Boxster spyder
#46
That's a surprise.
Not bad at all.
Still strange they didn't lose a lot more weight for all the compromises.
Equally curious that not one of the inside-info sources had a clue that this was going down the pipe.
Porsche still has a few surprises up it's sleeve, but this one is news.
Not bad at all.
#47
Wow, very nice!
I really hope the 'lightweight movement' makes its way across the prod line!
Dumb question as I have never run a cab at a PCA event: Can you run the same at a DE event without a hardtop or without a full soft-top?? I think I've seen soft-tops out there here in NJ, but I don't recall ever seeing an open top unless spec'd with a cage. You prob have to have arm restraints at the very least..
#48
Wow, very nice!
#49
CGT - Here (NJ) for certain cabs, the roll bars must be "deployed" or popped up first believe it or not. Not too sure of the exact rules as I don't run one. And if there is no full top (soft or hard) arm restraints are required. I am wondering how the "land of laws" will treat this car with a 'bimini' (or any old jeep or boat owners) top ..
#50
Anyone got a pic with the rear lid up? I wonder why they didn't go *****-out and make it a see-through to the engine ... oh, that's right ... the engine is pretty boring and should be locked away in a box(ster) ... is that where they got the name? : )
I wonder if the Boxster/Cayman has the same weight problem in the new LED tail lights.
#53
Love it.
Make mine white with black wheels, PDK, radio, no a/c.
#54
This is one cool car!
#58
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
"Some components grew a little bit heavier, even on the GT car ... the rear lights, the LEDs - they weigh 2 kilos more each. They look fantastic ... but all the brainwork, all the cables and the unit itself ... altogether it’s 4 kilos more, so you have to find this weight elsewhere..."
Source: Andreas Preuninger interview by Chris Harris (Geneva Motor Show 2009)
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
![nono](https://rennlist.com/forums/graemlins/nono.gif)
#59
Andreas Preuninger comments on the LED lights for the 2010 Porsche 911 GT3 at the Geneva Motor Show...
#60
Interesting that he mentions "brainwork" (electronics hardware somewhere in the car) and "cabling" (LEDs should be running much less current and so requiring much less wire ... maybe there's some design issues in the LED housing itself) and "housing" (so the Cup assembly could easily be lightened considerably to retain a street car resemblance.) At 2700lb, the Cup is by no means a lightweight, so 4kg to them (keep in mind, that's additional weight, not total) might not be worth pursuing when they're still running urethane bumper covers for example.
Pretty cool that the engineer is openly discussing the pro's and con's, not at all hiding the contradictions of going after a $1700 battery while carrying LED ballast at the worst point on the pendulum.
If I get an RS, I certainly won't be targeting those 4 kilo's, but if the Cup assembly is lighter (and not wildly expensive) I have to admit I'd be tempted to tinker with it just for fun.
