E/SIM Racing For discussion and info on iRacing, SIMs etc.
Rennlist iRacing thread
Old Apr 24, 2014 | 12:45 PM
  #4501
User 52121's Avatar
User 52121
Video from last night. Quite a few great battles!
Gotta say - even though I've only been a "regular" for a short while w/r/t RL'ers meeting up to go iRacing, it's REALLY cool to see how far some of you guys have come. We have little mini-battles going on all the way to the back of the pack now. I'm hopeful we can keep up this attendance throughout what's traditionally the slower months (aka "the summer"). I know I'll probably miss more Sunday night practices (warm weather = more family stuff, BBQs, etc), but should make most of the Weds night races.
  #4502
Glenn(Geneva, IL)'s Avatar
Glenn(Geneva, IL)
Originally Posted by JustinL
I took the RUF to COTA and didn't have any trouble with frame rates or weirdness. I wonder if the new 3-d crowds are causing you guys some trouble. Try turning down the crowd and grandstand detail and see if your frame rates come back.
I will give it a try tis weekend. It is amazing that you can't take the same resolution that you run another dozen tracks from IRacing and have the same resolution at COTA. How did you find the experience with the new tire models on the COTA track? Do you have a setup I could try to start out and ease the pain??
Old Apr 24, 2014 | 12:49 PM
  #4503
Charles A. Toupin's Avatar
Charles A. Toupin
I have a C6.R setup from Daytona that I could send you. I imagine the TCS has improved the corner exit that I was struggling with.
Thanks a lot Justin!
I could not be there last night, I was in a meeting...
c.
Old Apr 24, 2014 | 12:54 PM
  #4504
Charles A. Toupin
Racing up front is very clean! I wish I was as fast as you guys!
c.
Old Apr 24, 2014 | 12:58 PM
  #4505
JustinL's Avatar
JustinL
COTA seems exceptionally smooth with both some very quick transitions and a couple high speed corners. To me it seems a lot like Silverstone so I was using one of those setups from the iracing forum. It is a tricky track because a lot of the corners encourage you to go in pretty hot, like the esses where the first one is flat out, then you've got to start scrubbing speed without understeering off the track.
Old Apr 24, 2014 | 01:16 PM
  #4506
abqautoxer's Avatar
abqautoxer
Thanks for the video again Jim!
Old Apr 24, 2014 | 01:20 PM
  #4507
User 52121's Avatar
User 52121
There *are* a couple tracks that seem to be framerate killers. Spa is one. Silverstone might still be (it definitely used to be...) Maybe COTA is just the worst one.
Like I said, I noticed it too. But then I also have ALL the eye candy on. I'm running the Rift which is only 1280x800 on a GTX770 so IMO I *should* be able to run it all. To be fair, I have not spent much time at Spa in the Rift, to know if I also take a framerate hit there too while Rifting... lots of trees and shadows combined with the low resolution of the Rift make it hard to see, so I've generally avoided going there. But back when I was running triples (on my old 6970) I definitely had to turn things down to run there and maintain 60fps.
Old Apr 24, 2014 | 01:21 PM
  #4508
User 52121's Avatar
User 52121
No problem. This one so far seems to be fun to watch. Good racing going on.
Old Apr 24, 2014 | 01:26 PM
  #4509
User 52121's Avatar
User 52121
Luke had a pretty awesome drift at 17:16 in the kink LOL (Generally the LAST place you want to slide at RA is the kink!)
Old Apr 24, 2014 | 02:06 PM
  #4510
Glenn(Geneva, IL)
Thanks Justin & Jim, I will try to pickup the Silverstone baseline and work from it. About 10 days from now I will be at COTA racing my 944 Turbo so I will miss the 5/4 practice while on the road back.
Old Apr 24, 2014 | 02:20 PM
  #4511
JustinL's Avatar
JustinL
Well you've got 10 days to practice your *** off before you go
Old Apr 24, 2014 | 02:23 PM
  #4512
loxner's Avatar
loxner
See you there! I'm glad they finished the COTA build in time for us to run some practice laps; I haven't been there in real life before. I'll be around the TOPP Racing garages, feel free to drop by.
Old Apr 24, 2014 | 02:26 PM
  #4513
loxner's Avatar
loxner
LOL, it does look pretty cool from that view
Old Apr 24, 2014 | 02:29 PM
  #4514
User 52121's Avatar
User 52121
Most of the iRacing baselines seem pretty awful.
I've got 2 "base" sets, which have slowly morphed into just one base set. One is based on Justin's Watkins setup, the other is one I got from Tom (which was apparently actually Julian's setup) from Mid-Ohio.
The Tom/Julian set is stiff, needs lots of trail-braking to turn in... but is consistent.
Justin's set is more loose and tail happy, but turns in better without needing as much trail braking. It's also VERY soft by comparison and soaks up curbs and bumps much better.
I've slowly been morphing the two - taking the Tom/Julian set and softening it to be more like Justin's over the bumps. I'd recommend you do something similar. Start with the set I shared with you earlier this week. It's actually pretty universal and works on just about all the tracks, just needs a little tweaking here and there for flavor.
Old Apr 24, 2014 | 03:52 PM
  #4515
Charles A. Toupin
I like Justin's set-ups...
c.
