E/SIM Racing For discussion and info on iRacing, SIMs etc.
Rennlist iRacing thread
Old Feb 9, 2014 | 01:24 AM
  #3061
tasracer's Avatar
tasracer
I jumped in with only one qual lap
Was on ur tail but messed up
Sent from my iPad using Rennlist
Old Feb 9, 2014 | 01:28 AM
  #3062
Gator_86_951's Avatar
Gator_86_951
Spell Checker
Yeah, I wanted you to take poll because I didn't want it. I LOVE close racing, and we were clearly faster than the balance of the field by like 1.0+. Scott XXX pulled the inside job on me in the bus stop, so I returned the favor in the next corner immediately . Didn't look as dramatic on replay, which is a bummer.
Old Feb 9, 2014 | 01:41 AM
  #3063
abqautoxer's Avatar
abqautoxer
@ WGI it wasnt IMS failure, sadly my fault. Car was tough to drive after I brushed a wall and knocked out my rear toe on lap 6 or so. On the final lap I pushed too hard and hit a wall hard enough to blow the engine. I killed bugs for the last several corners.
Old Feb 9, 2014 | 09:29 AM
  #3064
ny991's Avatar
ny991
I am going to put up a Mosport practice this morning. Is 11-1 EST a good time for anyone?
Old Feb 9, 2014 | 11:29 AM
  #3065
tasracer's Avatar
tasracer
I'm home
It's Sunday
It's 20 deg outside
So yes
Old Feb 9, 2014 | 11:41 AM
  #3066
ny991's Avatar
ny991
Hey, you're doing good! It's 13 here.
I set it up under hosted open, rennlist racers practice 11-1 EST.
Old Feb 9, 2014 | 11:51 AM
  #3067
HoBoJoe's Avatar
HoBoJoe
Well my brake pedal took a crap last night and isn't reading at all now. I'm going to calibrate the clutch pedal as the brake and see if I can run like that. Hopefully I hear back from fanatec quickly on how to get it fixed, my guess is that the load cell died.
Old Feb 9, 2014 | 12:01 PM
  #3068
tasracer's Avatar
tasracer
Fanatec and quickly
I hear those two don't go together
That said I'm ordering wheel and pedal from em
Looks like good stuff
Old Feb 9, 2014 | 12:21 PM
  #3069
HoBoJoe's Avatar
HoBoJoe
When my original pedals broke from my turbo S setup, they shipped me a new set in less than a week. However, I have heard that is not the normal situation.
Old Feb 9, 2014 | 01:07 PM
  #3070
George_B's Avatar
George_B
Hi All,
Anyone know how often those load cells fail ? Fanatec sells the for 15 bucks, might be wise to have a spare just in case. I've had my CS pedals for a couple of weeks, want to get the cs wheel eventually. Also thinking of the Obutto seat as well. Anyone know anything about them ?
See you all at "the track".
George
Old Feb 9, 2014 | 01:22 PM
  #3071
mikew968's Avatar
mikew968
I am new to Iracing and am finding it a lot harder to drive consistently than I would have thought. Any suggestions?
Thanks,
Old Feb 9, 2014 | 01:48 PM
  #3072
tasracer's Avatar
tasracer
Originally Posted by mikew968
I am new to Iracing and am finding it a lot harder to drive consistently than I would have thought. Any suggestions? Thanks,
It takes time...
And a good setup makes a diff...
What wheel/ pedal setup r u using?
Old Feb 9, 2014 | 02:03 PM
  #3073
pmason's Avatar
pmason
Mike, like a real car slow down and work you way up. You will do better slower and constant than fast and go off quickly. There are a number of us that just started, I started beginning of Dec. What I do to learn a new track is have the line on the track until you can get constant, then turn it off and see if you can work your way up to the lap times you were with the line on, it takes a few laps but comes. Also ghosting, jumping in someone else's car and seeing what they see and do help.
Old Feb 9, 2014 | 02:04 PM
  #3074
sbelles's Avatar
sbelles
I'm in....
Just saw this at 12:58. I'm in for the next one.
Old Feb 9, 2014 | 03:00 PM
  #3075
abqautoxer's Avatar
abqautoxer
Drive a 80% for several laps until you can run all the same times over and over with zero incidents, then pick up the pace. If you start racking up incidents, back off until you can. It's a progressive learning curve and driving aggressively is usually rewarded with damage.
I'm about to be on my 3rd load cell for my Fanatec CSR Elite pedals. The 2nd one died just before this season started so I've been running using the clutch pedal as brakes. Since it seems to work, I haven't changed out for a working load cell.
