CarPlay Retrofit in PCM 3.1 Cayenne 2013 ( With Pictures )
#61
I think the reason for #1 is not the PCM, it's your key memory. Was your key was last used to lock the car remotely (with the key button) when the tuner was selected as the source?
Try setting the source as Bluetooth and then getting out of the car and locking it using the key button. I'd also select "SET" on the door - and press whatever memory button you're using - that also saves it - but only to the button (the key has priority over the buttons..)
It takes the PCM a minute or two to connect to the BT devices, after the rest of the system has booted. So when it starts playing music there’s is no BT Audio device available and it switches to the default... which appears to be FM radio.
Lodo1000 (11-17-2019)
#62
Couple questions about these systems.
1. Does the PCM stay on the CarPlay source on start-up? That is my biggest complaint about the 3.1 system is that it does not stay on Bluetooth and reverts to tuner,
2. Can you change tracks using the steering wheel diamond button (providing you have that set up)
3. How quickly does it connect after start up?
On CarPlay, I can can change tracks with my steering controls if my Audio source is BT audio.
#63
Mine Connects to BT audio in 05 seconds.
#64
I also almost never unlock the car with the key, as I have the hands free entry (or whatever that is called). Would that make a difference?
#65
Same here. When I start my car BT doesn't show up as a source option for at least 30 seconds (seems like forever!) really wish it was faster. I ordered the CarPlay kit off Aliexpress today
#66
Did anyone post a link to the risers mentioned to keep XM radio? I looked for risers on Amazon, but not sure exactly what I'm looking for. Just ordered this kit off aliexpress: https://www.aliexpress.com/item/3296...49964c4djT4lbt
Will put it into my wife's 2013 Panamera. Really hoping it works well as I'm in the market for a Cayenne and was going to go with a '17 to get the CarPlay, but if this works well I'll save a good chunk finding a low miles '16 instead.
#67
I purchased the Joyeauto Porsche PCM3.1 for my 2012 Cayenne TT. The installation wasn't to much of an issue. I didn't keep my satellite board, just too crowded. The unit powered on and I have audio but my screen is black. So I took apart my PCM and checked all of the ribbon connections and they all seem fine. Does anyone have any idea what is going on with my unit.
#68
#70
Mine arrived today, but it looks like I'm missing the ribbon cables and brass stand off screws. I've sent a message to the seller. I'm bummed, was looking forward to installing this!
#71
The stand off screws and the ribbon cable should be in the same package as the new board. I hope you have better luck then I had. I had everything installed and my screen was black, I had audio but no screen. Pulled the PCM 4 times to check all of my ribbon cable connections and the LVD cable connection and no go. I was texting the company last night and we sent picture back and forth but couldn't seem to get it working. So I disconnected everything and went back to the original system with no CarPlay. Bummer Not sure if they will be willing to refund me. They kept asking me if I viewed their video which I did like 8 times before I even started. Good luck
#72
thanks,
Misha
#74
Joe Deng from Joyeauto, he is a tech guy not a seller.
+86 189 4870 6765
I am very disappointed to read this, mine works flawlessly (until now)
Maybe disconnecting the XM module has something to do with the black screen?
+86 189 4870 6765
#75
Galion whats even more disappointing is that Kevin was going to send me another video which he did but it was all in Chinese and didn't even remotely address my issue. When I asked what is next, nothing, no reply. I would need another large connector piece because the little tab that holds the 2 orange wire broke off and won't hold the connector into position. Just not a good experience. It's not like I'm an inexperienced DIYer, I built computers and have done major repairs on all my cars, BMW and Porsches So I'm a little bummed out.
