throttle body, along with an Accessport for my Spyder. I have not gotten a PIWIS throttle body adaptation done, the dealers around me don't want to do it. I was reading some of BGB motorsports's old posts on the 981 Cayman boards and I saw that a few others have struggled with P1074 and P0068 codes, (http://www.planet-9.com/981-cayman-a...tml#post884626) After about 50 miles, I'm now getting those CELs.
BGB - in your experience, is this still true with the 3.8l motor in the 981? Should I just drive the car and hope the DME figures it out? Or should I go ahead and try to pay someone to do the PIWIS throttle body adaptation?
Here's the thing...while everyone is saying this is all you have to do, i'm still skeptical that it's a true 100% success ratio. Some people have been successful, some have not. It seems that those that do it, drive around on the street and they're fine but once you drive the car at WOT and mash the gas half a dozen times, the rumors are that the next time you turn the car on the fault comes back. As of now, both Cobb and my other tuning partners have found a way to get rid of the CEL on the cluster. You could try another dealership...I can't imagine anyone would say no if you said "charge me 1 hour's labor and please re-adapt my throttle body." I can't believe they would say "no, we don't want to" but then again, some dealerships are hesitant to touch anything and others are super gung ho.
I too was baffled by the different sound that he had afterward but he said once he went to the dealership, it cleaned up. I'm still unclear though but if that's the report, then I trust it.
Agreed. The calibration is designed to calibrate the pedal position to the voltage sweep of the throttle blade. Every time you turn on your key, that click you hear is the throttle plate waking up and talking to the ECU.
To confirm based on what I know:
1.) I don't think that's the same as doing a TB adaptation with the PIWIS but I am not 100% sure because the ECU stores a fault if you put a new throttle body on and do not run the adaptation. HOWEVER, if the car goes to sleep long enough, there's a good change it will resort to a self adaptation because others have installed throttle bodies and have been able to drive their cars without doing it with the PIWIS BUT, the CEL has returned even though the vehicle has functioned fine post install.
2.) Without a tune there's an 80% chance that you will get a CEL but I tell everyone that they should expect the CEL 100%. Some folks say they have not, Fabspeed reports not...I'm not refuting what they're saying but i'm a skeptic when it comes to how fickle these cars are and I can't believe that will fix it 100% because I've gotten calls from frustrated GT4 owners who had a dealership clear the CEL and had it return.
3.) The hanging throttle body has happened with a tune AND without a tune. Someone on here PMd me to say that some of the Club Sports experienced an issue on downshifts with AND without programming at Laguna Seca this past weekend. So...the more I dig, the more I find.
In addition, I got impatient and called IPD and they said that of the 200 981 plenums they've sold and of the 60 GT4 specific sales, only 2 people have reported the issue of the hanging throttle. At this point, it's rather inconclusive as to what the cause of the problem is but it's clear that it's not a result of aftermarket mods. My apologies for the lack of responses lately but I've been doing homework on this subject and did not want to chime in until I had gathered more facts. I am still a bit baffled though and i'm ready to wonder whether the auto blipper is confused. We just finished the buildout of a PDK 2.7L 981 race car that now has a 3.8L 991 motor, got re-coded as a GTS and then flashed with Cobb tuning and it ran flawlessly for almost 400 miles. No issues with hanging anything. I can list almost a dozen 981s that we have built that have larger throttle bodies. Before the GT4 and the recounts of the hanging blade, I had never ever heard of such a thing. Make no mistake though...now that a few race teams have had problems and my phone has been ringing non-stop, we should have some more information over the next 2 weeks. Something is causing a problem somewhere...we just need to find out what and where.
BGB Motorsports Group
Old 05-03-2016, 11:32 AM
  #644
jmartpr
jmartpr's Avatar
John...is there a way to know if the engine is running in the Reduce Engine Power (REP) mode? Any codes? If for some reason you are at REP mode can unplugging the battery for a long period reset the ECU into regular mode?
Old 05-03-2016, 11:36 AM
  #645
user1029
user1029's Avatar
Does a CEL from race headers throw the car in limp mode? Or is it just a nuisance?
Quick Reply: GT4 - Unlocking the Power Potential!
