Lowering Car
Old Oct 31, 2015 | 05:57 PM
  #61
fbfisher's Avatar
fbfisher
I'll post my impression when mine get installed. Those Fuchs inspired wheels look great on your cab.
Old Oct 31, 2015 | 08:18 PM
  #62
myw's Avatar
myw
atsr - very very temping. car looks amazing.
Old Nov 1, 2015 | 09:53 AM
  #63
mattm840's Avatar
mattm840
8th Gear
Great pics!
Old Nov 2, 2015 | 03:09 PM
  #64
skynet's Avatar
skynet
I'm thinking of doing this on my 997.2 C2. I love my C2 but it would look better lower. This is good thread.
1. I've seen the Eibach springs for around 450 and the Techarts around 700. They are the same?
2. As far as clearance, can rennlisters give some specific examples of ground contact (and not)? Like angle of driveways, speed bumps, etc.
Old Nov 2, 2015 | 03:21 PM
  #65
jc9elfer's Avatar
jc9elfer
Originally Posted by swporsche
I'm in the process/planning to lower my 08 997.1 S Cab from the stock height by about 1 inch. Do any members of the forum think this is too much? All comments considered. Looking for pros/cons. Thank You
I used H&R springs with 14mm spacers all around with 20" OZ Ultraleggeras
No rubbing and just about the right ride height for street and track. I am very happy and considerably cheaper than coilovers.
File Type: jpg
Old Nov 2, 2015 | 10:46 PM
  #66
jcsomerv's Avatar
jcsomerv
1. Don't know for sure as TechArt does not publish it's specs. SharkWerks and others recommend TechArt for 997.2 so I paid the extra $250 and went that route. Do not regret.
2. I 'brush' the 2 plastic pieces immediately in front of the front wheels about once per outing. Only on the most obnoxious speed bumps (most there is no issue), the very odd dip in the road taken at speed, or coming out of the local liquor store where the incline is steep and drop off sharp. TechArt lowered my C2 25mm so I considered shaving 25mm off of those 2 plastic pieces and I would have 'factory' clearance but honestly not a big enough issue for me to bother.
Springs + spacers + alignment = proper 911 stance with slight improvement in ride. What a mod.
File Type: jpg
Old Nov 3, 2015 | 03:25 PM
  #67
FFSstavros's Avatar
FFSstavros
Very nice looking car! What tail lights have you put in and did you also do the front DRL?
Old Nov 3, 2015 | 10:06 PM
  #68
dasdman's Avatar
dasdman
Local indy quoted $1080 to install a set of springs, plus $250 alignment. Is there a DIY for replacing the springs myself? I like working on my car and am not afraid of jumping in, also have access to a lift which makes things a little easier. Wondering if I will need spring compression tool prior to starting. My buddy put springs on his 993 and said no compression tool was needed. Looked at the DIY list but didn't see anything for springs. Thanks for any advice or gotchas that anyone can contribute.
Old Nov 3, 2015 | 10:32 PM
  #69
jcsomerv's Avatar
jcsomerv
Thank you appreciate the compliment. Actually it is 997.2 with 997.1 rims.... So a little confusing I know but i really love the Lobsters so am keeping them. :-)
Old Nov 3, 2015 | 11:30 PM
  #70
ATSR's Avatar
ATSR
Your car looks fantastic. I'm also a fan of the lobsters and I think they look great on the 997.2
Old Nov 4, 2015 | 09:28 AM
  #71
Wolfk's Avatar
Wolfk
dasdman,
Yes, an outside spring compressor is needed for changing out springs on your 997.2
They are available at Autozone or Advance Auto as free loaners.
No real "gotchas" in job, fairly straightforward. Some DIY's say to remove front tie rod ends, I did not find this necessary.
The rear spring removal is made especially easier with the upper rear control arm completely removed, (it is just two bolts), some DIY's do not mention this.
Old Nov 4, 2015 | 01:04 PM
  #72
dasdman's Avatar
dasdman
Originally Posted by Wolfk
dasdman,
Thanks for the tips Wolfk, weekend project is coming up!! I went with Eibach springs for a more subtle look and a little softer on my old bones Will add before and after pictures within a couple of weeks.
Old Nov 5, 2015 | 01:20 PM
  #73
skynet's Avatar
skynet
Has anyone used a compensating plate or here to customize their lowering?
I think they come in 3mm and 6.5 mm sizes and I think they can be stacked? Not sure if the 3mm plate is the stock installation, but if that's the case, you could replace with 6.5mm and reduce lowering to 21.5 mm, which is still a tad lower than the SPASM suspension.
Old Nov 5, 2015 | 10:01 PM
  #74
fbfisher's Avatar
fbfisher
Default Eibach's Before and After
First two are the "BEFORE" from this morning, NEXT two are the "AFTER" from this afternoon. Difference in ride height very subtle, perhaps they will settle in time.
Ride comfort is the same (thankfully).
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Nov 5, 2015 | 11:31 PM
  #75
jcsomerv's Avatar
jcsomerv
^^^ looks good. Little hard to see with the light in the after pics. Did you do spacers (looks like not) and alignment? Nice driveway by the way - love to have one like that.
