CarPlay Retrofit in PCM 3.1 Cayenne 2013 ( With Pictures )
#181
I also had my unit freeze up a few days ago. I contacted tech support and they told me to run a wire and tap into ACC power. I really didn't want to do that as it was working fine before. I ended up pulling fuse #51 and that brought it back. I was having the same issue where I'd see IDCORE but pressing Navi wouldn't switch to CarPlay. I updated my firmware in the Joyeauto unit yesterday and re-paired my phone.
Those who are running the ACC power option, was that something included in the kit or did you do this yourselves? Also does it take any longer for CarPlay and music to start working from a cold start using ACC power?
thanks,
Misha
thanks,
Misha
#182
#183
thanks,
Misha
thanks,
Misha
#184
I ordered the JoyeAuto Carplay kit for my 2014 Porsche Panamera Executive Turbo a few months ago but just recently had an installer install it.
Everything is pretty cool...Siri is a nice addon and the fact that the car now starts with AUX and Navi selected so I don't have to start with FM radio any longer is sweeeet!
Scrolling on the touch screen is useless but I can live without that.
I do have a couple of issues...the steering wheel button is configured for "Next track" but does not work....also when the front sensors senses something, normally it switches to the front camera so I can see what's up - This does not work either (changing to reverse still shows the 360 cam)
Anyone come across the issues above and could help out with a solution? I've e-mailed JoyeTech as well.
Thanks, Mickey
Thanks, Mickey
#185
I would like to ask about a few issues with the joyeauto apple play install. I have Installed in my 14 cayenne and initially had severe echo from all callers.
I have since solved the echo problem by starting the PCM and the joyeauto Apple play Bluetooth simultaneously. Unfortunately I am unsure if the calls are now going through the PCM or through the new Apple play.
The entire system has become buggy with lock ups resulting in a black screen with pressing the nav button. I do eventually reconfigure via the Porsche icon and the Apple play program starts but not as smooth as I’m reading from others on this post. It takes nearly one minute be for an audible book to be recognized and the sound usually will not play through the speakers.
I also cannot get get to the joyeauto tech page with my password for joyeautotech as the page just keeps recycling.
#186
if the incoming phone call is coming through CarPlay then incoming audio will go through the aux port to the speakers ( and not the pcm) and the microphone connected to Joyeauto will be the mic used for that phone call. If you haven’t already you should delete the original Bluetooth connection called PCM from your Bluetooth connections in the iPhone and only connect through IDCORE.
do you have the same problems if you disable WiFi in your phone and connect for CarPlay through the USB port ? So see if you can bypass Bluetooth and WiFi in the joyeauto system by using the USB port into the phone directly and see if that helps solve some of your issues. If you are having echo problems you also might want to try and change the mic and see if that helps.
#187
#188
if that does not solve it then turnoff WiFi in iPhone and see if connecting through USB thru iPhone lightening port helps solve the issues
if that does not work consider if u might have a bad microphone from joyeauto and see if u can test with another mic
if that does not help u might have a defective joyeauto hardware board
#189
Thanks for all of the replies.
With the echo I unplugged the pcm microphones thinking they were competing without change.
I have disconnected and replaced the joyeauto mic without a change.
With pcm connected in Bluetooth simultaneously with incscore my echo is gone indicationing my car is using pcm for the phone not the apple play.
I have disabled pcm Bluetooth and it echos
I can only make call or hear audio if the WiFi from joyeauto is connected. And when it freezes I reset the WiFi and it works again indicating that Bluetooth is doing nothing.
It connects to the incore Bluetooth but this doesn’t seem to matter if it’s on or not
the frustrating part is after spending 5 minutes to get it configured I can hear my audiobook playing and feel good about the world and when a phone call comes in and then hangs up the whole system is lockedup again.
I have great touchscreen and the icons work it’s just not good
I will shop for newer or better versions if I can’t get this to work. Do you guys think software from joyeauto is an issue?
#190
#191
Yes unit works with usb and connection is immediate.
But phone calls have a terrible caller echo without pcm booted even with usb.
When I unplug the usb this results in Porsche setup screen and no link to CarPlay despite Bluetooth and WiFi connection.
thanks
thanks
#192
Thanks, Mickey
Thanks, Mickey
