Here is pic of my GT4, great car.
#182
It feels natural going whit autoblip, when driving hard anyway. My opinion is it feel more weird to use it when not driving hard. Sure if on autoblip in city then to much peopel turn their head and you got to much attention. If thats a bad thing or not others must decide. But for me I get to much attention then. But on track its feels very natural and fine.
How many track KM's and how are the pads/rotors and tires holding up?
Could be real additional cost savings competed to the GT3..
Looking for a dealer to fit clear bra, CS bar and 6 point harnesses to my US spec RS. Will have to do the same if I get a GT4, ugh...
#183
In regards to the auto-blip in sports mode, do I interpret it to work as follows:
Let's say you're in 4th gear coming down a straight with a 2nd gear turn approaching...do you simply apply the brake, then clutch in, shift to 3rd, clutch out, still braking, clutch in, shift to 2nd, clutch out, power out?
#184
rickdm
#185
One lap on nur, real gps speed/ km/h porsche track app/vbox-sport. Sorry for bad quality film as I just filme when play this on my low quality tv, as well filmed the tv with my old iphone4.
I might if find time load a bettet quality film. Still the speeds are true gps km/h speed as Well lap time true
http://youtu.be/pZO75dFDrZM.
Can some one bed in film?
#186
To embed the video put the Video code, in this case pZO75dFDrZM within [ YT ] remove the spaces [ /YT ] and it will work.
I might be tempted to add the sport chrono after this, but I don't know if its worth the extra cash compared to my Vbox Sport-setup that I run today. What do you think?
#187
Car data go thru wifi to app, i like that. racenavigator you need plug in cable to car. Same on racelogics vbox-HD(if you want gears in movie etc)
#189
Thanks for answering the 1000 questions. Not many to give feedback yet and even fewer truly fast.
#192
A few things I tought I could mention.
Until now, no need to fill up any motoroil as the levels been all ok from 0km to 3000km. I did check the level from time to time as new cars driven hard could use oil, but not this gt4.
The tourq For wheel is 160nm. (Not 140 as some will say)
The plastic under front like brake ducts and front spoiler lip are things that one will need to change, or look after as this cars is low.
The LWB chairs are a god compromise, but as this car is stick shift and pull high level of G its pretty much a workout doing track Nurburgring anyway, hence I would sitt better and relaxing more if in another chair with More support.
The sound this car makes are great, others tell me as they hear it better than me driving it.
As a total pack this is one great compromise of a car, out of the Box new on Factory setup it drive very well indeed.
Compared to My last Porsche i drove on nur the gt4 give you a real workout
#193
Pic of My front tire.
Due to slightly to high tire pressure front and factory set car i get this lose of pattern. And by that I dont use to outer grippy edge of the front tire. No bigg issue but wanted to try pirellis anyway. After god support from Michelin motorsport division at track we agreed the optimum hot pressure for my car/drivingstyle front tire would be 1.9 hot.(they did check my tire/wear and conclusion there after is 1.9 hot in front) Did mostly drive 2.1 or at end 2.0 wich is slightly to high accoringly to support crew from Michelin motorsport.
even My car need more aggressive camber its Always a compromise as Well different drivers need different cambers as we all know to make the most of a tire. In genral these guys said its often to common trackgoers in street cars as mine and others go to aggressive camber.
#194
Next trip I will set up car to my drivingstyle at Manthey/Raeder
Putt in more Schims For more camber
Change this stock toe bar to cup cars longer bar to be able to get more aggressive camber front as stock is to short
Put in more Schims For more camber
#195
Do you know the maximum value of amber in the front before you have to change to the cup bar?
