View Poll Results: Poll: Have you had bore scoring on your 997.1 or 997.2 engine?
Yes, 997.1 (05-08 MY)
143
14.50%
Yes, 997.2 (09-12 MY)
18
1.83%
No, 997.1 (05-08 MY)
524
53.14%
No, 997.2 (09-12 MY)
301
30.53%
Voters: 986. You may not vote on this poll
Poll: Scored cylinder failure for your 997, Y or N? tell us (yr, 997.1 or 997.2)
#301
2005 C2S 89k miles no scoring as of last scope at 84k miles. Original Clutch and IMS. Preventative maintenance scheduled for IMS retrofit at clutch replacement.
California/Colorado/Alabama car.
stiffler199 (06-23-2020)
#302
thanks!
#304
#305
2005 911 base model, 3.6, 77K miles, Bore scoring on #6 cyl. Motor currently being rebuilt. Just bought car Feb.2020. My first Porsche! Very sad story!
#306
Just curious, but what region of the country did you buy the car in or do you know where the car spent most of its time? Also, who is doing your rebuild, if you don't mind sharing?
#307
Car spent most of its life in the Carolinas ( Car was a trade in at Lexus of Greenville,SC.) Several people wanted the car so I had to move fast! I did not have the car scoped! Sister dealers Porsche, Jaguar, Land Rover next door. Motor and car are at Black Forest Racing in Denver, NC. They have a long history of racing air cooled and water cooled Porsches. Google them to read about them.
#308
#309
I'm also curious how you found out it had bore scoring. Did you have the bores scoped after you purchased the car, or did you experience some of the bore scoring symptoms (sooty driver's side exhaust tips, high oil consumption, knocking/clicking sound at idle, large amount of smoke at start-up, etc.)?
I would look into this as well. As we all know, bore scoring doesn't happen overnight. You might be out of luck since you've already pursued an engine rebuild. I suspect the dealer would have just taken the car back from you and sent it to auction. How long has it been since you purchased the car?
#310
Bore scoring was brought to lite when the engine was taken apart. Bought the car in Feb 2020. No smoke, oil use, or storage noise. Also South Carolina doesn't have a 30 day warranty....I tried to get the dealer to give me one year power train warranty and they said no!
#311
Why did you take the engine apart?
#312
I took the car in to have the IMS bearing replaced because I did not have confirmation of the last time it was replaced. During inspection the mechanic discovered that the IMS shaft was damaged. That's when I decided to have the shaft replaced which requires the engine to be opened. That's when we noticed the bore scoring problem.
#313
#314
Build date 2-2005, Looks like the bearing had been replaced once with a roller type bearing that was used/sold by Vertex in Miami,Fla. Don't hold me to that but that's what I have been told byFlat 6 Inovations. PS-I love the car and Looks like I will have a brand new engine when complete! Then all this will be behind me! Fingers crossed!
#315
3rd Gear
We do not typically receive the VIN when doing blocks. Depending on how long ago the block was done, you might be able to find the serial number on the chain well area on the bottom of the block where the IMS shaft is. The other location is up on the part of the block casting where the starter goes. That one will be very hard to get to.
- George
